Question about Dell Dimension 4600 PC Desktop
Starting whole system over
My computer has an incurable virus that will not allow me to get online. i want to reboot the whole system and start over, but i can't find my resource cd. is there any way i can start all over without it and get online? i don't care about permanently erasing everything. i've backed it all up. i used windows xp. i just want to be able to get online again.
  • 6 more comments
  • somebodyelse Feb 19, 2009
    the program doesn't run on my computer. maybe i didn't put it on the cd correctly. don't know if it needed to be formatted.
    maybe i didn't copy the program to the cd correctly. i didn't see a selection for "mbam-setup.exe". i'm not too computer savy. what is the correct pathway for downloading this on a disc?
    when i try to run it on my computer, it seems like it's about to open, but it never does. nothing happens.
    still doesn't work even in safe mode. the origional culprit of this whole mess is a blue and grey box that says "security center alert" and the name is: Spyware.ISpynow. are you familiar with this virus and/or would you know how to remove it.
  • somebodyelse Feb 20, 2009
    do i try the same method of installing spyware doctor as i did the other one. i will try it.
    spyware doctor didn't work either. i have spy emergency on it and i cannot uninstall it for some reason. it saya it doesn't exist. do the backup discs come with windows xp?
  • Peter Steiert
    Peter Steiert May 11, 2010
    Do you have another computer in your house that you could use to format this hard-drive? Just let me know if you have another computer in the house and I'll give you directions on how to remove the infected hard-drive from the current computer and how to insert it into the other computer. No, your other computer won't be infected by sticking the infected hard-drive into your non-infected computer.
  • Peter Steiert
    If you have a Windows Installer Disc lying around I can help you accomplish your task.
  • 447 Answers
Use another PC (or a friend's PC) to download a program called "Malware Bytes" (Google it). Transfer the program to the infected PC by way of a USB drive or CDR and run the scan and clean program. Hopefully this will allow you to access the web afterwards so you can update Malware Bytes to the latest version and do a more thorough scan. Should you need to reinstall Windows you are going to need a OS CD which matches your system's OS (XP Home, XP Pro, etc.) before you will be able to perform the reinstall. You may want to contact the manufacturer to order a recovery disc for your specific machine.
Posted on Feb 19, 2009
  • 6 more comments
  • John Elliott
    John Elliott Feb 19, 2009
    Just to verify...The file you downloaded is called "mbam-setup.exe" and it should be 2.74mb in size.
    If you have written this to a CD you should click Start + Run and then browse to your CD drive (or USB drive if you used a USB) and select the "mbam-setup.exe" file. If the program doesn't run does it give you a reason for not running (or an error message perhaps)?
  • John Elliott
    Right click on the downloaded file (mbam-setup.exe) + Send To + DVDRW or CDRW Drive. Windows will prompt you that there are files waiting to be written to the cd. Follow the instruction prompts.
    If writing to the CD proves to be a challenge you may find it easier to use a USB drive for this operation, it's a simple copy and paste job then...
  • John Elliott
    Let's see if we can do this in safe mode.
    While booting the machine hit the F8 key a few times until you see a boot menu. Choose safe mode as the option for start up. You will need to login as Administrator.
    Once you've started Windows in safe mode try to install Malware Bytes. It may balk at being installed or run in safe mode but that's ok, it works fine in safe mode.
    You won't be able to update the software in safe mode but that's fine, we simply want to do a cursory scan and clean at which point you can restart the machine normally and do your updates and full scan.
  • John Elliott
    John Elliott Feb 20, 2009
    It's one of the myriad of fake security center alert bugs. Malware Bytes is one of the fixes recommended for that nasty but we obviously can't get it installed so we'll have to try something else.
    See if you can download and install Spyware Doctor.
  • John Elliott
    Just a follow up, hopefully you've had some luck cleaning up your PC but if you need to order the backup discs for your unit here is the link. Good luck!
  • John Elliott
    Yes, same method. It would probably be a good idea to check into ordering a recovery disc for your machine just in case you ever hand it down to someone else or sell the unit.Most of the time the cost of the cd is minimal.
