Question about Insignia LCDTV26 26 in. Television
NS-27LCD / No Power / No LCD Display / Flashes Red Blue
I hate to beat a dead horse but I am experiencing the same symptoms. I was watching TV for an hour. I went to power off the TV. Before I pressed the power button on the set, I recieved a static shock (or the TV recieved the shock) and the TV turned off. The power indicator flashes from red to blue. This happened before. I called the repair center and they looked up the work order from two years ago. The problem from before was a Decoder Board Connector. Is it that part again? I can only assume since I don't have the proper test equipement.
  • 9 Answers
I have a 26" Insignia HD-TV and just found out the cable remote code (to connect TV with the cable box) is 0463.  If that's not what you need, try calling Insignia's help line at 877-467-4289
Posted on May 14, 2008
SOURCE: How to remove the back from Insignia NS-32LCD?
I unscrewed all the screws in the back, detached the tv from the base, and was able to get the back off. I ordered a new power supply board and will install it to see if it fixes the problem with the tv (won't turn on, insignia light alternates between red and blue). I didn't notice any problems with "swollen" capacitors, so if the new power board fixes the problem I'll update this website.
Posted on Jan 28, 2009
  • 463 Answers
SOURCE: insignia tv shock power on/off
And thus the wailing an gnashing of teeth. LCD TV's have really come down in price... Typically $500-$1000 for anything but ultra-high end. So something goes wrong with them.... what do you do? Typical repair cost is $250-$400 in parts, and that does not include technician house call, or labor to repair. Let's say you're the adventurous type and are pretty dang sure the problem is the PSU (power supply unit). So you order up one of those, it takes 6 weeks to get here from China. Costs you $300. You put it in and it doesn't work!!!
There you go.
So, anyways... Unplug the thing from the mains for about an hour and plug it back in. If it is still in an error condition, buy a new TV.
Posted on Mar 07, 2009
  • 9 Answers
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
if your a must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
Posted on May 18, 2009
  • 2326 Answers
SOURCE: No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to
Posted on Jun 29, 2009
Red flashing power light blinking
These flashes are fault indications, and are called blinking codes. By the number of flashes occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. If you wish to get more details, check the site linked here
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 10, 2013 | Insignia NS-LCD47HD-09 47 in. LCD TV
TV will not come on
You are experiencing symptoms of power supply failure
Apr 12, 2013 | Element ELCHW402 40 in. LCD HDTV
Insignia NS-27LCD TV, got a nasty static shock, and now I just get a blinking red light on the front. Nothing else happens...I left it unplugged for a year (yes, a year lol) and I am still having the same...
Jason, this does sound like a main unit issue...although not 100% certain. Give a company named a try for parts. They have been a huge help to me in the past. I included a link to your model page from their site. Hope that helps!
Sep 21, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
No power when switched on . Insignia model ns-27lcd
Power supply module will be the first place to look, it can be from bad DC filter caps (leaking/bulging top, high ESR), blown main AC fuse, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Jul 16, 2010 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
My Insignia NS-27lcd tv won't power on
Could be a dead backlight or inverter board. I would try the power supply as it isn't that expensive. I would buy the power supply from whoever has the best return policy. Best Buy might take it back with no questions asked. This way, if it is not the power supply, you can return it.
May 02, 2009 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Insignia NS-27lcd tv won't turn on
Well, take the plug that goes to the inverter board out which has the 12v on it. Check the 12v again at the power supply. If 12v is low you can possibly have 2 caps bad, the values should be about 1000uf/35v or there abouts. They set close to the plug. If that doesn't work then replace the Power Supply because there are no service manuals for lcd p/s. plus nearly impossible to locate individual ic's. Try Shop for the P/S.
Apr 30, 2009 | Akai LCT3701AD 37 in. LCD Television
Apr 17, 2009 | Insignia IS-LCDTV32 32 in. Television
27'' LCD panel compatability
Both power supplies are supplying the same voltages to the circuits but in order to use the one from the NS-27LCD 27" you will need to change the wiring configurations to make it work for the LCT2715..
I could repair the power supply from the LCT2715 for under $90.00 including parts, labor and shipping it back to you.
Let me know if you require further assistance.
Mar 01, 2009 | Televison & Video
No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
Insignia LCDTV26 26 in. Television Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
