Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
I have a red light on my xbox 360 wireless nework and i cant conenct to live
  • 6 more comments
  • handerson52 Feb 21, 2009
    Same thing steady red light on my wireless adapter and can't connect
  • brodz_28 Mar 02, 2009
    I have just had my xbox 360 repaired and when I tried to set it all up, my wireless network adaptor has now got a red light on it and will not let me go on xbox live.
  • Anonymous Mar 17, 2009
    My adapter has the red light on all the time but it still says i can connect to the network but not get online. It fails every test.
  • Rotobracca Apr 02, 2009
    about 8months+ ago I bought a network adaptor for my xbox360, and on the day I tried to get it working it had a red light glowing, it was stubborn as hell..Im pretty sure there isnt a point of buying these things, they are AWFUL like most things microsoft make :@ its really got me annoyed, and now im trying to use it again it wont work, still with a red light, I try to connect to xbox live but it instantly goes and says I cannot connect...I wouldnt have bothered wasting 60 pounds on this if I knew it wouldnt work, now I cant even get my money back..
  • Anonymous Apr 11, 2009
    my red light stay's on even though connected still cant play on line
  • Anonymous Apr 17, 2009
    i dont no whats going on with my adapter eather i plug it in and the red light flashes the when the xbox is on the red light stays on.
  • Anonymous May 13, 2009
    mjbnijhnbj
  • Anonymous May 23, 2009
    it wont connect watever i do to try and make it connect that little red light is on. idk what to do
The red light doesnt mean that its broken, it just means it needs a network to connect to. i had this same problem several times and all i had to do to fix it was to disconnect my xbox from its normal network connection, and then reconnect it. to do this just go to configure network, scan for networks, and then connect to what it should normally be connected to. idk why it does that, but it has worked every time for me. hope it works for all of you
Posted on Jan 03, 2010
You might have to try a different security mode on your router, pick a a security mode that most devises can connect to like WEP-128.
Posted on May 16, 2009
It might have to be replace
Posted on Feb 27, 2009
Cant connect to xbox live
What you need:A high-speed Internet connection such as cable A router, gateway, or wireless access point (WAP) that is compatible with Xbox LIVE. An Xbox 360 Wireless Networking Adapter (original Xbox 360 console only) Instructions: On your console, go to My Xbox, and then select System Settings. Select Network Settings. Select the name of your wireless network. Enter your wireless network password. Select Yes if you are prompted to update your console software. When you successfully connect to Xbox LIVE, your screen will look like this:
Jul 25, 2011 | Microsoft Wireless Network Adapter Xbox...
I have an ac adapter for the new xox 360 250 gb , that has the red light lighted up that means false alarm what should i do to get it back to green its been 1 week?
Check the status light on your adapter The state of the adapter's status light indicator can tell you the status of the Xbox 360 Wireless G Networking Adapter. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is ready to be configured. For information on how to do this, please see: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support.
  • Not illuminated: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select Configure Network.
  4. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article:
    977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  5. Select Scan for Networks.
  6. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article:
      909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  7. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  8. Press B on your controller, and then select Test Xbox LIVE Connection.
    If you successfully connect to Xbox LIVE, you'll see this screen:
    If you receive an error message, please go to www.xbox.com/networkhelp (http://www.xbox.com/networkhelp) for further help.
Dec 03, 2010 | Microsoft Wireless Network Adapter Xbox...
Ive just got an xbox 360 adaptor for xbox live and the light is still on red on the back of the xbox live adaptor, how do you get it to a green light beacuse ive tried everything. many thanks cameron
You need to first set up your connection...the red light indicates there is no connection....you need to make sure your internet has a wireless network and u need to selct ur network from ur network settings in xbox360.
Mar 01, 2010 | Microsoft Wireless Network Adapter Xbox...
I cant connect to xbox live
The red meant it was ready for configuration. If there is no light it means it is not receiving power. Try plugging it in again, or plugging it in to a front USB slot. If it still doesn't work your adapter has a defect and should be replaced.
Dec 30, 2009 | Microsoft Wireless Network Adapter Xbox...
My wireless adapter for my xbox 360 stays on red light
You can try fixing this using Xbox360 repair guide that covers almost all xbox 360 problems, you can get a copy from here
http://xbox360repairguide.com
Jul 10, 2009 | Microsoft Wireless Network Adapter Xbox...
Red Light On Wireless Adaptor For Xbox Live
just do port forwarding in the router and port number of the x box OK try it
Apr 17, 2009 | Microsoft Wireless Network Adapter Xbox...
Cant connect to live...wireless.
Basically i know its a rip off but if u wanna use wireless with the xbox 360 u need to buy the official xbox 360 wireless router which is about £60.There is another way if u dont use wireless u can connect the xbox 360 to a router or the phone line then go to your windows firewall and set it up manually.Hope this can help you .Joe stevenson
Jan 22, 2009 | Microsoft Xbox 360 Console
Xbox 360 wireless connection faiures
sure i can help, when you run "test xbox live" where do you fail in the tests?
Nov 06, 2008 | Microsoft Wireless Network Adapter Xbox...
XBox 360 via wireless
Hi ServiTiendas
To resolve this issue you have to set DHCP client to automatic
Jun 24, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
1,938 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
