Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
ESTA DEMASIADO LENTA MI HP C4180
CUANDO ENCIENDO MI HP C4180 ME SALE Y QUE.. ALINEAR CARTUCHOS..LE DOY OK, Y DEMORA PARA LA ALINEACION, CUANDO TERMINO TRATO DE SACAR UNA COPIA O IMPRIMIR Y ES FULL LENTO,, QUE PUEDE SER
pineworks
  • 4041 Answers
SOURCE: no permite imprimir
Hi you could try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
SOURCE: error 6911
You'll have to use google.com to translate this because I don't speak Spanish, but I used it to translate your text into English.
What you're seeing is PostScript being output to a non-PostScript printer. Mac OS 9 LaserWriter driver prints only PostScript. Make sure you've downloaded the correct driver from HP, and then make sure you're selecting the HP driver in the Chooser.
Please let me know if this information helps or not.
Posted on Jul 16, 2008
  • 104 Answers
SOURCE: mi hp deskjet f380 no es compatible con vista
El driver para Vista se puede encontrar aqui:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=1128296
Se necessita sacar el driver de XP y hacer la installacion de Vista driver
JOAT
Posted on Oct 16, 2009
pineworks
  • 4041 Answers
SOURCE: Tenho HP 3110, falha para imprimir
All the best
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Posted on Feb 13, 2010
puertobori
  • 7733 Answers
SOURCE: buenas cordial saludo alas
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Dec 03, 2010
Acer veriton z291g se apaga sola cuando entra al sisitema escritorio
hola amigos, es la primera vez que respondo en sitios (y ami que? diran, ps nada ya ven que todo dicen lo mismo) .
ok yo teni a el mismo problema con la acer veriton le di muchas vuletas, pensando en virus o si era alguna parte interna.
lo que hice fue entrar a la bios y desactivar el shutdown en el regulador de energia. si hay una opcion en ingles. esta enable solo pasenla a disable o algo asi,, y bueno es una solucion que doy, al menos a mi me funciono. espero que les sirva. y pasen el conociiento
Jul 10, 2012 | Cars & Trucks
Saludos, mi endeavor tiene Una vibracion fuerte cuando va de 20 a 40 millas.
saludos, tengo una mitsubishi endeavor 2005, la cual me estaba dando exactamente ese problema, cuando iba acelerando entre 20 y 40 da una vibracion muy fuerte, el problema esta en la transmision, eso lo causa la falta de liquido de transmision, cuando a la transmision le falta liquido hace ese fallo para indicarte que le falta y que debes completarlo, mi recomendacion es que lo revises lo antes posible y que le heches un aditivo para transmision, hice eso y se le quito inmediatamenteee, cuando la revise estaba seca no tenia casi nada de liquido de transmision.
Feb 04, 2012 | 2005 Mitsubishi Endeavor
Trying to change colour cartridge but comes up with message " Remove and check colour cartridge"
ok les cuento nuevamente tengo una impresora Hp photosmart C4180 all-in-one le instale el cartucho negro y el de color recargado o bien generico y me derramo por todas partes tinta incluyendo las tarjetas el problema que me esta dando es que no me enciede la pantalla ni mueve el carro donde van los cartuchos de tinta quesiera saber que puedo hacerle para resolver este problema ya que la desarme por completo la limpie todita y aun persiste el problema. me pueden ayudar por favor , Gracias
Mi correo es Dennisemilianofloresolivares@yahoo.com
Oct 11, 2010 | HP Photosmart 4180 All-in-One Printer
1. se enreda el hilo abajo y se rompe el hilo de arriba. 2. muy baja tensión del hilo de abajo. está en el límite de ajuste. Ajusté la bobina y mejoró pero sigue con el problema...
Hola! Espero que puedo ayudarle con su problema--pero, como hace mucho tiempo que no escribo en espanol, por favor, tenga paciencia conmigo.
Muchas veces ese problema de enredar el hilo del abajo resulta de la presencia de pequenos pedacitos de hilo en esa zona. Use un pequeno cepillo para saquar toditos.
Generalmente, no hay que adjustar la tension de las canillas (bobina?). Adjuste al punto que hay un poco de tension cuando jale un poco al hilo.
Casi siempre adjustando la tension de arriba solucionara todo.
Use hilos de diferente colors en la canilla (bobina) y arriba. Tambien, es major usar un aguja nueva. Usando un pedacito de su tela normal, empieza a coser. Cosa unos centimetros, y pare para cequear. Siempre adjuste la tension con la pie prensatelas abajo.
Si se ve el hilo de abajo (el del bobina) en la parte superior de la tela, el hilo superior esta demasiado tenso. Gire el equilibador de tension para disminui el numero.
Si el hilo superior esta demasiado flojo, se ve el hilo del bobina en el lado inferior de la tela. En ese caso, hay que amentar el numero.
En todo caso, hay que hacer las correciones lentamente,
Sequn mi guia, se rompe el hilo de la aguja:
1. No esta enhebrado correctamente 2. La tension del hilo de aguja es excesiva. 3. La aguja esta despuntada o doblada 4. La aguja no esta bien colocada. 5. Los hilos de la aguja y del bobino no estan bien colocados debajo del prensatelas al empezar a coser 6. La tela no se ha extraido hacia atras al terminar la costura 7. El hilo es demasiado grueso o fino para la aguja.
Ojala que eso le ayude y que mi espanol no esta demasiado feo.
Robbie
Feb 22, 2010 | Kenmore Sewing Machines
Compaq deskpro EN
mi compaq deskpro pentium iii enciende y se queda contando la cantidad de memoria..y luego se reinicia..y cuando le doy a f10 me dice que el cmso tiene problemas, y le he quitado la pila y el jumper pero todavia sige igual, y le he dado al boton que esta en el board que dice CMSO , pero no se arregla nada
Sep 26, 2009 | Compaq Deskpro EN PC Desktop
Problem with my dvd player
Estimado, tenes que correr la llave que esta a la derecha y colocarla en OUT, con eso ya te va a funcionar
Saludos
WP
Sep 27, 2008 | Sony DVP-FX810 Portable DVD Player
LEXMARK X3550
Quite los cartuchos. y asegúrese que las pequeñas cintas protectoras han sido quitadas de los contactos. Entonces examine donde los cartuchos caben en la impresora. ¿Es limpio en allí? ¿Hay allí alguna tinta secada o gotas de la tinta en allí? Si hay, usted puede apagar y desenchufar la impresora y usar una cantidad diminuta del alcohol desinfectante en un Qtip para limpiar la tinta.
Si no sustituyen los cartuchos que se los aseguran adecuado cómodamente. Ahora continúes su computadora a - Principio> Panel de instrumentos> impresoras y faxes> chasquido DERECHO en su icono de impresora y elija preferencias> servicios. Cuando usted está en servicios abiertos y mira cada opción allí. Haga cualquier prueba o limpieza de los cartuchos a los cuales esto le pregunta. Cuando usted es terminado, apaga su impresora y reanuda su computadora. Si el problema no es ido, contestarme. Espero que mi español sea comprensible. Gracias.
Aug 19, 2008 | Lexmark X3550 All-In-One Printer
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
354 people viewed this question
Ben Johnson
