Question about Valeo Speed Jump Rope 1 Pk
How do you adjust the valeo speed jump rope for your height?
  • Anonymous Mar 02, 2009
    Yup! I have the exact same issue. It says "adjustable" but without instructions, I'm not sure how to do it.
  • Anonymous Apr 05, 2009
    my jumprope was a little bit long for me when i got it, but now about 2 months later, it somehow magically got wayyyy shorter! its way too short for me, and im only 5 feet tall! and it doesnt come with instructions. Someone please help!
It's simple, really.
At each end of the handles, you'll see a black cap. You can use a flathead screwdriver to go right in the crack of it, and pop it out. You then take the black rope, pull it out, and move down the silver piece until it fits your height. If you're like me, you'll need to cut some of the rope so it will fit in the handle. After you have adjusted it to the right height, snap the black caps back in.
Posted on Apr 08, 2009
  • normzee Nov 27, 2010
    How did you all configure the end that you trimmed? I knotted it but then the rope looses its ability to turn smoothly.
Apparently there are different versions of this rope, as I read from a customer off Amazon. Yeah, easy enough to pop off the end caps, but I suspect many out there have the same model that I have, where you can't just push the rope out the ends of the handles. There's something that blocks it from moving more than an inch or so. So far I'm trying to grab the ends with needle nose pliers, but even those aren't skinny or long enough. So it's not really that "simple."
Posted on Aug 01, 2010
    Problem Solver:
  • 5 Answers
Pull rope out hard. Using screw driver remove bearing by flipping it out. Then plyers to unsquueze metal clamp, shorten rope, re-squeeze clamp, put back thru handle, push bearing back into handle and done. V EASY.
Posted on Feb 15, 2012
Pliers! That was the key for me, use pliers to pull tight rope out of handle. The silver clamp will still be bent so the rope wont slide back through. I used the pliers to slightly "untighten" the clamp by squeezing it opposite of ****. After adjusting the length I used the pliers to once again tighten the clamp at the proper length of rope. Cut the access rope and reassemble the handle cap. Done!
Posted on Mar 16, 2011
  • jjfar Mar 31, 2011
    look to see if there is a hex nut on the side.
    if so loosen this nut pull rope thru and tighten.
    hope this helps
How do you adjust the champion adjustable jump rope? No instructions on product.
http://punkrope.com/how-to-size-a-jump-rope/ have the same product and i found this extremely helpful video :)
Jan 24, 2013 | Champion Adjustable Power Jump Rope
I just bought the Weider Beaded Jump Rope and it is too long for me is there a way to shorten it without ruining it?
if you're careful and crafty you can try to take the beads off the rope and use a scissor to cut the rope to your ideal height, If the jump rope isn't constructed to be disassembled or you don't wanna take the risk, try tying a knot on both end of the handles to shorten the rope. btw you probably know this already, but when trying to determine the length of a jump rope you should stand on the center of the rope and make sure each end of the handle reaches your armpit or at least your chest
Jan 16, 2013 | Weider Jump Rope, Beaded, 1 rope
Are there different names for jump roping?
Jump Roping can also be called skipping, rope skipping, or rope jumping. Skipping rope is generally the British way to say it, while Americans say Jumping rope.
Jan 03, 2013 | Exercise & Fitness
Are there different types of jump ropes? What is the difference between them?
There are speed ropes, cloth ropes, and beaded ropes.
speed are a cost effective and easy to adjust style of jump rope, Beaded ropes are the most durable jump rope style suitable for any environment but they are the best rope for outdoor and colder weather use. Cloth en cloth ropes are the finest quality ropes on the market.
Aside from it benefiting my health, what kinds of benefits are associated with jumping rope as an activity?
Jumping rope can increase your coordination, speed, balance, agility and rhythm.
Aug 26, 2012 | Cobra Exercise & Fitness
What is a jump rope?
A jump rope is a ropewith two handles that is held in each and hand and rotated at varyingspeeds. The holder then jumps over therope each time it comes around.
Jul 09, 2012 | Exercise & Fitness
My jump rope came all rolled up in the package. Now it wants to stay in the twisted shape it was when I got it. The result is that I can only jump a few times before it twists on itself and trips me or...
the only thing that I can think of doing is to hang the jump rope over a beam in the house or garage and tape light weights to the handles and let it hang there for a day or two,,, this should straighten out the rope. NOTE : when hanging the rope over the beam -- take a towel and fold it up many times and place this on the beam first before you put the rope on it,, this will make sure the rope takes a nice slow gentle bend down to the floor ( not creasing it ) ---if a beam is not availible you could get the same effect by drapping it over a closet/bedroom door --- don't forget your towel ).
c...
Jan 19, 2011 | Valeo Speed Jump Rope 1 Pk
Donkey kong slipshyde ride i cant get past this level
Animals - None
Enemies - Army, Klap-Trap, Necky, Zinger, Kritter
Bonus Levels - Three
Animal Tokens - Enguarde, Expresso
- K -
Slowly walk ahead until you see the jumping Kritter. Jump on him when you get under the high rope and ride up, jump to the left and use ther barrel to break the wall and enter a bonus level. You have to spell out KONG. The prize is an Expresso token. After exiting, jump off and jump onto the two Kritters. Jump onto the rope. At the top, jump off, pick up the DK barrel and kill the Army with it. Jump onto the rope, and when you get to the top, jump off and you will land on the K
- O -
Run to the right and jump onto the rope. In the middle there is a barrel. Choose Diddy before you pick it up. Jump down and break it into the left wall to enter the bonus level. In this level, you have to spell out NINTENDO. You win a red balloon if you do this. After the bonus level, run right, and kill the army, and jump over the Zinger onto the rope. When you get to the top, jump onto the left rope to avoid the Zinger, then the right, then the left. Jump to the left, and if you want the banana bunch, kill the Necky and jump up there. Go through the small gap, and jump on the Army if you got Donkey. Jump high on the rope and quickly jump to the other side. Walk down the slope and jump on the Kritters. Jump on the first rope, go down a little, jump to the second then quickly jump onto the third tope and into the checkpoint barrel. Walk left and avoid the Klap-Trap, jump onto the rope and into the auto barrel. wait until a jumping Kritter comes. Jump on him, then climb the rope to get the O and two banana bunches.
- N -
Jump back down and run to the right, avoiding the two Klap-Traps. When you get on the rope, on the first three ropes, jump immediately to the right. But on the fourth rope, wait and then jump back onto the third rope to reach a bonus level. Go to the far right rope, watch out for the three Zingers. Jump to the right and get the N.
- G -
Take the DK barrel, and throw it on one of the two Zingers. Go above or below, depending which one you hit, the Zinger and jump on the rope, and jump to the left. Take the rope to the top, and then take the six ropes and jump to the left. Then jump the rope and jump to the other side. You should be next to the red arrow now. Jump onto the two down ropes. Always hold up during this section. Hold northwest and northeast depending which rope you are on. When you reach the top, jump over and hit the G. Run to the right and Exit.
Nov 30, 2008 | Nintendo Game Boy Advance SP (Japan...
Valeo Speed Jump Rope 1 Pk Logo
5,112 people viewed this question
Top Valeo Sport & Outdoor - Others Experts
Are you a Valeo Sport and Outdoor - Other Expert? Answer questions, earn points and help others
