Question about Dell PowerEdge 1400 ( pe1400/210 ) Server
Dell PowerEdge 1400SC Can not locate hard drives or partition
I am trying to reinstall the operating system on a Dell PowerEdge 1400SC, however once the windows set up starts It alerts me that no partion or hard drives can be found. There are 3 hard drives on this system and I do not think the problem is with the hard drives.
Any ideas as to why the server would not recognize the hard drives on install?
You need to download Dell's Storage Managment ISO file, create a CD, boot the system with this CD and set up the array. This will also give you the option to install the O/S with no user input.
Posted on Jul 16, 2010
  • 489 Answers
The controller (probably a RAID controller) that the drives are connected to is one for which Windows does not have the correct drivers. You need to supply the proper driver and .INF files during the initial load. The process used depends on the version of Windows you are installing.
Posted on Mar 19, 2009
PowerEdge 2900 not detecting 2 sata hard drives installed
If you have only One Drive the computer is telling you that the One Drive has "TWO" partitions. The main partition has the OS and Programs, and the 2nd partition is for reserve/OS backup data.
Jan 02, 2014 | Dell Computers & Internet
How do you make the ide drive primary in the poweredge 1400sc
Master can be single drive on one IDE channel. Or, one master and one slave on a single IDE channel. From there you have the option of expanding over to the secondary IDE channel. Hope this helps.
Feb 13, 2013 | Dell PowerEdge 1400...
When I start my poweredge 1300 it gives option for utility mode but when I try to enter it says there is no space on my hard drive for the utility mode. what can I do to restore utility mode so that I can...
> what can I do to ... partition my hard-drive?
There is both "commericial" and "free" software that boots from a CD-R that can be used to do disk-partitioning and disk-formatting.
Search for "Partition Magic" or "Ranish Partition Manager".
Aug 28, 2010 | Dell PowerEdge 1300 Server
Hi my computer dell gx280 didn't work. It keep show "no boot device available". i try to replace with new hard drive but it still show same thing. Can you help me figure out what is problem with it please?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Try the above solution and let me know how you get on?
Jul 04, 2010 | Dell OptiPlex GX280 PC Desktop
Reinstall
As long as you have proof of purchase/paperwork......
Call Dell Customer Service.
Or E-mail them.....all info can be found on:
Dell.com!
You may be able to Download them....
Also Check your Poweredge Manuals......
Sometimes Dell is famous for having Everything backed up on a protected partition on the Hard Drive.......So a simple keyboard command (it might be "Ctrl+F11", not sure) at the bios boot screen can sometimes load the computer Back to it's original status.......
Also There's a better way if you don't mind ignoring all the CRAPPY software that comes preloaded with your operating system.......
Or, EVEN BETTER IDEA..........
Buy a New Copy of WINDOWS (I recommend XP PRO! since Windows 7 won't be released til around September this year......then upgrade to that.......SKIP VISTA......7 is way better, I would know!)
When You boot from the Disc, (True Windows XP OS Disk) you can delete ALL THE PARTITIONS and install a FRESH NEW WINDOWS INSTALLATION..........that's the best solution, in my opinion.........but call dell.......do both of these things!
Apr 19, 2009 | Dell PowerEdge 2600 Server
NO BOOT SECTOR ON HARD DRIVE
Afraid you are going to have to get ahold of a copy of the Dell operating system. Once you get that loaded, you can go to www.dell.com to download/install all of the device drivers.
You can actually use any retail operating system version, does not have to be dell. It is only that the dell copy is less expensive. You might try getting that on Craigs List or Ebay.
Good Luck
Mar 17, 2009 | Dell Latitude D600 Notebook
Dell media direct won't work
Here is the steps,
1.Turn on your computer.
2.Insert the reinstallation media (Dell Media Direct CD/DVD) into the CD/DVD drive, then restart the computer.
3. press F12 when the bios page comes up and then select CD/DVD drive from the boot menu.
"Option 1" from the menu if you wish to use all of the hard drive for you operating system installation. This is the most common selection and how is your computer was originally shipped to you, unless you specified an operating system partition size at the time you ordered you computer.
"Option 2" to designate a size for your operating system and have a data partition. This allows you to specify a size for the operating system partittion, leaving the remainder, of the hard drive configured as a "data" partition ("D")
4. Once you have prepared the drive and you have returned to the main recovery menu, remove the installation media and replace it with you operating system reinstallation media. Select the option to reboot your computer. If your computer does not automatically start the media, press <F12> to access the boot menu and select the Cd/DVD boot option.
5.Install your operating system, select the Primary partition when prompted. If you have two hard drives, select the primary partition on the same disk where hte media direct partition resides. Once the OS is installed and the necessary drivers are installed you can begin the reinstallation of the dell mediaDirect software.
Good Luck,
Austin
Feb 12, 2009 | IBM ThinkPad T30 2366 Notebook
Replace hard drive of my server, now, is not going to startprog m
Call Dell for the best answer. Support is free forever.
If you are out of warranty you will pay for parts.
Dec 23, 2008 | Dell PowerEdge 1400...
My operating system will not load
Try removing all of the hdds or just leave one that you think it works. See what happens.
Nov 07, 2007 | Dell PowerEdge 2500 Server
Computers & Internet Logo
391 people viewed this question
Alun Cox
