Question about Nikon Sporter I Binoculars
Hinge on binoculars is too loose
I have a set of Nikon Sporter I 10x36 binoculars. The center hinge is so loose that I must constantly adjust them to keep the separation to match my eyes. How can I tighten the hinge so that it does not move quite so easily?
  • 112 Answers
There is a hinge nut at the bottom of the hinge..sometimes you have to turn of the cover or peel back the rubber to get at it
Posted on Feb 20, 2009
How to tighten binocular hinge
Simple solution: Pry or unscrew the cap covering the end of hinge shaft on the rear of the binocs (between the eyepieces). Use a screwdriver that fits snugly in the slot on the end of the shaft & tighten to desired tension. Place a dab of Goop-type cement on the inside of the cap if it was pried off & press it firmly back on the shaft . Helpful hint: Slide a small knife blade (an old dull one you don't use for cutting) under the cap and gently work your way around to pry it off. Note the position of the index numbers before you remove it so you can replace it in the same position.
Feb 27, 2012 | Nikon Monarch ATB 7345 Binocular
Eye alignment loose for eye centres
sounds like center hinge is loose..has to be taken apart to repair ..larry@reichinstruments
Jun 05, 2011 | Zeiss Classic B/GA 524013 Binocular
Nikon compact binocular 25 years old. The hinge
Does this pair have two parallel tubes with a bridge in between?
If it does, then removing the caps at the eyepiece end of each hinge will reveal a grub screw. Tightening these will add tension to the hinge and give you the proper feel once more.
Feb 28, 2010 | Nikon Optics
Binoculars are too loose to hold eye to eye spacing/
under the bottom hinge cover there should be a hinge nut you can tighten, if i can help further call 5088331232...larry
Jun 12, 2009 | Bushnell Binoculars - Off Trail Compact
Nikon Replacement Eyecups
What an excellent glass you have. Nikon in your country should have a service center. I have had them get me a replacement set for a 7x50IF SP WP which is not a common model. They emailed me an order form and I emailed it back. They were not in stock so it takes about 6 to 8 weeks. May I suggest you order a back up set when you do.
If they aren't too helpful (they needed a shove) try Binoculars.com or Adorama Camera in new York. They will also ship internationally.
Mar 29, 2009 | Nikon Superior E Binocular
I cant find friction adjustment on Minolta 10 x 40 binoculars
Hi Ray:
I have Minolta binoculars with the same issue, I believe that I also have the same Minolta model: 10x40mm, roof mounted prisms, 5.6 degrees, waterproof (WR series) and model number j-b35.
Have you found any solution for the loose center hinge?
josch799@yahoo.com
Feb 01, 2009 | Optics
Bushnell insta-focus mechanism gets stuck.
they were famous for that, because the screwpin that holds the eyepice shaft is metal and the groove that it rides in is plastic, and eventually gets jammed....look where you put your fingers to adjust eyepieces. should be small metal plate in center of hinge(sometimes with bushnell logo) that will simply pry off by using small screw driver,and now you will be able to see if the screw is loose or damaged. good luck...larry@reichinstruments.com
Jan 14, 2009 | Bushnell "Insta-Focus" Binoculars
Insta-Focus focusing problem
first open and close the binoculars untill they fit you eye width,now adjust left eye with the flat section located on the center hinge,now turn right eyepiece till clear. note: once you have adjusted right eyepiece you only have to leave it in that position in order to focus from near and far.........good luck......larry@reichinstruments.com
Nov 24, 2008 | Bushnell "Insta-Focus" Binoculars
Bushnell 10 - 30X50 adjustment
on some models the center focus control is located on the center hinge,it should be flat,and not hard to find,if there is no center wheel this is where it should be...good luck...larry@reichinstruments.com
Nov 19, 2008 | Optics
Cabelas Alaskan Guide 10X42
I agree with you on that! I have a feeling they are either Nikon or Leupold sourced. The body is alot like green ring leupold ive seen but the lenses have a magenta multicoating on a lens surface which ive seen on nikon. I'm in the process of looking for the maker of them myself as I need an objective lens. I'm going to call the Cabela's Cust SVC number and see what they say. I've heard the new Euro styled binoculars are made by Meopta.
Nov 25, 2007 | Cabela's Alaskan Guide Binoculars
Optics Logo
1,750 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Are you a Nikon Optic Expert? Answer questions, earn points and help others
