Question about BarcoMed 2MP2 (4 MB) Graphic Card
Not a vaild sync signal - BarcoMed 2MP2 (4 MB) Graphic Card
  • Peter Steiert
    Peter Steiert May 11, 2010
    So, what is it that you're asking?
  • 1,602 Answers
GO INTO CONTROL PANEL, SEE IF YOU HAVE A FOLDER CALLED SYNC CENTER, AND OPEN IT IT WILL TROUBLESHOOT FOR YOU.
REMOVE EVERYTHING AND NEW SOFTWARE GET THE OLD ONE TO WORK AND THAN INSTALL NEW DEVICE AND GO INTO CONTROL PANEL AND ADD NEW HARDWARE
ENTER
ROD
Posted on Feb 28, 2009
Check engine light P336
Are you sure this isn't P0336, P336 is not a vaild code not enough numbers.
P0336 ISUZU - Crankshaft Position Sensor Performance
Possible causes- Crankshaft position sensor harness is open or shorted
- Crankshaft position sensor circuit poor electrical connection
- Faulty crankshaft position sensor
- Signal plate may be damage
- Starter motor may be faulty
- Starting system circuit
- Dead or weak battery Tech notes Sometimes and in some models, low battery voltage or a weak starter can can trigger a Crankshaft Position Sensor code. Before replacing any parts, recharge or replaced battery
Sep 07, 2012 | 2000 Isuzu Rodeo
Where is the cam sensor at
Description & Operation
2.5L Engines
On the 2.5L 4cylinder engine the Camshaft Position (CMP) sensor is located in the distributor.
The sensor contains a Hall effect device called a sync signal generator to generate a fuel sync signal. This sync signal generator detects a rotating pulse ring (shutter) on the distributor shaft. The pulse ring rotates 180 degrees through the sync signal generator. Its signal is used in conjunction with the Crankshaft Position (CKP) sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinders.
When the leading edge of the pulse ring (shutter) enters the sync signal generator, the following occurs: The interruption of magnetic field causes the voltage to switch high resulting in a sync signal of approximately 5 volts. When the trailing edge of the pulse ring (shutter) leaves the sync signal generator, the following occurs: The change of the magnetic field causes the sync signal voltage to switch low to 0 volts. 4.0L
The Camshaft Position Sensor (CMP) on the 4.0L 6cylinder engine is bolted to the top of the oil pump drive shaft assembly. The sensor and drive shaft assembly is located on the right side of the engine near the oil filter.
The CMP sensor contains a Hall effect device called a sync signal generator to generate a fuel sync signal. This sync signal generator detects a rotating pulse ring (shutter) on the oil pump drive shaft. The pulse ring rotates 180 degrees through the sync signal generator. Its signal is used in conjunction with the crankshaft position sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinders.
When the trailing edge of th4.7L
The Camshaft Position Sensor (CMP) on the 4.7L V8 engine is bolted to the front/top of the right cylinder head.
The CMP sensor contains a Hall effect device called a sync signal generator to generate a fuel sync signal. This sync signal generator detects notches located on a tone wheel. The tone wheel is located at the front of the camshaft for the right cylinder head. As the tone wheel rotates, the notches pass through the sync signal generator. The pattern of the notches (viewed counter-clockwise from front of engine) is: 1 notch, 2 notches, 3 notches, 3 notches, 2 notches 1 notch, 3 notches and 1 notch. The signal from 5.7L V8 Engines
The Camshaft Position Sensor (CMP) on the 5.7L V-8 engine is located below the generator on the timing chain / case cover on the right/front side of engine.
Fig.
The CMP sensor is used in conjunction with the crankshaft position sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinders. The sensor generates electrical pulses. These pulses (signals) are sent to the Powertrain Control Module (PCM). The PCM will then determine crankshaft position from both the camshaft position sensor and crankshaft position sensor.
The tone wheel is located at the front of the camshaft (2). As the tone wheel rotates, notches (3) pass through the sync signal generator.
