Question about Ricoh CL4000DN Laser Printer
Error message "replace black pcu"
the printer is still operating like normal. We do not know where or what this unit is
Photo Conductor Unit. Instructions come with the replacement. Installs from left side. Read instructions carefully.
Posted on Mar 06, 2009
SC 491 error message
sc 491 is error signal is detected for 0.2 seconds when charging the drum or development.
• High voltage leak
• Broken harness
• Defective drum unit or development unit
• Defective high voltage supply unit
Oct 19, 2016 | Ricoh Office Equipment & Supplies
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
Ricoh Aficio AP3800c--message to replace black PCU, have done same and still get message?
This must be done before drum is replaced.
Resets counter.
Start the SP mode and execute the
New Unit Set:
• PCU: SP5-999-001 ∼ 004
Feb 03, 2010 | Ricoh Aficio AP3800C Laser Printer
On a ricoh aficio 3500n color laser printer getting a replace black cpu error after changing the black cartridge. How do i take care of this?
replace the black pcu(drum unit).
the life of the pcu(s) are 15k each(blk & col) .
the machine will work but copy quality will reduce and the error will be there.
replacing the cartridge has nothing to do with this error.
Jan 14, 2010 | Ricoh Aficio CL3500N Laser Printer
Error message: replace pcu
I believe its asking you to change the photo conductor unit. From what I can tell there are 2. Theres a black photo conductor and a color photo conductor. If its not telling you which one you should be able to print a supplies status page and you can see which one needs to be replaced. I'm not totally familiar with the machine but the PCU's should be located in the cartridge area. I just checked out our supply catalog and you should be able to order them from any office supply store or Ricoh dealer. Just a heads up..from what I'm looking at the black pcu is pretty reasonable, but the color one is $300 plus! For your sake I hope its the black one that needs replacement! You should be able to verify the error message in your user manual and more than likely find the part number for ordering.
Jul 08, 2009 | Ricoh Aficio CL3500N Laser Printer
Error message
the pcu stands for photo conductor unit it is more commonly known as the drum.
Jan 13, 2009 | Ricoh Aficio AP3800C Laser Printer
PCU Replacement
You are more right than you know, the reason for the kit is for the reasons you said. When you change the kit all 3 colors are new and thereby not 3 service calls and 1 upset customer.
The kit is far cheaper and keep any "good PCUs" in the original package.
The black PCU is the most important one. Buying the different maint. kits saves $$$ as opposed to peicemeal.
You can put one color PCU in at a time if you wish.
-Carl, please let me know if this helps.
Apr 28, 2008 | Ricoh Aficio CL7100 Printer
SC 441
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
Gettin a Error: replace Black PCU.
Hi yes you can fix it yourself it is just a warning that says the black pcu is almost warn out , but if the quality is still good you can clear the message is the sp modes by holding down online and escape whilst switching on the machine , under the menu "engine " is a sub menu called data log enter it and execute pm counter reset
hope this helps
Oct 15, 2007 | Ricoh CL3000E Laser Printer
Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Nov 10, 2006 | Ricoh Aficio CL2000 Laser Printer
Ricoh CL4000DN Laser Printer Logo
283 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
