Question about Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit
N80S won't completely sink #12 nail
My N80S sinks #12 nails about half way. Most times it will only fire a single #12 nail. #8 nails work great. I have installed the basic O-ring kit, but still no luck. I have also replaced the large O-ring "check valve" on the lower outside of the cylinder. All parts have been cleaned and oiled with air tool oil. I have 120psi available and a very large compressor.
  • David Ford
    David Ford May 11, 2010
    by basic o ring kit I take that to mean the piston and firing valve and the trigger? How are the bumpers in the bottom of the cylinder? Also how is the seal on top of the cylinder? When you rebuilt this tool did you grease the orings. And by shooting a single nail is the piston not returning to the full rest position. If not it could mean that the cylinder is dry and not retracting the piston (it should move freely) or the firing valve might be sticking. Let me know
  • 3 Answers
It sounds like its not oiled enough possible bent piston due to jamming.
Posted on Feb 20, 2009
I have a Bostitch N80S stick framing nailer that leaks air from the trigger area. I replaced the entire trigger valve with a new single fire trigger to see if the old bump fire trigger was the problem
Remove the nails and take off the trigger to expose the trigger valve (usually part # tva6). Connect air and spray soapy water on the valve to determine if the air is leaking from the center of the valve or around the outer edge between the body and valve. If leaking from the center, could be defective valve or debris under oring. Pop out the valve and examine internal parts for cut oring or defect. If leaking from between body, you could have cut orings installing the valve. Make sure that there are no rough edges in the body of the gun. Bump fire or single fire happens with the trigger type not the valve. Bump fire trigger is usually black metal and single fire trigger is light color plastic. Good luck
Apr 10, 2013 | Stanley Bostitch Nail Gun
Can I use paper collated nails in my Stanley N80s b-1? The nails meet all other required specs.
Paper collated will work. Maze nails part # PCP28325131 works on many 28 degree guns including yours. Only advantage that I can see with using welded is that the nails will take more abuse on the job site including getting wet. Paper collated can brake apart easily but dont worry too much about the difference. I would buy the least expensive or available but I like the idea of using made in USA of maze nails (not available on all areas of US). Good luck
Nov 10, 2012 | Stanley Bostitch N80s Nailer -rebuild...
Miss fires and wont sink nails depth set deep and pressure over 120 psi
If no air is leaking from gun, miss-fire is usually caused by worn or too tight piston oring or lack of lubrication. Easy test. Disconnect airline, remove nails, point nose of gun up then down. Driver should stay in uppermost position. If driver moves up then down within gun replace piston oring and retest. Set pressure to about 100psi. Good luck with repair.
Oct 14, 2012 | Porter Cable Coil Roofing Nailer
Hitachi roofing nailer shoots every other nail & doesn't sink the nails it shoots
i think you have two different problems , replace the feeder spring, and replace the oring on the driver piston. also make sure that the coil of nails is perfectly round if they are dropped or squeezed tool will not work right
Sep 11, 2012 | Hitachi NV45AB2S Coil Roofing Nailer
Paslode 900600 Trim nailer not sinking nails
The firing pin can be completed or part of it crooked worn and can have a little burr on its way and stuck in the cylinder somewhere o-rings worn and hardened, have a tilting piston on the firing pin somewhere in the cilinder
Jul 27, 2017 | Air Tools & Compressors
Stanley coil roofing nailer not sinking 3 1/4
That model may not be designed for that length nail. Check with your local supplier.
Mar 10, 2010 | Stanley Bostitch Coil Framing Nailer
It will double fire sinking second nail only half way. This happens every third or fourth shot. The nailer is a Hitachi NR 83A 3.25in. X .131
the pin pushing your nails is loose and the guides are warned .
try to change the guides and you will see that this problem will will be gone .
one last thing , make sure the coils are in good shape as it may create some feeding problems and push 2 nails at once
Sep 26, 2009 | Hitachi VH650 2 1/2" Full Head Fencing...
Nailer only will fire one nail at a time and will not fire a second nail unless we take the nails out and put them back in. Nail also does not drive all the way in when it fires.
I found your post a couple times, when you remove the nails does the piston/driver slowly come down? Also do you hear any air leaking around the cap? When was the last time you had it serviced. It sounds like the o rings are dried out or worn flat and possibly a seal on top of the cylinder might be damaged. Not to worry though, it is rather inexpensive to repair all that yourself if you are handy with tools. Let me know and I will find a breakdown for you before you attempt anything
Jun 05, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Cambell-hausfeld framer
its double firing, after firing gun pull back, what is happening is when you fire a nail your pushing the gun back onto the wood and its putting another nail in
May 08, 2009 | Campbell Hausfeld 2" 18GA Brad Nailer
Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit Logo
157 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
