Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Leaking ice maker.
I woke up thhis morning and my floor was covered in water. I noticed that my refridgetor was leaking where the ice maker dispense the ice so i shut of the water supply to the ice maker and it stop leaking. Can you tell me what is my problem?
  • hammondathen Feb 19, 2009
    Is that expensive to have replaced?
    President:
  • 1,902 Answers
Sounds like you have a bad inlet valve that is staying open and is not closing letting water run through the system all the time. The valve is located next to the Ice machine water line
Posted on Feb 19, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 19, 2009
    No pretty cheap you can get it at repairclinic.com
Kenmore model 106.72009010 leaking water onto floor
Defrost is not working and that is causing the leak.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Water leaking from Icemaker fill tube near the back wall
It probably is not the water valve. More likely it is the ice maker itself. Nothing else in the machine controls the flow of water to the ice maker except the ice maker itself. It is recommended that both the ice maker and the water valve needs to be replaced when trouble such as this.
Dec 12, 2012 | Refrigerators
I have an old GE fridge with ice maker in freezer, water started leaking and flooded floor of freezer and started leaking outside freezer. What's going on & how do I fix it?
I think you need a new fridge/freezer. Look for offers now on sale some are quite reasonably priced and home Depot has interest free credit.
Sep 19, 2017 | GE Refrigerators
I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
Nov 14, 2010 | Jenn-Air Refrigerators
Water leak from freezer
Two possibilities. Water leaking fro ice maker or the drain is blocked behind the back panel inside freezer. I will send links soon on how to fix it. Sea Breeze
Jul 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool side by side (ED5VHGXMB10) Not ejecting Ice
take and power off the unit for 5 seconds and then see what happens,
Apr 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water and Ice maker problems
sounds like you water lines may be kinked or clogged.
follow you water lines and see if there is a kink in the line that would be the easiest thing to check first.
Jun 02, 2008 | Amana ACD2232HR Side by Side Refrigerator
Ice maker leaking
there should be white cover on that ice maker assy. it will pry off with a small screw driver and underther should be an ajustment screw. it should be a turn screw marked with a + and -. if so turn to the minus side of line, half turn should be plenty of adjustment,very small increments, do not over adjust
Mar 05, 2008 | Refrigerators
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
187 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
