Question about HP LaserJet 4200 Printer
HP 4200 printer paper jam. No paper is jammed
HP 4200 printer keeps getting paper jam error. I open it up, check it, no paper is jammed. I close it back up, the printer prints out the document. After printing about 3 or 4 pages, it keeps giving me the same error. Can anyone help me figure out why this keeps happening?
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    What is the code 13.??
    Sniper:
  • 121 Answers
OK, if the printer says jam but no paper inside and prints after you open and close the cover the paper likely never made it out of the tray. Or the machine thinks the page never made it out of the machine.
As far as input check your rollers 1 in the tray and the pick up roller in the machine if you don't have alot of pages on the machine these likely OK.
Next (and this I have found often) check the paper back stop in the tray. This is the guide to set the length of paper. If it is set just a little long the roller cannot catch the edge of the paper. Sometimes the teeth the guide sets in are broken or worn.
The output would be the sensor in the fuser replace fuser.
Hope this helps
Posted on Mar 09, 2009
  • 34 Answers
Check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
Posted on Mar 14, 2009
What do I do if my printer keeps saying paper jam and there is no paper jam?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Dec 29, 2010 | HP Officejet 4315v All-In-One InkJet...
I am having repeated paper jams in the rear door of y HP 4200. It occurs right when the paper hits the rollers to go into the outbin, and the paper stops and jams in the rear door area. I have to open...
It's been a while since I worked on a 4200. Will it print if you keep the back door open?
If yes, does it jam?
If yes, and it doesn't jam, replace the paper delivery assembly(RM1-0026-040CN)
Dec 23, 2010 | HP LaserJet 4200 Printer
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
Mt HP Photosmart C6380 keeps wadding up the paper and gets jammed. It then says out of paper and when I clear it and press OK, it crinkles the paper to death. Please tell me how to fix this. There is...
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 09, 2010 | HP Photosmart C6380 All-In-One InkJet...
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Paper jam message no paper jam cartridge gets stuck HP 6310 all in one
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | HP Officejet 6310 All-In-One InkJet...
PAPER JAM PRINTER SAYS PAPER JAM IN INPUT TRAYS BUT PAPER DOES NOT SEEM TO BE JAMMING
Dec 11, 2009 | HP LaserJet 4050 Printer
Jammed paper the jam is obvious when trying to slide paper drawer in. Jammed Paper is not visible Lifting movable parts does not expose paper
Dec 07, 2009 | HP Photosmart C7280 Laser Printer
Hp 2355 all in one error message
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP LaserJet 4200 Printer Logo
1,569 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