When the cam gear is rotating, the sensor will detect the notches. Input voltage from the sensor to the PCM will then switch from a low (approximately 0.3 volts) to a high (approximately 5 volts). When the sensor detects a notch has passed, the input voltage switches back low to approximately 0.3 voltsthe CMP sensor is used in conjunction with the crankshaft position sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinderse pulse ring (shutter) leaves the sync signal generator, the following occurs: The change of the magnetic field causes the sync signal voltage to switch low to 0 volts
Jun 08, 2012 | 1999 Jeep Grand Cherokee
Where is the camshaft position sensor located on a 06 jeep grand cherokee limited 4.7 l automatic ? ... also the crank position sensor
The CMP sensor engine contains a hall effect device called a sync signal generator to generate a fuel sync signal. This sync signal generator detects notches located on a tonewheel. The tonewheel (4) is located at the front of the camshaft for the right cylinder head (2). As the tonewheel rotates, the notches (1) pass through the sync signal generator. The pattern of the notches (viewed counter-clockwise from front of engine) is: 1 notch, 2 notches, 3 notches, 3 notches, 2 notches, 1 notch, 3 notches and 1 notch. The signal from the CMP sensor is used in conjunction with the crankshaft position sensor to differentiate between fuel injection and spark events. It is also used to synchronize the fuel injectors with their respective cylinders.
May 12, 2011 | Jeep Grand Cherokee Cars & Trucks
Will not regonize computer source
The projector looks for Horizontal sync & Vertical sync signals from the VGA source. If it finds these signals only then the source is connected. Even if the sync signals are found, the RGB switching should be working. Either there is a problem in sync circuitry or RGB switching. You need to be well conversant with the circuitry.
sonsunny
Mar 29, 2011 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Where is the camshaft position senor on a 2000 jeep grand cherokee 4 liter
4.0L
This information is available from the Autozone.com websitecheap_repair_3.jpg
Jan 27, 2011 | 2000 Jeep Grand Cherokee
In a move my NEC MultiSync 5FG monitor got disconnected from its BNC cable (5 BNC). Now I don't know which leads connects to which ports. Can anyone help?
The cable should be labeled with R (RED video signal), G (GREEN video signal), B (BLUE video signal), V (Vertical Sync signal), and H (Horizontal Sync signal), so you just have to match the plug to the sockets.
I hope it is clear explanations.
Dec 31, 2010 | NEC MultiSync 5FG (White) 17" CRT Monitor
I'm trying to sign up but my street address wont work
The console might be having problems validating your address, if it is a Reserve, try an alternate physical address.
Apr 29, 2010 | Sony Playstation 3 (PS3) Console
No signal from hand controller to console
You probably need to sync your Wii-mote to your Wii. Open the battery compartment on the remote and the SD card door on the front of your Wii. Press the red SYNC button on your Wii and then on the controller. You know it is synced when a solid LED light is shining at the bottom of the Wii-mote.
Jan 25, 2010 | Nintendo Wii Console
Waiting for a vaild GPS signal. three days. been
You essentially have to reset the GPS. You can do this by holding the power button down for at least four seconds to get the Tom Tom to fully shutdown. You will know you successfully did this if you hear the tom tom sound and a warning message appears during startup. It then seems to work just fine after that.
Apr 08, 2009 | Tomtom XL 330 Car GPS Receiver
Component Video losing sync with too much White signal
I had this exact same issue. I tried two different component AV switches, and shorter cables to prevent signal loss, but any time there was too much white on the screen, the video still lost sync. Plugging the sources directly into the TV solves this problem, but since I have a DVD player, a game console, etc, this was not acceptable. The way I resolved it was to (sadly?) buy an expensive component AV switch that can support the bandwidth without losing the signal.
I wound up spending the extra money on a Key Digital 4x1 component switch. It is much more expensive, but it works.
May 02, 2008 | Onkyo TX-SR604 Receiver
BarcoMed 2MP2 (4 MB) Graphic Card Logo
65 people viewed this question
Top Barco Computers & Internet Experts
David Payne
David Payne
Are you a Barco Computer and Internet Expert? Answer questions, earn points and help others
