Question about Audiovox MMDV70CB Car DVD Player
Movies2go MMDV70C dvd player doesn't work
We just purchased a used Ford Windstar with the above dvd player. How does it work? Does it require a remote? Is there a switch somewhere other than on the player itself that must be turned on? Where can I locate a manual? A remote? The power switch is iffy. Is there more than one function that is powered up by this button? There appears to be a light of some sort in the center of the dvd that does not light. Is this in fact a light and what does this indicate? Thank you.
Jane
Look here for manual:
http://akamaipix.crutchfield.com/Manuals/220/220MDV70C.PDF
Posted on Nov 22, 2009
It's not reading cd, or DVD
Check for scratches on the disk surface - these can inhibit the player from reading a disk correctly.
Some players will read olny certain type(s) of disks. This is an issue mostly for disks created on a computer, not those that are prerecorded and available for purchase or rental that contain movies and music.
As stated above, dIsks created on a home computer may not always be readable on a home player. Re-writeable and recordable types that are not listed as being compatible will not work. Check your manual to see which types are acceptable and not. DVD types are: DVD-R, DVD-RW, DVD+R, DVD+RW and DVD-RAM CD Types are CD-R, CD+R and CR-RW. Older home CD and DVD players generally work with "-R" types and the newer players with both "-R" & "+R" types. "-RW" and "-RAM" types are the least likely to be readable in home players.
Additionally, most players require that disks created on a home computer be "finalized". This is an extra step that isn't required by most CD / DVD drives in computers. Just because it works in your computer doesn't mean it will work in your home player. If you're using compatible media and still not able to read disks, check your CD / DVD recording software options to enable finalization.
Jan 03, 2013 | Televison & Video
We have an audiovox movies2go single dvd system installed in the interior roof of our car. The picture display on the system is not working. You can play a CD in the unit and you can hear it, but not a...
This combo devices have two lenses, one to play CDs and one to play DVDs. It looks like the lens that plays DVDs is defective and will need to be replace.
Try using a lens cleaner. If the lens cleaner does not work, the lens is defective.
If your device is less then a year old, still under manufacturers warranty.
Let me know if you need further assistance.
Aug 21, 2008 | Audiovox Televison & Video
DVD player purchased 8/4/10 will not read disc. Model SD7300. Have used the cleaner disc.
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Regards.
Apr 14, 2011 | Toshiba Televison & Video
I just recently purchased a 2000 Ford Windstar. The headlight on the passenger side will not work. I have replace the headlamp and the fuse to that part....still to no avail...no light. Could you help me...
If you bought your truck at a licensed dealership or used car lot, most states require that if the vehicle will not pass inspection, the seller must repair the vehicle at their expense. First check for corrosion in the headlamp bulb socket. Also check the headlight relay and for damaged wiring between the bulb, relay and fuse box.
Mar 11, 2011 | 2000 Ford Windstar
How do I remove the Radio/CD player
There are 4 holes on the radio (two on each side) that requires a special tool that has to be inserted on each side. You can purchase the tool at auto parts store. Insert the tool and pull the radio out.
Oct 10, 2010 | 2000 Ford Windstar
A light on above spedometer in my ford windstar . it looks like a engine with a fan on front and one on top. just wondering how serious it is. I have stopped driving it.
Based on your problem description, it seems to be like the cooling fans have some problem. Kindly check the functionality of the fans in the engine compartment. If they are working fine, you may required to visit the nearest garage / dealer to fix.
Jun 07, 2010 | 2002 Ford Windstar Cargo
Where is the cd player in my 2001 ford windstar
Depends on the trim you purchased. If a base model, you wont have a cd player, unless requested at time of purchase. But more luxurious models come standard with cd players.
Feb 03, 2010 | 2001 Ford Windstar
The radio with a 6 disc changer stock wont eject cds in my 2001 ford windstar van with double sliding auto open/close doors
Hi
Thanks for using FixYa. Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Use a stiff wire, a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open and remove the CD.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 04, 2009 | 2001 Ford Windstar
Player won't read a DVD
Some DVD players requires installation of software to load some DVD's. Ask your dealer to provide you with a Software CD. Just insert this software CD and then try to run DVD it will work...
Oct 04, 2008 | Samsung DVD-R155
Audiovox MMDV70CB Car DVD Player Logo
615 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
