Question about Canon Office Equipment & Supplies
Canon IR 210N Network Configuration
I'm sure this is simple, but can someone tell me how to change the network settings (IP address, netmask, gateway, and dns) for Canon IR 210N?
Thanks in advance for your help!
You need to turn off the copier, wait a few seconds, then turn it back on. Make sure to select the Printer I/F button and press the setup button on the touchscreen when it comes up. Voila! Network settings.
Now, I can't get it to actually work, but that's a different problem.
Posted on May 10, 2010
I have the same problem. Cannot access the network settings screen. When I press the INFO button in the print screen the screen just flickers for a moment but doesn't do anything. Printing the settings reveals the machine is set to appletalk and the web config console is turned off so I'm kinda stuck.
Posted on Jan 21, 2010
Find network settings on the copier by going to the information button.
Posted on Dec 30, 2009
How to configure the printer on network printing
Print a configuration page. Look for the IP address under Network. Type that IP address in your web browser address and press enter. That should bring you to the printers internal web server settings.
Jan 22, 2014 | Canon iR 2022 Printer
DHCP Server configuration in Linux
Linux is a UNIX based operating system. It is a server operating system. REDHAT Linux is Enterprise version of Linux. Now a day's Most of corporate sectors use red hat Linux as server in their company because it is secure very much.
Full form of DHCP "Dynamic Host Configuration Protocol. DHCP server assigns IP addresses and other network configuration information like subnet mask, broadcast address, etc to computers on a network. The DHCP assignments are the following.
Lease Request: Client broadcasts their request to DHCP server with a source address of and a destination address of
IP lease offer: DHCP server replies with an IP address, subnet mask, network gateway, name of the domain, name servers, duration of the lease and the IP address of the DHCP server.
Lease Selection: Client receives offer and broadcasts to al DHCP servers that will accept given offer so that other DHCP server need not make an offer.
The DHCP server then sends an ack to the client. The client is configured to use TCP/IP. Lease Renewal: When half of the lease time has expired, the client will issue a new request to the DHCP server.
Installation of DHCP server: First of all while install the RedHat Linux enterprise version server be careful about the ports and the services must be turned on. To create DHCP server in Linux first download DHCP RPM package and install with "rpm-ivh" command. Where I have done it there I have create YUM server, so easily I have download and install it by YUM (yum install dhcp version). DHCP package will locate in /usr/share/doc/at Linux file system. I copied the DHCP's files from /usr/share/doc/ to /etc/dhcpd.conf.. Then I started to configure the dhcpd.conf file to route the DHCP server in there local network. I have open the configuration file with "vi" command. Then commented out the lines from "default gateway to option netbios" because system don't read the commented lines. After that I set the range of IP address in dynamic- bootp of their local assumption of system. I have change the "next-server" with the dhcp server name and have also change the fixed address with the dhcp server IP address (end range of dynamic IP). It is very easy job to configure DHCP server. After configure the .conf file of dhcp just turn on the service with "chkconfig" command and restart the dhcp service. After that entire job I reboot the system. And after rebooting of server I turned on the other client system. While startup the client system without static IP address all of those picked up IP from dhcp server and going on successfully. I have prefer the command line mode to do the total job.
The DHCP server configure file is following:
ddns-update-style interim
ignore client-updates
subnet netmask {
# The range of IP addresses the server
# will issue to DHCP enabled PC clients
# booting up on the network
# Set the amount of time in seconds that
# a client may keep the IP address
default-lease-time 86400;
max-lease-time 86400;
# Set the default gateway to be used by
# the PC clients
option routers;
# Don't forward DHCP requests from this
# NIC interface to any other NIC
# interfaces
option ip-forwarding off;
# Set the broadcast address and subnet mask
# to be used by the DHCP clients
option broadcast-address;
option subnet-mask;
# Set the NTP server to be used by the
# DHCP clients
option ntp-servers;
# Set the DNS server to be used by the
# DHCP clients
option domain-name-servers;
# If you specify a WINS server for your Windows clients,
# you need to include the following option in the dhcpd.conf file:
option netbios-name-servers;
# You can also assign specific IP addresses based on the clients'
# ethernet MAC address as follows (Host's name is "laser-printer":
host laser-printer {
hardware ethernet 08:00:2b:4c:59:23;
# List an unused interface here
subnet netmask {
on Mar 17, 2011 | Computers & Internet
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address
Console(config-if)# exit
Console(config)# ip default-gateway
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
How to install broadband to android tablet pc?
Share 01 Feb
2011 How to configure IP address of wi-fi connection on a Android Phone (Samsung Galaxy Tab) Posted in: Gadgets Tagged Under: Android, Galaxy, Samsung, Tab 7 Comments samsung_galaxy_tab-small-1.png
By default Androids phones (including Samsung Galaxy Tab) are set to automatically configure IP address, Gateway, Netmask and DNS address of wi-fi network.
But if you want to manually assign IP address, Gateway, Netmask and DNS address of wi-fi, here is how you can do. Method below is described for Samsung Galaxy Tab, but it will work for all Android phones.
