Question about Blanco 157-090-CR Rados Kitchen Faucet Chrome w/ Black Pull-Out Spray
On and off handle becoming very stiff
Hard to manuver the handle. Thanks.
  • 547 Answers
Change the insert or washer thank you for useing fixya please rate me
Posted on Feb 26, 2009
Turning faucet on has become stiff and there is water leak at hinge
turn the utility water off at the mains
remove the handle and the tap insert
go to the local hardware shop or plumber supply with the insert and get a new one
the problem is that the shaft corrodes and jams up and the
"O" ring is hard and along with the corrosion will not seal off
best fix is a new insert
Apr 18, 2016 | Plumbing
Toilet handle sticks
It sounds like the nylon nut which holds the handle in place is too tight. Try loosening that nylon nut just a little to see if the handle moves easier. Sometimes if they are over-tightened, the handle will be stiff and hard to operate.
Apr 10, 2014 | Home
Stiff cold water handle bathroom Hansgrohe
If the handle is hard to turn it is most commonly caused by water deposits in the handle or in the cartridge below. I would try removing the handle to ensure it turns freely when not installed on the faucet. If not you can clean it with CLR to remove the water deposits that are making it difficult to turn. If the handle turns freely when not installed you will need to remove the cartridge and inspect it to ensure it is not broken or damaged in any way. There could be debris in the cartrige that has either made it hard to turn or broken the ceramic disks. Our handles are easily removed by turning the bell shaped ecutcheon below the lever or cross handle. There are not set screws that hold them on. If you need further information feel free to call me at 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
Aug 07, 2012 | Hansgrohe - Lavatory Faucet - Centerset -...
Handle very stiff, hard to operate. Hard to pull up to open tap. It is 10 years old and has been used very seldom. I can get the handle off, remove the U clamp, but can not pull out the spindle, or...
You need to purchase a moen puller it can be purchased from most supply houses such as Home Depot or Lowes and as you tighten it up it pulls out the cartridge.
Aug 29, 2011 | Moen Home
Really stiff turning. I am looking at a 2008 CBR 600 on craigslist and when I took it for a ride, the handlebars were extremely stiff. It's hard to describe, but when doing a tight turn the handlebars...
take a riding course... the instructor will tell you to push the handle bar to the opposite side you are turning when running about 30mph and you really dont turn the handle bar when turning at a high speed. in low speed, handle bars should not be very stiff. maybe check tire pressure.
Jan 15, 2011 | 2008 Honda CBR 600 RR
Maytag MDBF750AWZ, Quiet Series 200 - sticking, stiff door handle
There are lot of handy sprays available. Try your super market or the hard ware stores where plumbing materials or sold.
May 03, 2010 | Dishwashers
I replaced the cartridge on my Moen single handle kitchen faucet (the old cartridge had become quite stiff). Everything went back together fine. Now however there is alot of slack in the handle when the...
You need to get the handle back on properly there is a groove on the handle that connects to the top lock nut older models had a chrome nut newer ones had a black plastic one
Nov 17, 2009 | Plumbing
The faucet handle has become stiff to turn off and on, and to switch between cold and hot. I have loosened the screw with an Allen key, but cannot remove handle.
The handle has build up in it but should come off eventually. Sounds like a dry o-ring seal. You can purchase a kit for your model without having to replace the whole unit.
Jul 03, 2009 | Blanco Classic Single Handle Faucet with...
Single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
Apr 22, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Power steering
Check your power steering resevoir and make sure it's full. Check for leaking hoses.
Oct 06, 2008 | 1993 Nissan Maxima
Blanco 157-090-CR Rados Kitchen Faucet Chrome w/ Black Pull-Out Spray Logo
295 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
