Question about Sub-Zero 642
Sub-Zero service manual
Where can I find a service manual for the model 642 Sub-Zero refrigerator? The service light is flashing on the display. The word "Ice" is also displayed.
  • gurkenkoenig Apr 20, 2009
    after discovering that my 642 sub zero doesn't make ice I saw a light flashing saying "vacuum condenser" since I didn't have the manual, the old owners didn't leave it, I found this link, model 642 is included:
    http://www.subzero.com/resources/product...
    Problem Solver:
  • 5 Answers
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Posted on Jul 30, 2009
Sub Zero 642 side by side, refrigerator side not working.
If the refrigerator compressor runs and cools when you use the manual activation mode but does not run normally then the control board would be what I would suspect. If it has the manual activation then it is new enough to give error codes. If it is not running and not recognizing it's not running, something is wrong with the control. Unless you are seeing two dashes in the refr display. That would mean the refr section was disabled.
Jan 11, 2016 | Sub-Zero 642
LCD panel and lights not working
On your Sub-Zero 642 Your display will not work unless your refrigerator lights work.
1st. Make sure your light bulbs are good.
2nd. Check your refrigerator door light switch.
3rd. The subzero uses a thermal overload to kill your lights if the door is left open to long.
http://www.on-timeappliance.com/subzero.html
Mar 26, 2012 | Sub-Zero 642
I have sub zero 642 and my techinician says that I need a ice make valve replacement. He says it costs $495, does that seem accurate?
Sub-Zero a hallowed name in refrigeration, and the 642 side-by-side refrigerator/freezer unit is a landmark Yeah, it's that impressive. Dual refrigeration uses two compressors and three evaporators, I can tell you to never expect less than $300 for calling anyone to your home!
Aug 10, 2011 | Sub-Zero 642
I have a ten yr. old Sub Zero model 642. The
maybe a re-gas will last another ten years...if the leak is that small a re-gas will probably last it days out....ask the service man to re-gas it so the food does not spoil until you can save up for replacement...then just see how it goes.
Jul 21, 2010 | Sub-Zero 690 Side by Side Refrigerator
Cannot reopen Sub-Zero 642 freezer door for 50 seconds
Yes, this is normal.  My 642 does the same thing. It seals to be more efficient while trying to cool back down after it has lost heat while open.
Jun 21, 2009 | Sub-Zero 700TR
Sub-Zero 690 Refrig Side Ice Forming on Back Wall
replacing leaking evaporator on Sub Zero Video
Jun 09, 2009 | Sub-Zero 642
Freezer not working on sub-zero 642 model
Remove the top grille and touch the compressor on the left, above the freezer. Is it warm, can you feel it vibrating? If not, your compressor may need to be replaced.
May 10, 2009 | Sub-Zero 642
Ice maker in Sub Zero 642
Call the factory at 800-222-7820 for the manual. It souns like you are missing one or two screws. Pull the ice tray out and lift it up about an inch and it should release. Take a look at the ice maker and there are two supports that both need to have screws on them. There is also a third underneath on some models. Insert the screws and you should be fine.
Sep 16, 2008 | Sub-Zero 642
Refrigerators Logo
1,949 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
