Question about ASUS P4-533 Terminator (terminator p4) Barebone
ASUS P4-533 won't power up.
6 months ago I put away my P4-533, carefully packing it and put it in the garage. It was running properly when I put it away. Today I need a file from it and have tried to restart it. When I hook it up and hit the button, nothing happens at all. No LED light, no fans, no nothing. Am I overlooking something trivial, or what?
  • emcalvin Feb 19, 2009
    The connectors are ok. Same ones I am using on this machine as I write. No fan movement or lights on the machine.
  • 44 Answers
  • 479 Answers
Please disconnect all the connectors and put them one by one and try following DYI
1.Refix the connectors and the check the power is coming.
2.If the power is coming in the machine and the fans are moving then the issue is with the RAM refixing open the cabinet and then refix the RAM module and it will work.
Posted on Feb 19, 2009
Abs problem,garaged tried computer put the lights out replaced a part (copy part)this problem started 6 month ago owned for 6 month
Most common failed part is wheel speed sensor, but read the codes with a GOOD scan tool which can read transmission codes and you should get a clue.
Feb 26, 2015 | Cars & Trucks
Sputtered for a few days, but now won't start at all. Where should I start?
You should have had it properly diagnosed & all
issues resolved six months ago,now you may have
issues you can't afford to repair.
You obviously need professional help from a repair
shop & soon
Do you think 16oz of anything in 16 gallons of gas,
would do anything other than take your money,NO
Jun 11, 2012 | Nissan Cars & Trucks
Engine mis-firing
Mass Air Flow Sensor or Intake Absolute Pressure sensor
Oct 07, 2009 | 1998 Ford Mustang
Rpm's run real high before it shifts
Contact ASUS, and get an RMA (Returns Material Authorization) number, and then ship the motherboard back to ASUS, so that they can fix it or replace it.
Sep 14, 2009 | ASUS Z71 (90-N9Q1G1000) (90N9Q1G1000)...
Car running rough when raining
check the spark plug wires, put water in a spray bottle and spray along the wires,especially by the coil,if the car starts to run bad or you see sparks, the wires are no good, hope this helps, Ray
Apr 03, 2009 | 1999 Mercury Villager
Asus p5p800 motherboard
seem power supply fault, because some times, it looks that power going on, it is not giving proper voltage to motherboard. check other power supply.
Oct 16, 2008 | ASUS P5P800-VM Motherboard
Engine Warning light on rover 75
hi after reading your problem i gather the water pump blew you lost water the car overheated you say it had a brand new cylinder head and the cars still losing water and causing it to overheat and the garage say its the same problem as before yet they won,t do the job because it needs a bottom end ;engine block] so why when they had the head off was this not checked for level and signs of cracking . to be fair to the garage it something that is often overlooked . but that said if this is the problem that occured after three days of buying you are entitled to have the work gaurenteed for 12 months unless otherwise stated i can see there warrenty company won,t want to pay for it as they already paid the garage to do the job [CORRECTLY] the garage had no right to sell a faulty car in the first place and secondly they have been paid by your warrenty company to repair it it is not the warrentys companys fault the garage didnt do what was required in the first place but its not yours either so i would read what your warrenty agreement is and see if it states they won,t pay twice for the same job if not phone them up tell them the only reason you bought the car is because of the warrenty and it is not your fault the job was done properly in the first place and expect the car to be repaired as it should have been in the first place and its up to them and the garage to decide which one of them pays tell them what the garage mechanic said about its allright to drive and i have no idea what book tells you to ignore warning lights but should be shot then go to the garage tell them you want it putting right and you don,t care wheather its under warrenty or the garages oblgation not sell defective vechicles it is up to the garage to put it right or give you your money back if the problem arises within a reasonable amount of time usually seven days tell them to put it in writing if they refuse to do the job if they refuse get a wittness to this and tell them it needs puting right and will be taking to another garage getting it repaired and am giving you the first chance to repair it as stated in law then the bill will forwarded to them an have you took finance out on it or did you pay cash if finance phone them up tell them the problems your having and are going to stop payments until the car is fixed REMEMBER THE GARAGE DEPENDS ON THE FINANCE AND WARRENTY COMPANYS THEY WILL NOT WANT TROUBLE FROM THEM BECAUSE THEY WITH DRAW THERE BACKING THE GARAGE WON,T SELL THER CARS HENCE OUT OF WORK i bet your a newcastle supporter as well with this kind of luck if you let them get away with it your as daft as a brush find out where to report the garage i think it is the office of fair trading and if they won,t bend i will be amazed yates210456
Sep 24, 2008 | 2003 Renault 181
ASUS P4-533 Terminator (terminator p4) Barebone Logo
433 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
