Question about RCA RS2664 Shelf System
Rca 5cd changer tray
Hello I have a problem with my RCA stereo system the cd player tray will not go back in it those a sound like is attempting to close but it won't I even tried pushing tray in but no luck it won't close what should I do to correct this problem....Thank you...
  • 28 Answers
First basic step if u still haven't tried this yet is to turn the power button off then unplug the appliance then plug it again and turn the on the power button for the compact disc unit to initialized its program on its CPU and memory devices.
second step: if you can manage to open u'r mini component, check the mechanical moving parts of cd rack if there's any broken parts or missing parts.
third; if you still have the remote control try using it.
4rth; don't forcibly close it manually it will just worsen the problem. hope this tips help ;-)
Posted on May 24, 2009
RCA RS2612 Digital CD system malfunction will not play CDs
The changer is fubar and repair is not cost effective.
Sep 16, 2017 | RCA RS2656 Shelf System
My rca rs 2657 cd changer is stuck. door will not open. any ideas how to correct?
If you hit the open button and you hear a sound like a motor running than it is most likely a belt or connection that physically opens the tray. You'll have to take it apart, locate the cd player and check from there. If no sound of a motor running when the button is pushed then the motor is probably bad.
Oct 17, 2009 | RCA 100-Watt Stereo System With 5-CD...
RCA RS2025 Bookshelf Stereo CD Player Hangs Up
Ok,
Look for a reset button at the back or may be at the front head of the cd changer.It is a very small 1mm hole.If you find it insert a paperclip in it,press and hold it for 1 min.This will reset the unit.If you still face the problem then just unplug all the cords of the changer for 1 hour and then plug it back in.
Sep 03, 2008 | Audio Players & Recorders
5 CD Changer won't work
my rca 5 cd changer skips on all cd's?
Jun 26, 2008 | RCA 100-Watt Stereo System With 5-CD...
Buzzing sound and can't open stereo
Again RCA stereos **** for this factor, cheap transformers, replace the transformer and see if that helps as it seems to be the most problem with most RCA systems I've repaired in the past.
May 09, 2008 | RCA RS2656 Shelf System
RS 2653
I had a rca system similar to this little different. It's a problem you'll find in any cd player after awhile. You'll need to replace the laser. It's quite easy google for some instructions to replace a cd laser. Look around for a laser that can read cd's and cd r and cd rw and you'll be ok. The disassembling might be a bit tuff but it's worth it. I had to replace my hifi laser and after i did sound was incredible again no skipping. Make sure when opening your system you power it on and unplug it to make sure all charge is gone wait 30 minutes or so before you go and operate.
Feb 10, 2008 | RCA 100-Watt Stereo System With 5-CD...
RCA RS2664 Shelf System Logo
376 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
