Question about Kodak EasyShare DX6490 Digital Camera
Pictures with halos
I have a Kodak DX6490. When it was new, it took wonderful pictures. Now it will automatically place a light spot in every picture taken. I have tried different SD cards - thinking that they were damaged - but it didn't help. I can't find anything loose or damaged but it continues to take poor pictures. Help.
  • 1 more comment
  • mwhic857 Feb 22, 2009
    I have tried to clean the lens without any success. I still get a ray of light in the picture, or a washed-out look - typically in the upper left hand quadrant. Is there a way to open the lens to clean it inside? Or is there something else going on?
    I cleaned the lens with no change in the picture; unless there is a way to clean the inside of the lens...I don't know how to do that.
    How do I remove the lens to clean inside?
  • Kodak Master
  • 19,396 Answers
The light spot is not a matter of settings.
To reset settings you can go to camera menu and select reset to factory, but that will not solve the problem.
The SD card also has nothing to do with this kind of problem, when SD card is defective camera does not store file at all.
A white spot, or abnormal light areas, or a washed-out lookare unmistakenly symptom of water and humidity trapped inside the lens.
This can only be repaired drying out the inside of the lens assembly, and to do that you need to take apart the camera.
Taking apart a camera is a job that must be done by a qualified technician, unless you want to risk badly damaging the camera.
If you want to know the cost of the repair you can contact the website below:
Advance Camera
Posted on Feb 22, 2009
    Sergeant:
  • 326 Answers
  • To keep from damaging your camera, do not open the memory card door, battery door, or skylight filter while in harsh environments such as rain, sea air, or windstorms. The seals in these areas prevent exposure to moisture and dirt which can damage your camera.
  • Always follow basic safety precautions, refer to the "Important Safety Instructions" booklet packed with your camera.
  • Clean the outside of the camera by wiping with a clean, dry cloth. Never use harsh or abrasive cleaners or organic solvents on the camera or any of its parts.
  • Do not allow any chemicals, such as suntan lotion to come into contact with the painted surface of the camera.
  • Never disassemble or touch the inside of the camera. This could result in electrical shock.
  • If you notice smoke or a strange smell coming from the camera, immediately turn off the camera, wait a few minutes until the camera cools, and then remove the batteries. Contact your Technical Support Center.
  • If you need to remove the lens filter cover, first clean the outside of the camera to prevent getting any dirt, moisture, or dust on the interior lens. Once the cover is removed, do not touch the interior lens. If necessary, clean the interior lens with the appropriate cleaning accessory, such as a KODAK lens pen accessory.
    • When replacing the lens filter cover, be sure that the gaskets are clean and that the cover is tightly secured.
    • Clean the lens filter cover and back LCD screen:Do not use cleaning solutions unless they are designed specifically for camera lenses. Do not wipe the camera lens or LCD screen with chemically treated eyeglass lens tissue as it may scratch the lens.
      1. Blow gently on the lens or LCD screen to remove dust and dirt.
      2. Moisten the lens or LCD screen by breathing lightly on it.
      3. Wipe the lens or LCD screen gently with a soft, lint-free cloth or an untreated lens-cleaning tissue.
      for diagrams and pictures click this link .model is different but the system is same  http://www.kodak.com/global/en/service/digCam/dc5000/ownerManual/ch114.shtml
    Brigadier General:
  • 5,158 Answers
It sounds like you have used alcohol or some other harsh solution on the lens and removed the special coating that was there.
  • 257 Answers
Hi, You say light spots but the heading says halos. Halos are cause by light leaking in around the lens but light spots are a different problem. Are the spots in the same place on every picture? I would start by going to the menu and resetting the camera to the factory defaults. Good Luck!
Posted on Feb 19, 2009
  • 10,594 Answers
There is some dust particles on lens or inside lens assembly and CCD Imager should also be cleaned.
  • Shahid Electronics
    Shahid Electronics Feb 23, 2009
    Better to take camera to Kodak Service Center for proper fix. Lens opening and fixing is quite technical job and qualified camera tech will do it in correct way.
    Thanks.
    Brigadier General:
  • 8,619 Answers
Hi!
Please check for any dirt inside the camera lense. Also check for loose lens.
    Sergeant:
  • 250 Answers
For mat the camera and check out.also check out the battery.it can also be the dust on the lens clean it and check out.
    Sergeant:
  • 219 Answers
Sounds like the lens is smudged. Try using some cleaner fluid on a cotton cloth (such as an old T-Shirt that is 100% cotton) and gently wiping the lens with it.
I need help taking pictures with my DX6490 kodak camera. It does take clear pictures in a gym or auditorium when I need to use the zoom.
What is most important is that unless there is a slave flash or a more flash the subject might look quite blurred in the distance . You might need a SLR with a wide angle to get such pictures perfectly. Try to light up the area when it is indoor and see the result.
Dec 30, 2011 | Kodak EasyShare M530 Digital Camera
Firmware Update Could my Kodak DX6490 camera a while back for taking pictures very sharp and not now. could you tell me if there is any diagnostic utility?
Hello Joan, There are no diagnostic utilities available to the consumer for the DX6490. It sounds like the drive unit for the lens has worn over time. Not a cheap repair, Sorry.
Best Regards, Russell
Apr 05, 2010 | Kodak EasyShare DX6490 Digital Camera
Kodak easyshare dx6490 jpeg problem: Jpeg format corrupted
a jpeg is not a standard photo file. You want to set it for jpg. Take the USB hub out of the connection. Connect the camera or card reader directly to the USB port.
Jul 30, 2009 | Kodak EasyShare DX6490 Digital Camera
I turn on my camera to take a picture and the light will not lite
Hello, Your Dx6490 uses a SD Memory card so all you need to do is buy a small memory card reader and hook it to your PC with the USB cable that comes with it.These units are real cheap.
Good Luck And Best Regards, Russell
May 31, 2009 | Kodak EasyShare DX6490 Digital Camera
Cannot 'review' pictures on the Kodak EasyShare DX6490
press the EVF/LCD button in top left corner of camera
May 05, 2009 | Kodak EasyShare DX6490 Digital Camera
Can no longer update load pictures from camera or
Hello, Sounds like typical Microsoft Windows Registry Problems, Uninstall the Kodak Software Package and reinstall it. This should correct the issue.
May 03, 2009 | Kodak EasyShare DX6490 Digital Camera
Kodak dx6490 won't download pictures
Hello Billy, Sounds like a Windows OS problem, have you tried rebooting the PC ? You may have to uninstall the kodak software and reinstall it. try plugging the camera in directly to the PC with the usb cable. One of these should solve your problem.
Dec 23, 2008 | Kodak EasyShare DX6490 Digital Camera
Dark Pictures
Hello Cowgirl, It sounds like the camera settings have been changed in the menu.Check to see if all control items are set to "AUTO"
This should take care of problem.The camera did not go bad not being used.
Dec 19, 2008 | Kodak EasyShare DX6490 Digital Camera
Spots of faded color in my pictures
Hello Kathy, The problem Sounds like a faulty CCD unit, The only other reason would be scratches on the lens that you would be able to see.
Either way it will be quite costly on a DX6490 camera. you may be better off selling yours for parts and buying another DX6490 in good working order so you can still use your accessories such as,battery,charger,memory card etc.I have several nice ones for sale.
Hope this helps,
Best Regards,Russell hounddogellie@gmail.com
Jun 15, 2008 | Kodak EasyShare DX6490 Digital Camera
Preview Picture - Locked Up
Eventually, the camera's battery will die. I suggest removing the battery and then wait for 30 seconds and put it back in. This should solve the problem.
Feb 29, 2008 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
