Question about HP Computers & Internet
Bios Password Hello, I have a toshiba satellite A215-S6816 but this dont star because I dont know the bios password, please my friend, I need your help urgent. Ricky
  • HP Master
  • 4,806 Answers
Hi there.
1. Turn the computer OFF, if it's on.
2. Remove the memory module cover, on the bottom of the computer.
3. Check the configuration of memory modules in the two sockets. It's necessary to have a memory module present in the outermost socket only.
  • If there is a memory module in only the outermost socket (the one farthest from the system board), then continue to step 4.
  • If there is a memory module in only the innermost socket, move it to the outermost socket.
  • If there are memory modules in both sockets, remove them both, then re-insert one of them into the outermost socket.
4. Carefully peel back the black Mylar film. Pull this film to the side enough to expose the B500 solder pads. Do not remove the film completely, because it may be difficult to re-attach it correctly.
5. Short the B500 solder pads on the system board. Needle-nose pliers or a flat-blade screwdriver works well to short them.
6. While continuing to short-circuit the solder pads, turn the computer on, and continue shorting the pads until the Toshiba Logo Screen appears. then remove the short.
7. Re-position the Mylar film over the system board.
8. If you removed a memory module, turn the computer OFF, then re-insert it.
9. Re-attach the memory slot cover.
10. turn on computer, if it boot password has been removed.
Good luck and thanks for using Fixya!!
Posted on Feb 19, 2009
Updated my BIOS on my Toshiba Satellite a215-s4747 Laptop, now has a BIOS password I can't work around to boot the OS.
You'll need to Reset your BIOS password. To do this, go to another PC, and visit youtube to find a guide, or ring toshiba support and have them talk you through it.
Sep 07, 2010 | Toshiba Satellite A215-S4747 Notebook
Boot passward issue with Toshiba Satellite A215-S7413
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Mar 13, 2010 | Toshiba Satellite A215-S7437 Notebook
I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
Nov 04, 2009 | Toshiba Satellite A215-S7437 Notebook
I have an Toshiba A215 and cant remember the admin password how can I unlock the system to change my password. I have a toshiba satellite a215-7417 and need to reset bios. I heard something about shorting...
Do not attempt to short out the jumpers on your own. As simple as it is, you can also kill the board. Also, the RTC battery will not effect the BIOS password. Take it in to the nearest Toshiba ASP center and they will reset the BIOS password as well as update it to the latest BIOS revision to avoid it from happening again UNDER WARRANTY. You do not have to pay for this repair.
Mar 16, 2009 | Toshiba Satellite A215-S5822 Laptop
Toshiba satellite A215-S7416 clearing a bios password
Contact Toshiba service they have a special hidden program (rootkit?) they can activate on your PC.
Jan 30, 2009 | Toshiba Satellite A215-S4747 Notebook
Locked myself out of lptop goes strait 2 black & blue screen bios
Ouch, unless you know that password its not looking too good for you. take it into a computer technitian to look at it and they should be able to fix it and get it into working order again
Hope This Helps
Nov 19, 2008 | Toshiba Satellite A215-S4807 Notebook
Toshiba satellite A215-S4807/changed bios pw and cant remember it
no i'm affraid that the bios is locked and you cannot reset, you need the password to access the laptop.
try "toshiba" as the password and see what it does
keep us informed
regards The Fixya Team
Nov 19, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite? A215-S4747
You cant bypass toshiba bios password. U need to bring it to Toshibas Authorized service center. I think this model if free of charge eventhough not in warranty. To make sure , call 18004577777, verify if this model is free of charge.
Aug 14, 2008 | Toshiba Satellite A215-S4747 Notebook
Satellite A215-S7416 Bios Password
There is a jumper that will clear the BIOS password on most of the newer Toshiba laptops such as this model. Here is a link to an article showing where the jumpers are located on various models of Toshiba laptops.
http://www.ccl-la.com/blog/index.php/clearing-bios-power-on-passwords-on-toshiba-laptops/
I hope this helps, if so please rate my solution.
BuddyMc
Jul 17, 2008 | Acer Aspire 3680 Laptop
Toshiba satellite A215-S5818 bios password
I think there is a power on password on it. Please reset it from motherboard. I Think u need to open it. and reset. Take Professionals help if you are not aware of technical details. Else this will damage Motherboard and you no longer you wil be able to use it. Please rate and ngive me feedback
Mar 22, 2008 | Toshiba Satellite A215-S5822 Laptop
Computers & Internet Logo
235 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
