Question about Maytag CWE4800A Electric Single Oven
Maytag CWE9000 electric oven won't turn off
The other night our oven would not heat to selected temperature, so we hit cancel and microwaved our food.
The next morning we noticed heat coming from the oven even though it was off. I had to shut the breaker.
The lower element did have a bright glow in an area the size of a pinhead. Control panel is about a year old. (replaced due to f code problems)
Any help solving this issue is appreciated. Thanks.
SOURCE: F1 error code for Maytag CWE5800ACB
Defective touch pad or membrane, usually the touch pad.
Posted on May 19, 2008
  • 126 Answers
SOURCE: maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Posted on Jun 25, 2009
SOURCE: control panel buttons due not work
It is the whole front face w/ the buttons. My whole neigborhood has these ovens (same builder, same ovens) and this part lasts about 2-4 years. The part is about $165. You can see it on Home Depot's appliance repair site. It looks like there is nothing electronic, but there is, and it's busted. It is really easy to replace:
1. Turn off the breaker at your house's breaker panel.
2. Verify there is no power to the oven.
3. Open the oven door. Look on the right and left side of the oven. There should be 4-6 screws going from vertical trim pieces of the oven into your cabinets. Your builder may have also put screws from the bottom trim of the oven into your cabinets. Mine did not. Remove these screws.
4. After that, your oven should slide forward out of the cabinet. Pull it about 6 inches out.
5. There are two screws (1/4 inch hex headed screws) holding the front panel to the oven. Remove those.
6.Slide the front panel off.
7. Remove the computer ribbon looking wire from the back of the control panel. It's a strange connection - it should come out effortlessly when done right. The little grey connection that surrounds the wire's entry point stays on the panel, but a wedge is jammed between the grey surround and the wire. You pull the wedge out and the wire comes out...easier than my credit card out of my wallet.
8. Remove the four screws (again, 1/4 inch hex headed screws) connecting the thick, double layered circuit board and clock display from the metal face.
9. The metal face is what you need to replace. Pasted onto the front of the metal face is a super thin button panel, and that's the part that died, and will die again, and again, and again...
email me for pics schmidtkeith1@yahoo.com
Posted on Sep 30, 2009
heatman101
  • 43501 Answers
SOURCE: The element on the bottom of my GE oven had a glow
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Apr 01, 2011
  • 52 Answers
SOURCE: i have a maytay range model mer5710aaw the lower
You have several thing faulty, sounds like a switch inside the circuit board has gone, i have not worked on this model, but there are control problems , I would advise someone with electrical knowledge to check it out, the glowing of the element could be signifficant, but your main problem is an expensive one. How much i don't know. Look for parts in www.whitegoods.co.uk you will need model serial numbers.
Hope this of some assistance.
John
Posted on May 31, 2011
JTP85 microwave shuts completely off with a blank readout.
Your magnetron is overheating, and its attached thermostat is doing its job to protect the magnetron by shutting off the power to the oven until it cools back down to a safe temperature.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven when cooking such foods)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, and it is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 21, 2012 | GE JTP85 Electric Double Oven
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    The microwave seems to be operating on reduced power. It seems to be transmitting a single wave, as only one part of the food is heating and the rest remains cold. It was repaired 4 months ago and had new...
    If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
    So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
    then it must be checked or replaced.
    See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
    Now keeping clear of the microwave, switch on, use a cup of water inside to test.
    If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
    If there is heating without any issues, you can use the microwave safely
    Jul 22, 2011 | Ovens
    The fan works but the oven doesnt heat up
    Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
    Jul 13, 2011 | Whirlpool Ovens
    My microwave comes on but is not heating food. is there a reset button?
    Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
    Basic
    Microwave Oven Troubleshooting Tips
    heatman101
    Jan 25, 2011 | Sharp R90GC Electric Single Oven
    Oven and coil burners work one time then the next time neither one warms up, try again later and it works again. started last week when the oven preheated put in food to cook and half hour later noticed...
    If this is an electric range, it sounds like you are not geting 220v all the time. check were your cord or house power hooks up to range. You may find one side of the 220 line burnt. Shut off power and repair conections. or call a qulified tech.
    Nov 22, 2009 | Ovens
    Convection works but Microwave does not heat
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    duid
    May 26, 2009 | GE Monogram® ZMC1095BFBB /...
    5 yr old Jenn Air Electric oven won't maintain oven temperature
    Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
    If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
    Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
    Sparking when microwaving
    heatman101
    gfgh
    Mar 08, 2008 | GE Profile Advantium SCB2001KSS Stainless...
    Error code F1 and beeping
    Means replace the $300 control board. And if your like me.....do it twice within 12 months.
    Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
    Maytag CWE4800A Electric Single Oven Logo
    434 people viewed this question
    Top Maytag Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    Mack Baxter
    Are you a Maytag Oven Expert? Answer questions, earn points and help others