  1. On Home screen, press Menu key.
  2. Tap Settings
  3. Tap Wireless and network.
  4. Tap Wi-Fi Settings.
  5. Press Menu key again.
  6. Tap Advanced.
  7. Enable "Use Static IP".
After you have enabled "Use Static IP", you will be able to manually assign and configure IP address, Gateway, Netmask and DNS address of wi-fi network.
Sep 23, 2011 | Android Apps
Need to install ir 5020 onto server. Do I need any config software first like HP JetDirect?
You would need to ensure that the IR 5020 has a valid IP address (Should be located on the Network Configuration Menu from the on-screen display). When plugged into the network for the first time the printer is usually given an IP address, this would allow you to connect to the web management interface and make changes to the settings from an easier interface than the on-screen display.
If you are planning on sharing the IR 5020 out from the server to other computers then you would then need to assign a static IP address to the IR 5020 so that the IP address would not change once configured.
(Side-note - I do not recommend using DHCP on printers as it can cause issues down the road if the printer is given a defferent IP address by the DHCP server.)
Sep 13, 2011 | Canon imageRUNNER 5020 Copier
Canon IR 1023if; trying to network with buffalo router and two laptops and a wireless desktop. subnet mask default gateway is laptopA laptopB desktop ...
Did you change the coper to static IP? If not then the copier is most likely still set for a dynamic IP. A dynamic IP means the number will change from time to time when the IP lease from the router runs out. Your computers are most likely set for dynamic also. This is not a problem and the use of dynamic IP's is very common.
If you print out a status page (also know as a configuration page) from copier/printer there should be a Host name listed along with the IP address. The host name is a name that always stays assigned to the network card (providing you don't manual change it). If you substitute the host name for the IP address when you are setting up the printer port the computer will always look for that name on the network when you send a print job.
The IP address and host name are both ways to find the proper device you are looking for on a network. Think of them the same way as a phone number. You dial your friends cell phone and it goes out over the cellular network looking for your friends cell phone once it finds your friends cell phone his phone rings. IP's and Host names work the same way.
Let me know if you need anymore assistance. If needed I can log in remotely and give you a hand.
Jan 28, 2011 | Canon imageRUNNER 1023iF Black and White...
Imagerunner 210S. I have a network card in this used printer but my computer does not see it. How do I install this printer on my home network? Is there an adapter to plug into the ethernet jack to...
  1. You need to set a Static IP address in the printer:
  2. Press the "Additional Functions" key on the Canon Imagerunner 210N keypad.
  3. Tap "System Settings" and enter your administrative ID number and passcode if prompted.
  4. Tap the "Network Settings" button and tap the button next to "TCP/IP Settings."
  5. Press the "IP Settings" button.
  6. Highlight "IP Address" and use the keypad to enter the IP address you want to assign to your Canon Imagerunner 210N.
  7. Fill in the "Subnet Mask" and "Gateway Address" fields with the appropriate information.
  8. Press the "OK" button to save the network settings and enable the new IP address.
Read more: How to Set the IP Address on Canon Imagerunner 210 N ' Then install the driver and poit them to the IP address.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 30, 2010 | Computers & Internet
I have a zebra 2844 Printer and we just recently changed the VLan so the Printer IP changed. Looking for a way to verify that the printer has the IP address assigned to it on the printer that I set up via...
you be able to see the net configuration wen connect first to a network, first plug-in to one network, then if you go through the settings, you be able to see IP, NETMASK and GATEWAY and change.
Nov 18, 2010 | Zebra 203DPI Printer
I have ubuntu 9.10.Plesae how to install ip address of my ethernet controller.
Go to System>Preferences>Network Connections. This will bring up the configuration window. You'll notice several tabs at the top. Make sure you are on the correct one (Probably wired). Then you will will see "Auto Ethernet." Click on it and then click "Edit" which will bring up another window. Then click the tab labeled "IPv4 Settings." Then under the "Method" drop down, you'll have to select "Manual." Then you can click "Add" to add an IP address and enter it with the Netmask and Gateway accordingly. To get everything to work properly, you'll need the IP, Netmask, Gateway, and at least 1 DNS server. entered here.
Mar 10, 2010 | Canonical Ltd. Ubuntu
How can I reset it back to original configration
Hey Eric, I do use same Avaya switch at my lab at office. To me what you have to do is quite simple, first of all you have to get from your network administrator the following info: - Free IP to assign to the switch - Subnet - Gateway (If you ping such IP from a machine of same subnet, there will not be an answer). Then log as superuser (#) and do this: 1. Type set interface inband Replacing , and with the VLAN, IP address and netmask provided by your network administrator and press Enter. (for VLAN you can list them and decide which one to use, but normally you should use 1) 2. Type reset and press Enter to reset the stack. 3. After the Reset, perform login again as superuser.  4. Type set ip route , replacing and with the destination and gateway IP addresses. (If you want all packets not from your subnet to be send to the gateway, then use as destination, list routes set on device for more info) 5. Press Enter to save the destination and gateway IP addresses. That's all. Your switch will be rechable from your same subnet and from other networks if your gateway is working properly and there's no other element blocking you the access. Good Luck!
Oct 23, 2006 | Lucent Cajun P333T Networking Switch
Open Questions:
804 people viewed this question
old marine
old marine
