Are there any boxes that don't require 'autoscan' for setup?
Looking for a converter that doesn't require a scan or rescan to receive channels.
Have amplified rooftop antennas that I turn to receive multiple stations in opposite directions; the magnavox TB100MW9 requires a rescan whenever the antenna is turned. Current channels in memory are erased and then replaced with new ones---- which has turned out to be completely hit-and miss...mostly miss.
The magnavox won't allow any other channels to be added after it autoscans(channels CAN be added to the list but no reception is possible on these channels) The manual implies channels can be added manually, but apparently not so...
Have tried disconnecting antenna, running autoscan, then reconnecting antenna-----result was that ALL channels were being locked out with no reception possible even on local digital stations......
Thanx for any help!
How to connect a motorola DCH3416 to a computer?
Posted on Feb 20, 2009
Alba set top digital freeview box
normally its - press menu - install - scan for channels and then save
something similar to this
hope it helps davetech
Aug 08, 2014 | Alba DVBT set top box
SDTV CONVERTER BOX BLACK SCREEN MENU WONT COME UP
Maybe pressing the SETUP button the remote will get results.
Nov 28, 2013 | Magnavox TB110MW9
HOW DO I AUTO SCAN CHANNELS ON VIEWSONIC VY2430
Do you mean the VT2430? Viewsonic doesn't list a VY2430.
For my Viewsonic TV, first make sure that your input is TV. (Press the Input button on the remote (upper left) or the TV (furthest right). Use the arrow keys or multiple presses of Input to change the current input.) Next press Menu. Use the up/down arrows to navigate to the TV menu (the icon looks like a TV). Press Enter. Set the type of incoming TV signal (Cable or Air or let the tv figure it out with Auto). Then go down to the line labeled AutoScan and press Enter. You may be prompted to begin the scan or to select the type of channels to scan. Press Enter again after making the selection.
Viewsonic has the manual for the VT2430 available on their site: http://www.viewsonic.com/products/vt2430.htm#tabbox_downloads . The direct link is http://www.viewsonic.com/assets/041/11502.pdf .
I hope this helps.
Sep 02, 2011 | ViewSonic NextVision HD12 HDTV DTV...
I am in Los Angeles,Ca. Converter box signal problem
Just go to walmart and buy a good digital antena.Should work great.Just rescan all ur channels again.
Mar 11, 2010 | Digi Sansonic FT-300A tal To Analog TV...
Can't get abc2, abc3, etc. we have a digital set top box. how can we get it to show the chanells?
My set-top box has an 'autoscan' function in the channel menu under setup. Try that to see if it will be able to find the missing channels. Here, some time after the initial changeover to digital, they changed some of the channels, and a new scan was necessary to get all again.
Jan 03, 2010 | Televison & Video
My set top box will no longer pick up certain channels such as itv and channel 4 stations !!
My set top box has setup menu, channels, autoscan to scan for channels. They changed some of the channels here after the original switch to digital, and a fresh autoscan was needed to again find the channels that moved. See if your box has autoscan for channels, and do it.
Dec 28, 2009 | Televison & Video
My pacific freeview box isnt picking up any channels
U have an out door antena?Rescan channels in the menu?Buy a digital antena get better signal,but still must rescan channels to get every channels.
Oct 22, 2009 | Televison & Video
Unable to rescan channels AWA STB 262 set top box.Need to scan for lates channels. Menu button not working. AWA HD Digital Terrestrial Receiver Model STB 262
These STB262 box remotes won't work if they are not hooked up with the 720dpi option (Use HDMI Cable) -
Cheers - compac
Sep 01, 2009 | Televison & Video
Cant get all channels
Instead of doing auto scan the should be a option for channel list or add\delete or manual scan. What kind of tv is it? You don't have a cable box right? If you still have trouble, just comment on this.
Mar 15, 2009 | Televison & Video
No freeview bbc channels
just solved the problem
with the variable attenator fitted i did a rescan still didnt work
but when i did a rescan to the restore factory settings it now works
Nov 24, 2008 | Televison & Video
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
Electro Med Services...
