Question about Panasonic NN-S753 Microwave Oven
PanasonicNN-K627M micro & browner
It won't heat up food, but the grill part still works.... Any ideas why it won't heat up please?
  • 52 Answers
It is obvious that nthe microwave side of the unit is not working.
microwaaves have a terrible habit of blowing fuses for the most stupid reasons. No not the fuse in the plug but the ones the manufacturer hides inside the case, you will have to look hard. if one is blown replace it with a direct replacement. and do not test the machine with the cover removed
Posted on Feb 21, 2009
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
My microwave doesnt work
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
Thanks,
micro
pls. rate..
Mar 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic microwave grill not working
I would call customer service with the model number to see if this is a known issue. You might also call a authorized Panasonic repair center and chat with them to get some idea of what a possible repair might cost.
Dec 04, 2012 | Microwave Ovens
I WANT OPERATING MANUAL OF NATIONAL MICRO BROWNER NN K577WF
I WANT TO BUY CHIP WHICH OPERATE MICRO WAVE
Oct 30, 2012 | Microwave Ovens
Hi. I have samsung microwave oven GE83ZL two years old. I was out for a month. after i came back and starts the oven but its not working grill is ok but microwaves are not heating up the food ! oven works...
check the door safety interlock switches. if failed, they cannot tell the oven that the door is closed and if the door is open, the magnetron will not come on. remove the cover and find the small micro switches neat the door latch system. check them with a ohm meter with the door open ... then closed. of course, you are checking for continuity ...not voltage ... so unplug the oven before you start.
Nov 15, 2010 | Samsung Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
I have a GE Microwave Oven/Dual Element Browner Model # JES1288SHO3. The inside cabinet is arching through the wave guide panel. DAVE IN LA.
Hi Dave in LA,
The wave gude cover is replaceable, the part number is1085082. The reason for arcing through is typically a splatter of food stuck to the cover and then the heating waves overcooked or burned it. Carefully replace the cover (panel), look for any burned spots behind the cover, if the wave guide is burned through, the Microwave is unrepairable. If the waveguide has small arc spots you can carefully clean (sandpaper) and use touchup paint to recoat. I hope this helps and if it does, please let us know!
Apr 18, 2010 | Microwave Ovens
No heat - everything else works
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 26, 2009 | GE JVM1440 Microwave Oven
Panasonic NN-S753 Microwave Oven Logo
194 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