  • John Elliott
    Generally the recovery disc will include a complete image of the original installation (Windows included) as well as the drivers for the OS. Boot from the disc and reformat/reinstall. Click on the link I provided within this thread for more info.
  • John Elliott
    John Elliott Mar 02, 2009
    Be sure to post back here once you've sorted things out (or if you have additional questions). Just curious how things turn out.
The acer computer ask for reboot, but it will not go down or up
When your computer won't boot past the title screen or start-up screen, it usually means you have software problems or a virus.
Almost all Acer computers come preinstalled with a Windows operating system, which allows you to troubleshoot the operating system before locking up during the start-up screen.
Whether your problem is hardware or software-related, this technique allows you to access your desktop to retrieve all the items you want from your hard drive before completely reinstalling your operating system.
Click the power button.
Within the first 10 seconds, a BIOS keystroke should pop up.
The keystroke to access the BIOS is usually the "ESC"+"SHIFT" keys.
"F8" is also an option for getting to the BIOS.
After keying the keystrokes, the BIOS screen is displayed.
Navigate through the BIOS system, which is the first system that your computer accesses.
The BIOS contains several commands and options to scroll through to modify various ways to start up your computer or reinstall the entire system.
It contains the booting options of your computer.
Navigate to the desired option with the arrow keys and select "Start in Safe Mode."
Safe mode is an operation your computer can run in which it doesn't use full capacity of your computer's hardware or software, but allows you to navigate to your computer's desktop and hard drive, regardless of an existing virus.
Restart your computer in Safe Mode and wait for it to boot.
After navigating to your desktop, begin dragging and dropping any information you want to save onto an external hard drive or USB thumb drive before the virus corrupts the files.
Instructions for booting your computer in Safe Modehttp://www.columbia.edu/acis/security/articles/data/safemode.html
Apr 21, 2013 | Acer Aspire Computers & Internet
My acer aspire notebook D260 will not start up! it keeps asking me to put cd rom in to reboot. when i press f8 on start up it keeps bleeping and wont let me reboot from there. What can i do now?
It sounds like you might have had a virus that deleted your operating system on the computer. You need a recovery disk that came with your Acer notebook that will allow you to reboot the operating system.
Hope this helps! Please rate my answer :) Thanks!
Jun 12, 2011 | Acer Computers & Internet
I my pc there is a virus and because of that i am not able to install my antivirus
Try online scan from Trend Micro,it will help you to remove virus
http://housecall.trendmicro.com/
Also, try root kit buster. http://www.trendmicro.com/ftp/products/rootkitbuster/RootkitBuster_2.80.1077.zip
Clean up all your temp files
Go to Start->run - > type temp and hit enter
it will open up a folder, delete all files in temp folder
Again, Go to Start->run - > type %temp% and hit enter
After scanning and deleting temp files, restart the system once and try installing again
May 18, 2010 | Panda Antivirus Pro 2009 - 3 User for PC
Computer Freezes when using Skype and the Internet
These are the steps that you need to take, and the instructions on how to do it:
1. Reboot into Safemode
2. Run a virus and spyware scanner
3. Defrag
4. Scandisk
5. Registry error repairing
6.Reboot into regular mode windows
Here is how to do it:
Reboot yor machine while holding the F8 key right as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
Windows will start in safe mode. Run an AVG virus scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and only checkmark the top box 'fix file system errors', then click ok, the computer will then tell you it will scan upon next reboot., Now click the DEFRAG NOW button. the choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to reinstall Windows and see if that works. If reinstalling windows doesn't fix it, it is most likely a hardware problem.
PRINT THESE INSTRUCTIONS AND KEEP A COPY NEAR YOUR SYSTEM FOR FUTURE PROBLEMS. THIS SERIES OF STEPS CAN FIX MANY PROBLEMS
Good luck.
James.
------PLEASE RATE THIS ADVICE WITH 4 THUMBS UP!!!-----
Apr 26, 2010 | Computers & Internet
Slow allowing us to connect to the internet, also in letting us travel through the internet
Hi i'm Rain.
