Question about NEC Electra Elite DTU 16D-2 Corded Phone
NEC STU 16D-2 will no longer pick up our third line.
We have 3 phone lines in our office with the above mentioned phone system. The third line is dedicated to fax, cc machine and alarm system but we used to be able to access an open line if our other lines were in use. We can no longer do that. Can you help with programming the phone to pick up that line?
We ended up having tech support fix the problem.
Posted on Mar 02, 2009
The screen on my phone shows "VRS-AL" which does not allow anyone in the office to page me. How do I remove it?
on the phone press speaker dial 713 and hang uo.
if this does not work we need to know what kind of phone system. IPK IPK 2?
Sep 19, 2014 | NEC Dterm DTP 16D-1 Corded Phone
One of my phones stopped ringing on my nec dtu 16d phone
Ringing is assigned in system programming, very little chance it was changed by mistake. If Do-Not-Disturb was turned on, that could make a phone stop ringing. If it's just one line on a phone, maybe the system got put in night mode by mistake and night programming isn't identical to day ring. If you have direct access to the phone line check it for dial tone. Often virtual lines are used and you can't check for direct dial tone. On very rare occasion the ringer stops working, which can't be fixed.
Jul 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
I have a NEC Dterm 80 phone system in our office. Not all phones will ring when there is an incoming call, and I want to set them ALL so that they will
Dterm 80 works on several systems, would be helpful if you mention what system you have. Programming lines directly onto a phone is done in system programming, not really something you can do yourself. If your IT person has the programming software, great. Very rare someone on site is tasked with knowing the phone system at that level, because it gets deep quick, and your working on the whole thing, not just one phone.
Jun 23, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Office NEC phone to be used at Home
This phone is a proprietory digital phone that only works with a KSU. You would need an IPK or Elite phone system to make it work. You would also need to program it. This is a business office system and that phone will not work unless it is plugged into the system.
Feb 05, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
DO not disturb feature will not turn off
do not pick up the headset
push feature 69 feature
Jan 20, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Can't answer direct line calls
This sounds like a programming issue on this telephone. There are 2 areas in programming that would cause this. If you have recently had a technician out to do some programming then it is possible that he made a mistake and needs to be called back to correct his mistake.
Nov 12, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
RE: NEC DTP-2DT 2 Line Digital Phone HandSet
i believe the nec dtp-2dt maybe a phone system phone for offices. you didn't mention if it's for home or office use.a phone system phone will not work in a regular phone jack. it needs to go thru a phone system. also if you buy any 2 line phones, you need 2 lines for both lines to work. you can also have a 2 line phone with only 1 line and order a 2nd line if needed
hope this helps
wg
Jan 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
101 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
