Question about DFI AK74-SC Motherboard
Bios failure, or what?
Subject: PC won't boot (BIOS error?
I have an older PC that all of a sudden won't boot up.
It never seems to start into the windows load, just displays:
Award BootBlock Bios V1.0
copyright (c)2000, Award Software, Inc
Bios ROM checksum error
Detecting floppy drive A media
insert system disk & press Enter.
The first time it failed like this, I didn't have a boot disk, so simply
tried
Reset (several times)---same result. Tried forced power down, then turn
on again,
same result. Then I left it on, went on to set up another PC to try to
do
some productive work. After several minutes, the unit started up
voluntarily.
This happened another time, after letting the machine set off for several
days.
Now I can't get it to boot at all.
I tried to boot from a 3 1/2 floppy, after the initial failure.
Failed with new message: AWDFlash.Exe not found.
I don't know where to go with this either.
I do not know the motherboard manufacturer. The PC was built originally
by a local
company named Computer Peripherals Unlimited Inc.
I am running MS Windows XP Home Edition.
There is a label on a mobo connector that reads as follows:
AWARD 1998
pci pnp 686
265067673
I don't know whether to suspect hard drive failure, BIOS failure, or
what.
I came to you based on the "BIOS ROM checksum error message.
Any Ideas?
Thanks in advance, Bill Linhardt
  • DFI Master
  • 4,806 Answers
Hi there.
Try clearing the cmos
Bios failure, or what? - d015d7b.jpg<<<<< you will see in the picture a plastic jumper (in this case coloured green), move it to the other position and hit the on/off button, then put it back in its original position and power up the machine again. Hopefully the issue will have been sorted. If there is no jumper remove the battery for an hour and make sure the power cord is removed from the back before you clear the cmos
Good luck and thanks for using Fixya!!
Posted on Feb 19, 2009
  • 741 Answers
Here's a website where you can download AWDFLASH.EXE to flash the BIOS...that should take care the boot problem.
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
Sep 22, 2012 | HP Pavilion dv9000z Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
On booting it shows Intel AMT Error - Aborting, after a while it then shows 2207 AMT connection failure after which it finally boots to windows. its a hp compaq desktop dc 7700p mini tower convertible bios...
When you boot your computer, you need to hit the key to get you into the bios setup. F10, F2 or Del keys are the usual ones.
Once into the bios, change the boot order to make the CD drive first, and then you will boot right to the CD.
Note, you will also have to hit a key when it starts to boot, it will say, hit a key to boot from CD.
If you miss the key to get into the bios, you have to start over again. Sometimes you have to hit the enter bios key over and over to get in there.
Source : AMT Error
Aug 13, 2012 | HP dc Computers & Internet
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Blinking battery power LED
Battery
Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock
CPU
CPU not functional
Blink: 2 - Caps Lock/Num Lock
BIOS
BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock
Memory
Module error not functional
Blink: 4 - Caps Lock/Num Lock
Graphics
Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock
System board
General system board failure
Blink: 6 - Caps Lock/Num Lock
BIOS
BIOS authentication failure
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
I have an ei system 103a desktop i have had to sytem restore now when i turn pc on it tells me to press f1 to start windows i have tried going into the bios and boot from hardisk but still have the problem...
The 'Press F1 to continue" message is a result of an error caused as the BIOS does its hardware checks during the boot process.
The BIOS boot process (bootstrap) preceeds the loading of the operating system.
The most amusing example of this occurs if you unplug a ps2 keyboard,
1, it generates the error
2, pressing F1 does no good because the keyboard is not plugged in.
3, if its ps2, you will need to do a hardware reset after plugging the keyboard in again.
The bios can be set to 'halt on'
'no errors' which will stop the error message appearing.
'keyboard errors' see above
'all errors' any hardware failure detected by the bios will halt the boot process and give the above message.
Mar 11, 2009 | Computers & Internet
I need to know the signs of a BIOS failure
you should be getting error messages
Oct 09, 2008 | Computers & Internet
T23 BIOS error code #05
are you getting a date & time error ?. you could always try just resetting the bios.... remove the bios battery AND the battery itself for about five minutes or so. install it all again and boot up.
Robert
Aug 27, 2008 | IBM ThinkPad T23 Notebook
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Media test failure
Do you have the PXE error?
The media failure is in the boot sequence, on the toshiba press F12 on boot to change boot priority, select cd/dvd or hard drive, or to preclude from happening, press F2 on boot enter BIOS, select Boot options make sure to set priority as cd/dvd, then hard drive, then network or disable network boot. network booting causes media failure.
Mar 20, 2008 | Computers & Internet
DFI AK74-SC Motherboard Logo
429 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Matthew Spark
Matthew Spark
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
