Can i clean the filter of my aquarius wash system plus WM 65 ?
If so where do i find it please
  • 112 Answers
Most washing machines have a screen at the water hoses. Remove the hoses on the back of the machine and remove the screens inside. They can be cleaned and reused.
Posted on Feb 19, 2009
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
Clean Filter?
There is a filter at the rear of the washer.
Remove lower rear panel.
Remove large black hose from bottom of drum.
Remove and clean filter in inside hose.
Remove hose onto pump and check for blockage oe obstruction here as well.
Please rate my solution.
Jan 27, 2010 | Hotpoint -Ariston Aquarius WD645 Front...
Won't spin out at end of wash cycle code is OE
Please clean the filter.
Filter is behind the little door located on the front left corner of the unit.
Please read the owners manual for proper cleaning.
If filter is clean the drain pump may have failed.
Jan 16, 2010 | LG WM-1832C Front Load Washer
Hotpoint 6kg Aquarius , pre wash keeps flashing, so it is not washing......can you help
Check and clean the pump filter.
Remove lower rear panel of washer, remove large black hose on bottom of drum,remove and clean filter inside, alsr remove hose onto pump, and check for obstruction here and in the pump.
Nov 11, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Does the Aquarius 100 wm 25 have a filter?
you'll need to take the bottom rear panel off and remove the retainer from the rubber hose attached to the bottom of the drum.
it's like a plastic basket inside.
Feb 28, 2009 | Washing Machines
Does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
Feb 08, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Aquarius wash system plus wm 63
First of all lay the drain hose into a bowl or bucket to drain off.
Then take off the plate at the back of your machine and you will see a pipe running from pump to drum.
Where it meets the drum there is a filter inside which you can check for debris. also take off at the pump and check inside pipe & pump.
Happy to help further if required.
Thankyou for using Fixya.
Jan 29, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine not draining therefore not spinning
You will find the filter located inside the large black hose at the lower right rear of the m/c.
Remove lower panel and you will see the hose there.
Undo the large clip and remove hose and clean filter.
Plz rate this solution
Dec 19, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wm63
The heating element for this paticular model is located on the front casing of the drum.. you have to remove the front panel complet with the door and you will see it at the bottom behind a black protective cover.
Nov 27, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