The problem your having is due to a lack of cleanibg.
I will walk you thru the steps to clean your computer.
  • Click Start.
  • Then click All Programs.
  • Now click Accessories
  • Now click on System Tools
  • Then click Disk Cleanup
The Disk Cleanup window will open. You can check all of the boxes and click next.
You computer will now clean its self of unneeded files. Allow this action to complete .
Now that you have done a disk cleanup, let's do a Disk Defrag.
  • Click Start
  • Now click All Programs
  • Then click System tools
  • Finnally click on Disk Defrag
This action will put all files in the correct order and clear needed space for the Hard Drive
Click on Defrag to start.
The next step is to ensure you dont have viruses.
{ Click here } To scan and clean your computer of any viruses.
EST Online Anti virus scan is a Microsoft data base
designed to locate and remove any type of virus.
  • Click on the green EST Online Scanner tab.
  • Except the lisence agreement
  • Click Start
  • Check both boxes because you want a complete scan.
  • Download the needed file { You will be prompt to except a download file. Except the file and install it .
Allow the EST Online Scanner to clean your system of spyware,viruses and more.
I hope this information has been helpful.
Nov 25, 2009 | Dell Dimension 3100 PC Desktop
Once in windows start-up, it automatically reboot again and again and again. what is supposed to be the problem? thanks
Hello
I had the same problem a few months ago, but if it is what think, and not a hardware problem, you should be able to fix it with some virus tools.
I suspect it is the virus called ravmon, it did exactly the same with me, but every couple of tries to start the computer it actually stayed on long enough to install a aplication called combofix, it completely deletes ravmon from computer registry and it works 100%. If the computer does not stay on long enough to install combofix, you must take out your hard driver and put it in another computer as a slave device which has a good antivirus(Bitdefender) and combofix installed on it. Once you have done this, scan your HD. Once cleaned up, put it back and it should work if it is a virus.
Otherwise it can be your CPU which is overheating, where some new thermal paste on CPU will do the trick.
Just google combofix, it is very small and free to download.
Really hope this can help you. Also remeber to please rate sollution
Best Regards
Sep 26, 2009 | Acer Aspire 3000 Notebook
Dell computer while online sign says encountered
Scanned whole computer with the antivirus or antispyware.Sometimes it happen because of virus infection. One of my friend also facing same problem.and after scanning we got almost 70 viruses..Boot from Safe mode and scan.If you still get the same error then try to repair your operating system.
Thanks
Mar 05, 2009 | Dell Dimension 2400 PC Desktop
Fix registry virus
Install updated full version of antivirus like avg 8, avira or avast. It surely removes Viruses from your system. Scan your computer with it. After Scanning, reboot your computer. If your computer won't recognize you D drive due to virus blocking it, so Just copy your antivirus installer to your pen drive. Or, you can download free antivirus from the net. Go to this link www.free-av.com
Dec 27, 2008 | Gateway GT5220 PC Desktop
I have an hp laptop which has a trojan virus and will no alow me to do anything. Do i have to pess alt F10 to start reboot as i do on my sons acer
hopefully you have an anti virus/spyware programme installed, if so keep pressing F8 on boot up to get you into safe mode, this will not allow the trojan to run.
When you get the list on screen choose safe mode, then when windows starts, choose the administrator account, go straight to my computer>properties>system restore tab, and turn off system restore.
Run your anti virus programme and then when the trojan is found and then reboot pc, then turn system restore back on.
Sep 10, 2008 | Computers & Internet
System restarts on its own.
If you have been connected to the internet without the proper virus software or spyware software then you may have contracted a virus or you may have spyware causing your system to automatically reboot. If you do have a virus software remove your computer from the internet after you have updated the virus software. Run the virus software to see if you have any viruses. I suggest then to look in Add/Remove programs and start uninstalling any software that you are not familiar with if the system allows you to do so.
Dec 05, 2007 | Microsoft Windows XP Professional With...
Dell Dimension 4600 PC Desktop Logo
62 people viewed this question
Alun Cox
