Question about Whirlpool LER5636P Electric Dryer
Dryer is working but not heating
Dryer hose is not clogged and neither is dryer itself air is streaming out outside of vent at very high rate but is cool not hot in other words when i put setting on high heat nothing happens but cool question is there a heating element that can be replaced as in water heaaters or is it more trouble than its worth...
  • Itry2fxit1st Feb 22, 2009
    I have an 11 year old Amana (Whirlpool) electric dryer (Model LE8517W2). It also does not heat any longer. After resetting the circuit breakers for the dryer (even though they did not look tripped) and after cleaning out all the lint build up I could find in the dryer, I removed the heater assembly (which has the thermal fuse & thermostat mounted on it) as well as a separate secondary monitoring device (either a secondary thermostat or a moisture sensor for non-timed degree of dryness shutdowns?) that was mounted in line with the exhaust vent just past the blower. I brought them all to my local appliance parts store where they found all but the heater assembly mounted thermal fuse to be in working order. I bought a replacement fuse (I would have replaced the thermostat at the same time, but it was unavailable. So in lieu of unnecessarily replacing the entire heater assembly ($70) I just got the fuse. I didn’t want to buy an unneeded part as they don’t take electric parts back as returns). I replaced the bad fuse & reinstalled the heater assembly and the exhaust monitor. I ran the dryer for a few minutes. The heat was there, just not super hot. I placed a half load of towels in but it did not dry them properly even after a few hours. In your opinion what should I do next, replace the entire heater assembly or perhaps just the thermostat? It should be noted that before we lost the heat entirely the first time the dryer seemed to run forever before shutting down. The auto shut off seemed to be malfunctioning. The clothes were dry possibly an hour before it ever shutdown. I am not sure what is used to detect the level of dryness of the load whether a moisture sensor (surmised earlier) or what have you, but whatever it is, it doesn't seem to be working properly any longer. I am not sure if this could be tied to this problem or not but the cool down period seems to have stopped working altogether as well. When we opened the door to remove the clothes they were so hot I thought they could have possibly caught fire if they were left in for much longer. So much so that metal buttons and zippers would nearly burn you if you grasped them. I was wondering if this second issue (bad moisture sensor for auto shutdown) may have caused the first (no heat) due to excessive running times. Your thoughts? Thank you. (Needless to say I don't leave the house with the dryer running for fear of a fire.)
  • 188 Answers
There is a heating element which can be replaced but first check the home's electrical fuse panel or reset the breaker even if it doesn't look like it tripped.
If you have 240V going to the dryer and still no heat it could be either the element, thermostats, timer or wiring.
Whether it's worth the trouble depends on the age of the dryer and your investment of time and money. None of those parts would take longer than an hour to replace. If you want to tackle it let me know and I could try to guide you through it.
Posted on Feb 20, 2009
Dryer does not dry well , an the turn knob does not turn while the dryer is on towards turnning off.
Lint Trap
The lint trap is a metal screen with a plastic handle that is located either near the corner at the top of your dryer, or inside the dryer door. In most cases, the lint trap is clearly marked. If your clothes are not drying properly, this is the first place to look because it is the easiest problem to solve. Remove the lint from your lint trap, and then see if your clothes get dry. If they do not, move to the next troubleshooting problem.
Vent Hose
To work properly, a dryer needs to be able to vent warm air. If the vent hose is clogged, bent or has a hole in it, your dryer will not work properly. Examine the vent hose to see if it is installed completely over the dryer exhaust vent, and to make sure it does not have a hole in it. Remove the vent hose to see if it is clogged. There are vent hose brushes you can purchase to clean the vent hose properly. Also check the exhaust vent on the dryer and the outside vent to make sure they are not clogged.
Thermal Fuse
If you have been running your dryer with a clogged vent hose for a while, you may burn out the thermal fuse. A burnt thermal fuse will allow the dryer drum to rotate, but the unit will not heat up. Your owner's manual will show you where the thermal fuse is and provide the part number you need to buy to replace it. Thermal fuses are available at most hardware stores and are easy to replace.
