Question about Bose 901 VI Main / Stereo Speaker
My 901's doesn't sound as they supouse to
I got a great sound on mid and high ranges, but I have read in other web site how impressive bass they got to show. So, I think that I got some trouble. Can you help me?
    Brigadier General:
  • 8,546 Answers
I doubt that poor positioning kill the bass response in any home environment. After all, how far from a wall can you be in a typical living room? I imagine if you placed them several YARDS from any corner (like in the middle of your yard) they may start to sound bass-shy. The Bose 802 is essentially the same and yet you see professionals using them well out from the walls in a dance hall or stage.
Bose 901's are part of a SYSTEM that includes an Active Equalizer.
Are you employing the REQUIRED Bose Active Equalizer and is it installed properly? It applies very steep boost at the extremes to compensate for limitations of the full-range drivers. It is not an option to skip it, unless you want NO BASS.
Posted on Nov 30, 2009
Follow bose recommended speaker possitioning. You probably have some destracting things that the speaker is not able to reflect the sound correctly. Cheers.
Posted on Feb 23, 2009
I have a jvc kdhdr50......and I'm wondering how to adjust the bass and treble also how to turn the loudness on
This is discussed on page 26 of manual. Press and hold MENU and select USER for EQ. Under EQ you will have options to adjust SUB BASS, BASS, MID BASS, ULTRA HIGH, HIGH, MID HIGH, AND MID
Aug 10, 2014 | Car Audio & Video
Rms b80 bass guitar amp has little volume in the low side jack , hi side jack is fine just not as much bass
The low in side jack has a lower vol. but should only be1/4 less than the high in jack on most amps, --try this,-- plug guitar in high in then take all the treble off and 1/2 mid. range bring up bass range and if you have equauzation bring down 26k 5k 10k about 2 notches or points. See if that give you better bass tone.
Oct 10, 2013 | Bass New Rms 40 Watt Bass Guitar Amplifier
How to adjust Dg11100 car amp
If your head unit has an amp gain, turn it up as high as it will go. If it is hooked up to subs, the head unit will say subwoofer output in the menu. Then take a small screwdriver and turn the amp gain on the side of your amp counterclockwise to zero. Turn your freq. up to about a third. Crank your system up, with a song with good bass, and slowly turn your gain up till the bass from the subs sound distorted, and back it back down. If the bass is drowning out the other speakers in your car, then turn the gain down some more. I find it works best if you have your trebble up high, your mid range at a little less than half. And your bass at zero or one. Your amp is cranking up the bass, so let your other speakers handle the rest. This allows it to sound clearly at higher volumes.
Jan 02, 2013 | Cars & Trucks
I put a sub in my 2002 Altima but when I turn it up the bass cracks on the door speakers??? What do I do to get all the bass on the sub
Hi Ethan,
What you're looking for is called a "crossover". A crossover is an electronic filter for an audio or speaker circuit. In an audio circuit, a crossover is used to prevent or pass certain frequencies or a range of frequencies from passing through it. Since your sub will reproduce the bass or low frequencies, you don't want other speakers to reproduce them. A band pass filter on your door speakers will do this for you. A band pass filter passes only a range or "band" of frequencies and blocks those that are above and below the range or band of frequencies selected. Installing a band pass filter will prevent the very high & very low frequencies from getting to the door /dash speakers. Likewise, you should consider connecting a low pass filter to your subs, too. The low pass filters work a little differently from of the way band pass filters work - they only allow low frequencies to get to the sub - blocking all the other higher frequencies (your other speakers are better suited to reproduce those). Lastly, you would install a high pass filters on tweeters. Tweeters are designed to reproduce only the high frequencies - sending mid and low frequencies to them is wasting power and can cause damage to them.
You purchase the filters for specific crossover points (the block / unblocked point) as determined by the individual speakers. If a sub has a frequency response of 20Hz - 100Hz, a low pass filter of 100Hz would be ideal. Remaining filters would need to begin at 100Hz - assuming the mid-range speakers have a frequency response beginning at 100Hz. A band pass filter of 100Hz - 3KHz would fit the bill nicely if the mid-range speakers go up to 3Khz Match the high end of the band pass to the high end of the frequency response of the mid-range speakers. Next, a high pass filter at 3KHz would allow only the high frequencies to your tweeters. Basically, you want to have the entire audible range 20Hz - 20KHz covered by the speakers and have the crossover points that match the frequency response ranges of the speakers.
I hope this helps & good luck!
Apr 12, 2012 | Pioneer Car Audio & Video
Is it possible to hook up 2-6x9 and 2-12in.subs to the 7540a and still pack a nice punch
yes it is however the hookup for it requires something a bit unorthodox
you have 4 outputs (bridgeable)
channel 1 and 2 must be bridged (to lower the ohms) then connected to the 2 6X9 in Parallel..
this must then be set to the high pass frequency (eliminates bass)
lower all the settings as low as possible then turn them up slightly to increase volume to a level where its the hardest and clean sounding..lower volume after
this eliminates the bass and keeps the 6x9 pushing your mid range and high range frequency
now you have 2 channels remaining,, set 3 and 4 to low pass and connect each 12" to an individual channel. (this keeps the bass and ohms high so you will get a clean bass to match with mids and high's. Dont set or bridge for a low bass as it will jam out the 6x9 and your music will sound terrible.
so there u have a simple hookup that will work and keep you sounding clean. remember not to raise the volume on the 6X9 too much as you will blow them..
Mar 29, 2011 | Infinity 7540A Car Audio Amplifier
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
In most of the Amplifiers we have only Bass and Treble control (Bass works on 100 HZ and Treble works on 10KHz - approximately). In some Amplifiers we have Mid range control also. What is the frequency...
The frequency of mid range control is about 1KHz. The bass and treble are usually enough to set the tone of sounds and music, and if the customer has high quality speakers connected to the amplifier it is almost unnecessary to modify any tone. In my opinion you are right that x-band equalizer became less important now.
Thank you.
gylacz
I want to know the best setting of microfone system in concert hall for Mridangam., like bass,treble,etc
The drum has usable frequencies and harmonics out to at least 3KHz so plan on 5KHz.
I would use a Shure SM57 and you MIGHT find it necessary to have one at each end since this is a two headed drum. position the mics pointing at the ends or slightly angled but clear of the hands. If you put them off to the side you may not get quite the sound you want. Set the EQ controls to pass all low frequencies and the mid range up to 5 KHz as flat and reduce the highs above 5KHz to avoid some of the brushing noise of the hands.
Note that the room acoustics and your sound system may play a GREAT part in how it sounds.
Jan 21, 2011 | Mid East Mridangam South Indian Tenor
SPL8R Velodyne sub - Same probelm
Go to the Velodyne web site and check the service center locations.
They may have one in your area.
It sounds like the amp may be the problem. That may be all you need to send.
Best bet, Contact Velodyne.
Jun 08, 2009 | Velodyne HGS-10 Subwoofer
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
Bose 901 VI Main / Stereo Speaker Logo
155 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
