Philips HTS3565 DVD is stuck in standby. Tried unplugging unit and still does not work..
  • levek1 Feb 19, 2009
    Yes there is a Dvd in the player
  • 19,396 Answers
That means that the player is in protect mode.
When a device goes on protect mode that means that a faulty component had been detected.
The device must be taken apart and inspected by a technician to fix the problem.
The only reset you can do are the following:
1 Leaved the DVD unplugged a couple of hours.
2 Hold down the start menu for three seconds while you plug power back.
If that does not work, then the DVD is faulty, and must be repaired by a competent tech.
Posted on Feb 19, 2009
  • 479 Answers
If CD is stuck,then try with any small pin inserting by side but remember that it should be going in side after pressing eject button.
If the player is in warranty then tray stucking is solved and covered under warranty.
If neaither condition is working and applicable then it could be taken out by opening the case only and do it only when you are familiar with internal assembly otherwise contact any repair man.
  • 4,806 Answers
Hi there.
It may be in protect mode, to clear this unplug the power and leave it off for at least and hour to reset itself.
If it doesn't work please post back
Good luck and thanks for using Fixya!!
    Sergeant:
  • 250 Answers
Tap the sides of the unit slowly and keep the unit on while tapping it.also manually try prying the door to remove the cd.after removing shut off the unit for couple of minutes and check out.
  • 10,594 Answers
Seems HTS3565 has got problem in amplifier out section and goes to protect mode to avoid further damage.
Qualified tech can fix it easily.
    Genius:
  • 1,550 Answers
Is there any dvd inside your player ?
  • SAM ANDERSON Feb 19, 2009
    Press power, and quickly press the eject button of the
    player couple of time so that it ejects dvd stuck in .
    If you have tried this then unplug your unit from power chord . Manually remove the dvd by opening the panel of player and take your dvd out .
    You are facing this due to hardware failure which can be due to
    • dead laser diode
    • a defective controller ic
    • Faulty capacitor in the player .
    You need to take to service center to service your unit .
    Hope this helps .
Just like everyone...came home all of a sudden the unit won't turn on ???? standby light is on but nothing..
In addition to just unplugging the unit, another method that worked for me when unplugging it did not was to unplug the HDMI cable from the TV and then unplug and replug.
Jan 03, 2010 | Philips SoundBar DVD Home Theater with...
STANDBY LIGHT KEEPS BLINKING
Unplug the power cord, wait for 5 minutes, plug the power cord back in and try to operate the unit.
If this does not work, you will have to get a technician to look at it for you.
Please rate this solution - THANKS
Dec 26, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
The system is stuck in mp3 mode and will not eject or accept a dvd.
i took it a part and sprayed some air on it then i put it back together and it worked not sure why though
Jul 23, 2008 | Philips HTS-6500/37 System
Stuck on standby
if you cant get it to work will you be will to sell the remote let me know needs one bad cant play my mp3 on it anymore email me at josocuervo@yahoo.com
Nov 09, 2007 | Memorex MVD2042 DVD Player
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Philips dvd player not working
Im sorry to tell ya that you did all the things I would have suggested, so it sounds like a system control problem or a power supply problem, and if its a good machine then maybe its worth you having a service person look at it?? Most dvd units are not worth it these days, unless there combos or recorders.. Sorry couldnt be of more help.
Jun 05, 2006 | Philips DVP630 DVD Player
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
