Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Wahers do not pump the wateer out
It look like the pump unit is no getting any corrent o voltage
need schematic to trace this
Thank you for help
  • Anonymous Feb 24, 2009
    do no have 120 volts to moter
  • 70 Answers
Remove the front panel of the washer and take the molex plug off the elec pump. turn timer dail to "spin" and see if you have 120V to the pump. If you do and it will not turn on, you need to replace it.
Here is a link to the diagram:
http://www.etribles.com/Home.asp?PageID=117&ItemID=0&SessionID=07C9CFC71C2545D8AA8D002C0082E6D2
Posted on Feb 19, 2009
Electrolux fridge freezer wateer dispensing unit does not work
It is a water pump problem .Follow the water line behind your fridge and you will find it .Its a small pump so just replaced it and you should be fine
May 26, 2017 | Electrolux Refrigerators
It does not turn on. What and where to look to find problem and fix?
Most obvious thing is to make sure that the unit is receiving power from the socket. If so try to get a schematic to trace how the electricity is distributed to the machine and track the voltage down with a VOM until you come across the obstacle
The attached site is great for showing parts schematics; often it gives electrical schematics also. Check them out - nothing to lose. Search Over 2 1 Million Appliance Parts
Sep 21, 2015 | Washing Machines
No corrent to computer and injector pump solenoid
fuel pressure sensor working? theres a reason computer isnt sending the message fuel pump working? connect to a scan tool and see what codes you get, many part stores will let you borrow one
check all the fuses with a continuity meter especially fuel pump, auxillary fuel pump, fuel presure regulator, mass air sensor, ect
Jan 04, 2015 | Cars & Trucks
Fuel pump wiring not getting power
You need to buy or borrow a voltohm meter and check fuses for voltage and trace the voltage to the fuel pump.
Mar 29, 2014 | 1991 Toyota Camry
I have a power supply of an LCD monitor. The model is PI-170DTLA and I want turn on the backlight lights without using the motherboard. How do this? What is the pin? What voltage i need? How control the...
You'll have to power the HV converter board of backlight from an independent power supply with the same voltage and corrent capacity than the motherboard provides, you can use a multitester to get these values or maybe thre's a sticker on motherboard providing this data, use the connector from motherboard to HV converter board to get the pinout, the brightness control can be get varying the provided HV to backlight. If you can get service manual or the circuit schematic of monitor will be helpful for your purposes.
Mar 05, 2011 | Proview Televison & Video
93 flhs. evo, bike just quit running. no spark at plugs, put in new plugs,wires and coil. still no spark. i have a crane H1-4 in timing cone. is that my problem. would like to be sure that is problem...
If your bike has been converted to a Crane ignition, all you have is the Crane unit, two spark plugs, two wires, and a coil. Seems you've replaced everything else so the unit is all that is left.
Now, before you replace the unit, you see there are two wires on the hot side of the coil. Make sure you have battery voltage to that side of the coil. A test, take your plugs out and lay one on the engine where you can see it. Turn your ignition switch on, then turn it off. You should see a single spark when you turn the switch off. If so, you're electrical wiring and coil are alright. Your unit is bad. If you don't get a spark, you are not getting voltage to the coil for some reason.
If you are not getting power to the coil, make sure the "Run/STOP" switch is in the right position. If it is, you'll need a schematic to trace the voltage back to the source. I have a schematic for a FXDWG. If you want a copy, send me a personal e-mail at wd4ity@bellsouth.net and I'll send one to you. This forum will not allow for a file over 150Kb. Remind me of what you need.
Good Luck
steve
Nov 07, 2010 | Harley Davidson FLHT Electra Glide...
Goodman PC060-1B Package AC...Need Wiring Help
Depending on the size of your Electric heat you can use one set of wires because your unit does not run with the heat like the heat pump. The large set of wires going to the electric heat should be used. You may have to jumper a new set to the contactor. On Goodman unit come in L1 and L2 jumper to contactor. Very simple good luck. Rus
Jun 21, 2009 | Goodman Heating & Cooling
Altec Lansing ADA995 does not work
This is my Dell Altec Lansing 5.1 (ADA995) surround sound amplifier for my computer. There is a design flaw where the board gets corroded due to the fact they caulked or glued it togther and left some of the circuit board hanging out. Just thought I would point out my findings in case some of you had the same system. It's a relatively easy fix. I got all the parts from Newark for about $30.00, and it took roughly 2 hours. Original Amplifier Chips below:
Positive Voltage Regulator is blown out:
Notice the traces where corrosion caused a short:
Another view of the burnt traces:
The glue or caulk ran straight across here:
This resistor was blown out.
I pulled it out before I took the picture I went ahead and replaced all of the 4.7 ohm 1/4 watt resistors:8_18_2012_3_31_59_am.jpg
Blown out 4.7ohm 1/4 watt resistor:8_18_2012_3_32_37_am.jpg
Just before surgery on the amp chips:
Re-jumpered the traces:8_18_2012_3_35_55_am.jpg
Re-jumpered the traces:8_18_2012_3_36_44_am.jpg
New amp chips are in! Boy that "Heat Sink Transfer Paste" is really messy!!!:8_18_2012_3_37_26_am.jpg
A peek at the underside:8_18_2012_3_38_11_am.jpg
New L7815CV Positive Voltage Regulator (Shown here):
New L7915CV Negative Voltage Regulator is on the back side:8_18_2012_3_39_35_am.jpg
New amp chips are all nestled down in their new home!:
Boy that's a big heat-sink:
Time to try it out. And it works. Boy, going a week with out 5.1 audio on your computer is terrible! Nobody should have to live that way or be subjected to that kind of torture. I guess this would be considered a "first world problem"!
-Jason-
Aug 20, 2008 | Altec Lansing ADA995 Speaker
Looking for a schematic so i can trace the power
GO TO THE FCC WEBSITE:
https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm?calledFromFrame=N
ENTER THE FCC ID # YOU MUST ENTER IT CORRECTLY.
FOR INSTANCE...MY FCC ID # IS G9H3-5810 ENTERD CORRECTLY WOULD BE ON THE FIRST LINE
G9H AND THE NEXT LINE 3-5810.
TRY THIS FIRST UNTIL YOU GET USE TO IT AN IT WILL BRING UP ANOTHER MENU. UNDER DISPLAY EXHIBIT CLICK ON DETAIL
THEIR YOU WILL SEE BLOC DIAGRAMS,SCHEMATICS ETC. HOWEVER NOT EVERY RADIO WILL DISPLAY THIS,IF THE COMPANY PAYS EXTRA $ TO THE FCC CERTIAN THINGS WILL NOT BE DISPLAYED LIKE SCHEMATICS.
THERE IS A WAY AROUND THIS ALSO, THE US PATENT OFFICE. TYPE IN THE PANTENT NUMBER AND EVERYTHING WILL BE DISPLAYED, IF YOU CAN FIND THE PATENT ID #.
HOPED THIS HELPED
KEVIN
Dec 09, 2007 | Cobra FRS 307 (14 Channels) 2-Way Radio
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
106 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
