Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Cold water will not flow into machine
Cold water will not flow into the washer on any cycle. The filters are not clogged because they have been removed. Even on the "warm accuwash sensor" setting the hot runs while the cold mix does not.
  • Whirlpool Master
  • 3,361 Answers
Replace the water inlet valve.
Posted on Feb 22, 2009
Why is the water not filling in my washing machine
There are screen filters at the inlets on the machine where water hoses connect. When they get clogged the water flow is slowed.
Dec 13, 2014 | Samsung WA5471AB 27" Top-Load Washer, 4.7...
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
THE SCREEN SHOWS IE
Hello there and thank you for choosing fixya
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
And finely if all of this does not work then the inlet valve on the machine needs to be replaced ok?
Hope this all helps
Aug 05, 2011 | LG WM1814CW Front Load Washer
What is problem code IE and how do I fix it on my LG front load washing machine?
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. if this doesn't help then there are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg
Hope this helps.
Mar 09, 2011 | LG WM-2277HW Front Load Washer
The machine is indicating an IE fault
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly wm_inlet_filter_removal(1).jpg
Mar 02, 2011 | LG WD-1280FHD Front Load Washer
Washer will not fill with cold water. Warm and hot cycles work well. When you start the cold wash it fill for a few seconds and then it stops.
Check your cold water inlet for water flow. The filter screen might be clogged with debris. If there is no debris, you might need a new water inlet valve. It relatively inexpensive and easy to change. You can find them at any appliance supply outlet.
Sep 23, 2010 | Frigidaire GLTF1240A Front Load Washer
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
Is there a cold water filter on this machine. The
there is often a screen located in the hose end ... you can clean, replace or remove the screen and always replace the hose washers but its far better to replace both hoses with good quality new ones .. the safe lifetime of the hoses is only a few years ... so its a good idea to replace them every few years anyhow ... while you have the hoses off you can check water flow to make sure the shut off valves are not clogged .. (make sure they were both fully "on" to start with) .. if there is good water flow and the screens are not clogged then you may have a clogged solonoid valve (just inside the machine at the water inlets) (has wires going to it also)
Oct 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Very slow cold water fill, why?
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Cold water input only works intermittently
Replace the water inlet valve. You can get one at your local appliance store. Or at repairclinic.com. Easy to replace and can be done by just about anyone
May 18, 2009 | Kenmore 15864/15862 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
prem mathew
