Question about Bose Lifestyle 20 System
NO CLOSED CAPTION WITH BOSE RECEIVER HDMI
I AM USING A BOSE LIFESTYLE 20 SYSTEM WITH SHARP AQUOUS 65" 1080P TV. THE BOSE TO TV CABLE IS HDMI. I HAVE CONNECTED A SATELITE RECEIVER TO BOSE USING COMPOSIT CABLE. I DONOT GET CC WHILE WATCHING SATELITE PROGRAMMING. BOSE TELLS ME THAT HDMI DONOT PASS CC SIGNAL WHICH IS ANALOG. THEY SAY IT IS NOT THEIR PROBLEM AND ALL RECEIVERS WILL DO THE SAME THING. THAT SOUNDS DUMB. AS A TEST I TRIED USING COMPOSIT CABLE FROM SAT RECEIVER TO BOSE AND FROM BOSE TO TV AND THE CC WORKS BUT THE PICTURE SUCKS.
ANY ONE KNOWS WHAT IS GOING ON ? ANY WORK AROUND ?
JOE
SOURCE: Sony Audio Optical Out to Bose Optical In not working
Set the source for Optical-In on the Bose system to TV
Posted on Feb 17, 2008
  • 34 Answers
SOURCE: Apple TV and Bose Home Theater
You should be able to connect hdmi from apple tv to bose v30 for picture and sound. You can also run component video to bose and a hdmi out of bose to tv. Just make sure your running hdmi out of bose system to tv if your tv supports hdmi if not use component video cable. Another way which isn't as good of quality is to run fiber optic from apple tv to bose v30 and hdmi straight to tv.
Posted on Nov 07, 2008
SOURCE: Bose Lifestyle V20 - no video out, no response to remote control
check the voltage setting on the power supply that connects the power cord to the media center. Mine was set to 230V. Changed it to 115V and the video starting working.
Posted on Dec 07, 2008
SOURCE: System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Posted on Feb 05, 2009
SOURCE: audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Posted on Dec 28, 2009
I try to plug apple TV to my Bose sytem lifestyle 20. The apple TV is plugged by hdmi on my TV (hdmi2). The apple tv image is good but the sound is coming from my tv not from my bose system. i decided to...
You might want to try connecting the Apple TV to your TV using HDMI, then using the optical cable from your TV to your Bose system. In your TV's settings, there should be an Audio Output option. You'll want to turn off the TV speakers. Optical audio can be a little strange compared to traditional analog. If your cord is going bad, it could result in behavior like you described.
Jan 24, 2011 | Bose Lifestyle 30 System
I have v 20 Bose system all HDMI connections I
Did you find a solution ? I have latest Sharp LCD and Sharp BluRay and separate Video&DVD player - would you recommend purchasing the V20 ? Is the quality good ?
Dec 08, 2009 | Bose Lifestyle V20 System - black Theater...
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Bose Lifestyle 38 connection to TV doesn't work.
Is your tv hooked up to your cable box or satellite with an HDMI cable? There are several ways to input to the TV.
Aug 30, 2009 | Bose Lifestyle 38 Series IV DVD Home...
NO CLOSED CAPTION VIA BOSE LIFESTYLE 20 SYSTEM
CC is a function of your cable box in this case. TV's have the feature as well, but Bose is right about not all HDMI devices supporting CC through HDMI, especially converting from component to HDMI before hitting your TV. The solution: call your cable provider for this. Start at the source. The cables you use or the TV won't 'take away' closed caption if it's already there.
Feb 19, 2009 | Toshiba MW20FM1 20 in. Combo
HDMI cable between TV and Lifestyle 28
Did you set up your bravia TV to receive pictures throuh HDMI ?
Dec 28, 2008 | Bose Lifestyle 28 System
Jul 19, 2008 | Bose Lifestyle V20 System - black Theater...
Lifestyle 38 and HD
I have also have this problem with a lifestyle 28 system. Bose sent me a new cable then a software update. The problem remained, after contacting Bose and unplugging cables and powering down the system this solved the problem. However 2 days after and the problem has re-appeared. Back to square one. I should add that this is the second unit I have had the retailer exchanged the last one because of the same problem.
Apr 08, 2008 | Bose Lifestyle 28 System
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Bose Lifestyle 20 System Logo
134 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