Heating Element
The heating element is the long, coiled wire in the dryer that heats up the air. Over time, the heating element can burn out or become defective. In some models, the heating element can be repaired; in other models, the heating element should be replaced. Refer to your user's manual to see where your heating element is and whether you can repair it or need to replace it.
Jan 09, 2013 | Dryers
My Amana electric dryer, Model # NED4500VQ0 is not heating clothes enough to dry a load in one cycle. I changed the thermostat already. The back glows orange and is heating. I figure it has to be the...
Not sure about the hh limit or the element, but make absolute certain that there is good flow of air. Check to see if the vent is clogged. Remove the hose from the back of the dryer and see if air is flowing very hard. Use a vacuum cleaner or a wire or something if it is clogged. Similarly, check the hose itself. If the hose collapses when you attach a vacuum to it, it is clogged. Dryers require heat AND air flow to dry properly. :)
Mar 22, 2012 | Amana Dryers
Hi Our Bosch dishwasher (sms63e09uk) has E:01 displayed on the digital control panel. What does this mean and how do we rectifiy the problem
It means the machine is not getting enough water you need to replace the water inlet valve, that is very possible try cleaning it and see if that helps.If it does not then the problem is the water valve.Which is a very common problem.
This air flow error code refers to the dryer vent. This can refer to the dryer's lint screen, the thermistor behind the filter, or the vent itself could be clogged.
In order to determine which one is the problem we will need to gather some information.
1. Will water pour through lint filter's mess?
2. Outside where the unit vents on the side of the house can you feel air coming out?
3. Is the vent hose on the backside kinked or clogged?
4. Obstruction on vent housing outside (if screen is present on outside remove right away this is a fire hazard.)
Water should pour through the lint filter easily. Fabric sheets will put a layer of wax on the lint screen causing the dryer air circulation to be cut off. We should be able to feel warm, moist air at the vent outside. If air is not present you are in need of a dryer vent cleaning. A kinked or clogged vent hose can also cause the E01 error code. Ensure the vent hose is clear and placed in position with as few bends as necessary. When the vent is clear the E01 error should clear itself upon start up.
Hope helps.
Apr 02, 2011 | Bosch Dishwashers
Dryer over heats
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
This is a FREE answer, Please rate me
Dec 12, 2010 | Kenmore 62602 Electric Dryer
Dryer is taking multiple cycles to dry average weighted clothes/
Make sure the dryer heats up and that the proper cycle is selected. If the dryer doesn't heat, the cause will need to be determined. This can be an ignitor issue, the timer, or a gas supply problem.
If it's heating, check the vent line from the dryer to the outside of the dwelling for lint clogging. Also check the diverter (flapper valve) at the dryer vent outlet to be sure it opens all the way and that the air stream is pretty strong. Lint clogging is one of the most the most common causes of dryers not drying very well or taking an extended drying time period.
If the vent line is longer than 20 feet and has multiple bends, backpressure in the line can cause additional clogging.
Jan 25, 2010 | Whirlpool LGR3624JQ Gas Dryer
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
I have whirlpool dryer that the heat seems to kick on and off it is gas dryer
If heats for a few minutes then cuts off (heat) , then the 2 coils on the burner valve are probably bad . OR check the vent hose to the outside for good air flow . Sometimes , a dryer is pushed too far back , and it kinks the vent hose . If coils are bad , when dryer cools down , then restarting , cool coils will heat again for a few minutes , then stop heating till they cool off again .
Aug 01, 2009 | Dryers
Low heat output
A clogged or partially clogged vent . Especially if vents up thru the wall . If it vents straight out , make sure you have good air flow to the outside . Make sure the vent hose has no sharp kinks also . Try drying a load with the vent hose disconnected from the dryer . If clothes dry fine , that tells you the problem is elsewhere . Normally , a dryer either heats or doesn't heat . A heat for a few minutes then stops heating but continues to run complaint ,would be bad coils on the gas valve .
Jul 19, 2009 | Dryers
The dryer will not heat up
you may have a clogged vent. Make sure the exhaust vent is clear and full air flow is coming out on the outside wall (should be a fast stream of air). if not will need to clean it out.
If this still does not work then you may have a thermal fuse blown on the heater duct. This will require a repair call for a local Service man.
Apr 05, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool LER5636P Electric Dryer Logo
79 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
