Question about Whirlpool RBS275PD Electric Single Oven
I programmed my frigidaire to self-clean this morning at 10 for 3 hours to complete and 1 hour to cool. The door will not unlock even after it has cooled. Model #CFEF372ES3.
  • crappysystem Apr 05, 2009
    I have the same problem. We used the self clean function and a day later when we wanted to use the oven we just found out that we can't unlock the door. I'm looking through internet to see if someone had the same issue. If I get the answer, I'll post it for sure. But what a pain !!!
I finally got it !!!!
Click on the Clean Button - Then click on the Up arrow - a 3:00 hours should appear on the screen (In fact you are fooling the system by starting another self-clean session. Then click on Cancel, this should unlock the door. When door is open you might then get a warning message but it should disappear after a couple of seconds.
Posted on Apr 05, 2009
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    Tip
    How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
    Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Tip
    SELF CLEAN - FRIGIDAIRE OVEN
    I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
    1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
    2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
    3. PRESS THE "COOK TIME" BUTTON
    4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
    5. PRESS "START" BUTTON
    6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
    7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
    on Oct 09, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    How does the self-clean feature work on a Frigidaire CFEF366EMB model?
    Hi Beverly,
    I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
    -To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
    -Next you will press the "Clean" button, and the display will show "---".
    -Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
    -The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
    -"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
    When the self-clean cycle has completed:
    -The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
    -Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
    -If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
    -When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
    -Best Regards-
    Jan 23, 2014 | Frigidaire Ovens
    How do i operate the self cleaning function
    Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
    Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
    When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
    If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
    Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
    Door won't open after self cleaning and cool down has stopped.
    if you are sure it has cooled down cycle it again to clean hitting the cancel button shorty after it starts
    Dec 09, 2011 | Maytag CWE5800A Electric Double Oven
    My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
    Here are some solution on how to unlock the door of your oven ans do self cleaning below.
    IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
    hope this helps you out please rate this solution it helps get better results for our customers like you
    Here are solution on how to clean up your oven below.
    Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    The lock will not release after cleaning
    This is GE's trouble shooting advise:
    Range - Oven Door Won't Unlock After Self Clean
    The Oven Door has been Locked Accidentally:
    • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
    • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
    • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
    • Note: Do not force the latch at anytime!
    Door Will Not Unlock After Cleaning:
    On models with mechanical latches:
    • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
    Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
    If the above suggestions do not work try the following to unlock your door:
    1. Disconnect power to range for 30 seconds.
    2. Reconnect power and see if door will unlatch.
    3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
    4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
    5. Wait approximately 30 minutes and try to unlock the door.
    6. If the door unlocks, the control has reset itself and there should not be any other problems.
    7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
    Note: Under no circumstances should you ever force the door or latch open.
    May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
    Started to self-clean, locked the door, etc. Had
    Hi.
    The appliance door is probably locked in consequence of the self cleaning cycle.
    Unplug power cord, and allow the oven cooling down for few hours.
    If the is still locked, then the high temperature generated in self cleaning cycle may have damaged the door latch, or the electronic control.
    Parts must be tested to discover the fault.
    Call Frigidaire at the number listed on the owners manual.
    Regards.
    Mar 03, 2010 | GE Ovens
    Frigidare Self Clean Oven
    Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Whirlpool RBS275PD Electric Single Oven Logo
    105 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    John Tripp
    John Tripp
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
