Question about KitchenAid Dishwashers
Squeeking, swaking door springs
When the door to the dishwasher is opened all the way, the door springs squeek and squauk very loudly. What must be done to fix?
  • 4,806 Answers
Hi there
Thats a common problem with sprung door hinges, get some WD-40 lubricant spray and spray the spring until the squeaking stops.
Good luck and thanks for using Fixya!!
Posted on Feb 19, 2009
My dryer is squeeking when turned on and stops when the door is opened or it is stopped. what could cause this?
most dryers have drum rollers and an idler pulley. either of these could be squeeking. it also could be the motor bearings going bad.
May 24, 2010 | Maytag Dryers
I have a loud squeeking noise coming from my tv even if the tv is on mute how do i fix that horrible squeeking?
Take ur tv aparts.On the FBT,the big black block of plastic with a red wire with a cap hook to a CRT(tv tube.On the big plastic block it have a small piece steal "3 inches.Put some super glue on that will stop the squeeking.
Mar 16, 2010 | RCA 27F530T 27" TV
Dryer was making loud squeeking noise then quit tumbling. The spring was not attached. How do you reattach the spring?
You can try to bend it to get it to work, but get a new one, the old one has lost it's tension and is fatigued and the other part of the spring is somewhere in the dust.
Feb 28, 2010 | Washing Machines
How do I keep the door from squeeking when I open or close it?
Lithium grease or lubricating silicone spray.
Sep 16, 2009 | Dishwashers
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
Sep 09, 2009 | GE Dryers
Loud squeeking coming from the belt area
you'll have to the belt if the belt is old.
also, a temporary solution i learned that gets rid of some of the noise is to slowly pour a pitcher of water on the belt while the car is on.
Jun 30, 2009 | 1992 Plymouth Voyager
Loud squeeking noise from front end
check the belts and lake sure they are snuggly
Oct 12, 2008 | 2001 Chevrolet Blazer
Constant squeeking from drivers side rear wheel
cheap pads will squeak or it might need to be backed off on the adjustment
Aug 17, 2008 | 2003 Jeep Grand Cherokee
Door noise
Common issue with this dishwasher. Easy fix though!! KitchenAid uses a nylon string that connects the hinges to the springs located along the bottom edges of the dishwasher. I had to pull mine out to perform this service. The nylon string seems to dry out and vibrates as the door opens and closes. All that needs to be done is put some Vaseline or other appropriate lubrication all over the nylon string. Especially where it passes through the roller and stationary guide. That will take care of any squeeking or grinding when opening or closing the door. Be careful as your door will now open just like it did when it was new. Now if I can only figure out how to keep my door from popping open during wash cycles!!!
Apr 02, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
420 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
