Question about Uniden Cordless Phone
I do not get a dial tone and the phone does not ring when someone calls
  • 1 more comment
  • Anonymous Mar 02, 2009
    my uniden tru446 cordless phone gets no dial tone or ring when incoming calls come through
  • djhappy29 Mar 16, 2009
    it doesn`t hang up,keeps the line busy
  • Anonymous Mar 18, 2009
    MY UNIDEN HAS THE SAME PROBLEM TODAY. I DO NOT GET A DIAL TONE AND IT STARTS DIALING A # AUTOMATICALLY. MY LINE IS TIED UP, THE PHONE DOES NOT RING.
  • 96 Answers
Change ringer
Posted on Feb 20, 2009
My phone #1 does not ring nor can I get a dial tone.
Troubleshooting Home Phone for No Dial Tone ' iiHelp
https://iihelp.iinet.net.au/Troubleshooting_Home_Phone_for_No_Dial_T...
This article will explain what to do if you can't make or receive calls using your HomePhone (landline). ... If it rings normally, skip to step 3. If you hear an engaged tone ora recorded voice saying the number is not available, ... If you have a dial tone and can make a call when your phone is plugged into one socket but not ...
No Dial Tone - Phone Forum - Phone Forum - Cox Support Forumsforums.cox.com/forum_home/phone_forum/f/6/t/3496.aspxJan 1, 2014 - 16 posts - ‎13 authorsThis will help determine which phone or jack may be contributing to the problem. If these steps do not restore your phone service it may be necessary to ... directly to the #1 telephone port on the modem and see if you get dial tone there. ... Then try calling yourself(from a cell phone), and as it rings, plug the ...Big Mystery...Phone won't ring ' Techlore
Jan 10, 2016 | Lands Phones
Does not ring
If you recently dialed 4-0 or 4-1, those are Do Not Disturb and Call Forward codes. if this is what happened, then dial the cancel code for both, which is 4-2. This is with internal dial tone, don't grab an outside to do this. You could have someone dial your extension to test if the ringer is faulty. if their call comes in as voice announce, have them add a 1 to their dial sequence and their call should switch to audible ring, and you will know it's not a ringer issue. Adding a 1 can be done continuously if you want to switch back and forth.
Jan 07, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
Merlin BIS-10 no dial tone and can't answer but phone rings
I have a dial tone but can not make calls. and if the phone ring they can hear me but I cannot hear them
Apr 01, 2013 | Avaya MLS 12D Corded Phone
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
No dial tone
This is the time that love cannot help with. Buy yourself a new home phone where the massages will pile up. erase all massages on your mobile phone. It is time to buy a cell phone which will record all masseges that you've received.
Sep 23, 2008 | Siemens Gigaset S455 Cordless Phone
My house phone rings when someone calls but we can't hear it ring nor can we get a dial tone to call out
The ringing you hear when you dial your phone number is not actually your phone ringing but a machine at the phone company designed to give you something to listen to while they connect your call. I would say that your phone number is working, just not at your house. You need to call repair to trace your phone line and get it connected properly. Good luck
Jul 17, 2008 | Lands Phones
Machine dials during phone calls
please check if the machine is set to correct answering mode i.e. TAD/FAX ?correct it if otherwise. in case it is ok please check whether the DRPD mode may not be switched off ,pls correct it.. HAPPY FAXING HEMANT GROVER
Aug 29, 2007 | HP 1040 Plain Paper Inkjet Fax
Uniden Cordless Phone Logo
219 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
