Question about Lexmark T644 Laser Printer
WON'T PRINT MESSAGE SAYS CHANGE TRAY 1 TO PLAIN PAPER LETTER
    Problem Solver:
  • 7 Answers
There is a Paper Menu option somewhere in the menus on the op-panel. You need to go to the Paper Type option and change the Paper Type for Tray 1 to plain paper. You can also hit the Select button when you get this message and you will print.
Posted on Mar 01, 2009
  • 393 Answers
SOURCE: printer message apears
change the paper type at the printer to plain letter, or in printer properties from the start menu.
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
SOURCE: Dell 3100cn Printer will not print
I had to actually change the settings in Microsoft Word to resolve this problem.
If you go to page setup > paper source > there should be lists for "first page" and "other pages".
You can set this to "as per printer settings" and hopefully it should work.
childofsai
Posted on Jul 11, 2008
  • 85 Answers
SOURCE: Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Posted on Feb 15, 2009
Gort007
  • 1187 Answers
SOURCE: Everytime we print we get a beeping sound and an
On the paper tray 1, there is a paper size sensor that looks like a whitish triangle. The "legal paper size sensor is stuck in the down position.
If you can't find it, remove all of the paper and you will notice the letter-size sensor. Un-stick the legal sensor and clean the sensor area so it won't stick again.
Posted on Oct 13, 2009
  • 80 Answers
SOURCE: WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN
You have the settinigs on the printer wrong. There are two things you need to do:
1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
Posted on Feb 11, 2010
How do I change the default on my HP P30005dn to Tray 2?
Normal default on HP is tray 2, however if you do not have that tray set for plain paper letter size the printer will default to whichever tray has letter plain paper installed. You should also check your print driver default settings to ensure that tray 2 is set as default tray.
Aug 14, 2014 | HP LaserJet P3005dn Printer
I have a Lexmark T630 printer and every time I go to print it beeps and says change tray 1. How to I get it to not beep while printing?
You will need to change your paper handling.
From the machine, go into the Menu-> then Paper Menu -> Change your paper size and type to your machine settings. Example if tray 1 is letter make sure it's set to letter and plain, then confirm each tray setting for each tray attached to the machine.
Also pull the tray(s) out completely and make sure the guides are set correctly. (The guides move so you can put legal, A4 etc.)
I've come across a lot of machines that the guides are off by a fraction which will prompt your machine to display the message you stated.
Nov 16, 2010 | Lexmark T630 Laser Printer
Printer selects tray1 as default tray. how can this be changed?
Tray 1 by default is set to any size, any type, which means that no matter what you print, it will pull from tray 1. You can change that by setting tray 1 for a specific size and type, such as 8.5" x 11"(Letter) and Plain paper, and then going into the print driver options (Control Panel, Printers & Faxes, right click on the HP 3550 and select Properties) and under the paper input tray, change it to either tray 2 or 3.
Jun 09, 2010 | HP Color Laserjet 3550 Printer
Get the error message change tray to plain letter
Most probably the paper tray guide is not set properly. Here's a link to the Lexmark website to guide you on what to do when having an error like this. Just click on this link: http://bit.ly/c4AO17 . You can move the paper tray guide back and forth and setting it to the correct size.
Apr 08, 2010 | Lexmark Optra T610 Laser Printer
Everytime we print we get a beeping sound and an error message that says Change Tray 1 Plain Letter. If we press select, it will print
In the printer setup menu. You need to change the paper type for tray 1. It's likely set to a different type of paper (maybe card stock?).
The printer driver will specify what type of paper is being used, and the printer doesn't know what type of paper is in it other than what it is told, so a conflict occurs.
Oct 13, 2009 | Dell M5200n Laser Printer
Won't print
The printer is giving that message as the print job sent to the printer is asking for the correct paper type. Check the program you used and its print setup in that program to make sure the correct paper is selected. Software overrides hardware settings on a printer.Another thing is double check the tray position tab and make sure it is set to letter and locked in that position. If the paper tray is not set it can also think that the paper in the tray is a different paper size.
Bruce
Jul 15, 2009 | Dell M5200n Laser Printer
Printer message apears "change tray 1 plain letter" when i press print. will not print until i press select. Ive tried changing printer setting and cant seem to fix it..
Jun 25, 2009 | Office Equipment & Supplies
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
Jul 03, 2008 | Lexmark T640 Laser Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Lexmark T644 Laser Printer Logo
683 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
