Question about Hoover Nextra HNL 3166 Z Front Load Washer
Washing machine The washing machine will not take the powder or the conditioner Hi, my hoover washing machine won't take the fabric conditioner, it's about 18 months old. I've checked the pipes at the back i.e cold water inlet valve turned on fully and waste pipe not kinked or trapped. Any idea's. Regards Craig ( hoover hnl 6166 optima) Hi, my hoover washing machine won't take the fabric conditioner and have tried everything the draw works just no water go's into the conditioner compartment
  • 2 more comments
  • petri84 Mar 21, 2009
    I don't think the problem is in the pipes or such. Machine should flush the compartment with shower. My problem seems to be that the shower comes in only one of three compartments. Any idea where to look the solution?
  • Anonymous Apr 21, 2009
    I have the same problem with the Hoover Nextra 6 HLN7146
  • brownegirl Apr 21, 2009
    I have the same problem with the Hoover Nextra 6 HLN 7146 washing machine.
  • mark ogilvie
    mark ogilvie Feb 12, 2016
    clean the draw take it out pull out thr blue fill level part there you will see a hole that maybe blocked give the draw a good clean replace the blue fill level run it under a tap keeping it level turn tap off and see if there is any suction you should see the water draining out
  • Hoover Master
  • 744 Answers
Hoover washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
    New Friend:
I had the same problem. It was the solonoid for the cold water inlet. The conditioner solonoid also has since gone. Replacement dual cold water / conditioner inlet part was under $30 from Stokes
Posted on Nov 10, 2012
  • 77 Answers
-the conditioner compartment may be blocked
- the cable with spring that change course of the water may be out,
Posted on May 08, 2009
2 Suggested Answers
SOURCE: washing machine
i had the problem of my brand new washing machine not taking the conditioner and the customer service advisor rightly guessed that i was using concentrated liquid and advised me to dilute it with warm water then put it in the drawer because sometimes the liquid is too thick for the machine to take.try this!!!!! regarding the powder why not put it directly in the machine or buy tablets and do the same with those
Posted on Sep 10, 2008
Excell 7 VarioPerfect: fabric conditioner compartment will not drain
perhaps you need to contact Bosch website for tech support
Sep 21, 2016 | Bosch Washing Machines
Gunge in door seal samsung Q1233 washing machine
It's caused by using too much soap powder or fabric conditioner,it doesn't get rinsed away properly and goes greasy & slimy,,,,,if its starting too smell change door seal,,,,,use bicarbonate of soda 1 or 2 times a month, no clothes or detergent,& on a 90 degree wash,,,that should stop it returning
Jun 19, 2013 | Washing Machines
Hey, in which dispenser number do you put washing powder and fabric softer 1 or 2? Thanks
1 is usually for pre-wash, 2 for washing powder and fabric softner goes into the section with the level indicator should be small square section with removable top.
Feb 28, 2011 | Hotpoint Ariston AW125 Front Load Washer
I have recently bought my hoover optima washing machine which i am happy with. The problem I have is the centre recess for fabric conditioner does not drain and holds water full to the top even when the...
Hoover optima washing machine
This video will show you how to keep your soap draw clear and how to service the parts.
a 4 THUMBS rating is appreciated for answering your FREE question..
Feb 07, 2011 | Hoover Washing Machines
Samsung Washer,less than year old. Not every load and not every item but periodically something will come out with stains not previously on the item.
This is common, if the machine does predominantly COLD washes.
Over a period of time, there is a build up of soap scum (washing powder/fabric softener etc) inside the machine, caused by using excess soap powder/detergent.
To recitfy this, fill the empty bowl (no clothes) with a solution of HOT water & CITRIC ACID (found in the baking isle of your grocery shop) on HI Water level. Set the machine to wash cycle, then drain.
Fill again with same solution, but leave solution inside the bowl overnight.
Drain next day, then follow with 1 single HOT wash (no clothes) on HI water level again.
The scum should be gone...
The hot flush should be done at least every 6 months, but this can be dramatically reduced if you use less soap powder (Samsung machines do not require as much powder, as do other machines)
"If this has helped you, please rate this solution"
Nov 29, 2009 | Samsung Washing Machines
Hi there, my machine is about 6 years old-I have never had a problem until recently my clothes were coming out of the machimne with scum on them. I got soda crystals and put the machine on a 90 wash which...
I read about liquid detergents and fabric softners not being the best to use in the machine so I used powder for the first time the other evening and the smell seemed to ease a good bit. its not gone fully but I will continue with the powder and see how I get on.
Nov 01, 2009 | Hoover H120M Front Load Washer / Dryer
WASHES BUT WILL NOT SPIN
if it,s 7 years old. you,ve had your moneys worth. Scrap it and buy a new one.
as a repair solution, Check that the machine is emptying.
And that the pump has,nt got a coin/badge or anything else wedged in it.
Mike @ Compurepair.
Feb 25, 2008 | Washing Machines
Washing machine
Dec 18, 2007 | Hoover PE235 Front Load Washer
Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
Hoover Nextra HNL 3166 Z Front Load Washer Logo
1,078 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
