Question about Ebel Classic Wave 9090F249725 Wrist Watch
Ebel wave lady's watch battery replacement
Ebel wave lady's watch-- Could you provide detail of how to take battery out to be replaced? I can open the top screws, take out the crystal, but cannot get the whole thing out to replace the battery-- I cannot remove the crown and its shaft to permit the machinery, including the battery, to be removed.
Thank you.
  • montsfix May 11, 2010
    Same problem here. Any help out there?
3 Suggested Answers
landsend
  • 1066 Answers
SOURCE: Ebel Wave lady's watch battery
You obviously don't know the first thing about watches...I'd be surprised if you haven't messed it up.  You simply remove the back case to replace the battery.  the part you call the machinery is called the caliber.
Posted on Mar 22, 2009
Landsend, you have no idea what you are talking about, you have obviously never seen an Ebel Ladies wave - there is no back cover, the case is a solid piece of metal and the battery can only be accessed by removing the front bezel and glass, removing the hands and face and finally removing the stem (the hard bit!). Once all this is done the movement can be popped out to access and change the battery.
Posted on Jun 03, 2010
  • 5 Answers
to change the batt on an ebel womans watch i simple. 1 take out screws from bezel. 2 lift off , make sure to keep rubber gasket in place. 3 pull out stem to the set position. 4 be very carefull not to bend / touch hands. 5 turn case upside down, and you will see the opp side from the winder drop out slitely. with your fingernail pull downwards gently on works, then when you have it out a little on that side, turn it back over. and continue to lifft up gently, 5 as you do so, start to rowtate the works counter clockwise. the stem is made to .bend / swivel and the works will turn upside down and lay back into the case. to protect the face while installing the batt. 6 when done gently lift the same way but rowtate clockwise. but make sure you grab sides of works and not the face. ( the hands are very delicate) 7 take the batt to a jeweler to replace you will never find a batt with the same number ( ebel made sure of that ) they want you to pay 140.00 to 240.00 for them to do it. but a jeweler can match it. now that said, once you take the bezel off, your ebel warenty is void. so 140 -240 or $5.00 your choice i have had meny watches over the years all with rubber gaskets and have replaced batts is some five times and the gasket are still fine. and a batt will last 3 to four years. five in 15 years could cost you $ 1020.00 in the long run. hope that answers your question.
Posted on Aug 23, 2011
What type of battery does an ebel (feman) watch use?
ebel keeps that a secret they have a marking on there batteries mine 690 but there is no such after market replacement with this number. ( ebel wants to be the only game in town/ world ) but if you want to replace it your self, witch will void your warrenty 'says' ebel. take the battery out and take it to a jewelry store, and they can match it up ( $5.00 to $6.00 ) or pay $240.00 to ebel to "service" it. clean / new gaskel / batt witch ebel says is necessary to change batt. every 3 years or so. do not take the watch to the jewelery store only the battery , because know one will open it. they will want to send it out to ebel for service big $ also save old batt, because if you ever have to have the watch fixed put the old batt back in and hopefuly they wont notice. to get the battery out read my instructions i have posted its easy. other posts i have read on replacing batt, they don't know what they are talking about. do NOT remove anything but the bezel only. please Read hope this helps you out.
Feb 28, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
How to remove stem to get to battery in ebel ladies watch?
On my men's classic wave, the stem is removed simply by pulling it out. It feels like it's requiring a lot of force, but it is designed to have resistance so that it's not pulled out accidentally when setting the time.
So to change the battery, you remove the 5 faceplate screws, remove the crystal and gasket, pull out the stem and then the whole face/movement assembly will pull forward.
NOT positive yours is the same, but that's how my men's Classic Wave is. Good luck!
Dec 18, 2010 | Ebel Classic 1157111/0225 Wrist Watch
Ladies Ebel wave w/diamonds and sapphire face............jeweler cannot replace battery, does crystal need to be removed or remove back?
The back will need to be romoved, but in doing so yourself, you will VOID your warranty, and since this is an expensive watch, I highly recommend that you send it in.
You can find all this information here:
http://service.movadogroup.com/faq.cfm#127
Best regards.
Aug 23, 2010 | Ebel Classic Wave 9090F249725 Wrist Watch
I need acouple of wavy links for a gents ebel watch....where do i go to get some?? thanks very much
mcdevito75 here, Chances are the qiuckest way is to visit a local jewlery shop in your area, they may have quicker accesss to Ebel so you can get Ebel replacement links, this way your Ebel watch remains 100% Ebel.
Jul 28, 2010 | Ebel Classic Wave 9090F249725 Wrist Watch
I lost the crown of my Ebel Classic Wave and now I cannot set the time. Can tnis be replaced? How much and where can I get it replaced?
mcdevito75 here, Best Bet, Look for a small watch repair shop in your area, for this crown, being an Ebel watch you should contact Ebel. The watch repair shop can help.
Jun 29, 2010 | Ebel Classic Wave 9090F249725 Wrist Watch
I'm loking for a replacement black leather band
If you want to pay the premium for an Ebel strap then any Ebel dealer or an online source can provide that.
For a much more reasonable price, I would try a store that sells AND installs watch straps. Usually, only independant jewelers both sell and install these.
Oct 16, 2009 | Ebel Classic Wave 9090F249725 Wrist Watch
Need double link for mini Ebel Classic Wave Watch
Unfortunately you will not be able to buy links anywhere else exept Ebel. You can try to find them on eBay, but it may take years and even then there is no any guarantee thet you will find the right links.
The best way is to contact Ebel and ask them if they can supply any links needed. Visit this link:
http://www.ebel.com/#Stores_Service_Centers
Choose the way you want to contact them or the nearest srevice center.
Do not forget to rate, please.
Mar 06, 2009 | Ebel Classic Wave 9090F249725 Wrist Watch
Feb 19, 2009 | Ebel Classic Wave 9090F249725 Wrist Watch
Ladies Classic Wave Diamond dial
Yes, you can. Contact your nearest Ebel retailer and they will advice you.
Bear in mind- this is a costly upgrade.
Jul 19, 2008 | Ebel Classic Wave 9090F249725 Wrist Watch
Ebel Classic Wave fitting a new crown
i have changed the battery on my and my wifes ebel classic wave watch,,
step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
step 2 ...remove all 5 gold bezel screws
step 3... be careful,, the bezel/crystal will pry off easy
step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
step 5.. small screwdriver and remove/replace battery
step 6... reinstall watch guts/bezel and gold screws
step 7... push crown back into watch
step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
if have done it many times ,, you can do it !!!!
Dec 10, 2006 | Ebel Classic Wave 9090F249725 Wrist Watch
Ebel Classic Wave 9090F249725 Wrist Watch Logo
731 people viewed this question
Top Ebel Watches Experts
Coss
Jimmy Accardi
Tom Chichester
Are you an Ebel Watch Expert? Answer questions, earn points and help others
