Heaters
Problem for Heaters
Generic problem for all Heaters
Hi, my problem is i have gas (propane) to ...
By steelersf664 on Feb 19, 2009
hi, my problem is i have gas (propane) to the valve ,it has electric ignite , also hook up to a remote system i do not have the remote, there is a bypass setting,the igniter works still no pilot light.i have held a lighter on the thermocouple to force air out to bleed lines ,it made some clunking noises but no results, it seems that i cant get gas past valve.i just had to replace the outdoor regulator, system has not worked at least for 2yrs it never worked for me after i bought home
Solution #1
posted on Mar 08, 2009
Not Rated)
hvac teacher
Rank: Guru
Rating: 90%, 53 votes
The gas company should have have set and adjusted the gas pressure when they installed the new regulator. DO NOT ATTEMPTED TO LIGHT THIS WITH A LIGHTER. If this furnace has a hot surface igniter you and you lighter will be energized with 120 volts...BE CAREFUL...
If this furnace has a spark igniter you and your lighter can be lit up with up to 10,000 volts.
Since this furnace sat inoperative for so long I will bet that you have a blocked pilot assembly. Turn off the power and the gas. Carefully remove the pilot assembly. Dismantle it. Inside you will find a very small orifice Clean it out. Put every thing back together. The furnace should work.
REMEMBER PROPANE GAS IS MORE VIOLENT THAN NATURAL GAS KEEP YOUR FACE BACK AWAY WHEN IT LIGHTS IF YOU WANT TO KEEP YOUR EYEBROWS.
The clunking noise you heard was probably the gas valve trying to open.
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
best heater for a 5,000 square foot monolithic dome
Answer
how can you buy things for less than what they ask for?
Answer
model #5500 quit heating. checked outlets, lights up, but doesn't heat. worked less than 24 hours... (More)
Answer
dimplex heater switch insert
Answer
dimplex insert switch for a heater- 120 voltage #12
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
in , CA
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
