Can you remove hotpoint bwm 12 washing machine filter
Is the filter on hotpoint washing machine bwm12 removable
  • 32 Answers
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Posted on Feb 19, 2009
Can you remove a filter from a aquarius washing machine
Posted on Nov 10, 2010
Something I is stuck inside the drain outlet hence wont let me open it. It only allows about a 1/2 turn before it ceases/ blocks against whats inside. Can I access the pump outlet from elsewhere
This is an easy task if you can pull the machine from under the worktop and tilt it back so it is at an angle (unplug it first ) remove plastic plinth get washing up bowl remove the three screws round the filter at this you will find the pump is now loose if shake pump so that any thing inside will move and keep trying to unscrew cap this method works I've done it loads of times to replace pump back line up the screw holes insert screw.then check your pockets evertime you wash
Aug 04, 2016 | Hotpoint Washing Machines
Bwm 129 intergrated will not spin out the water from the clothes and all the water does not empty from the machine
Check the pump is not jammed/blocked also filer which is located within sump hose bottom middle of machine
Jul 12, 2010 | Hotpoint BWM12 Front Load Washer
Selector switch keeps clicking round after 1-2
is there any flashing lights? there should b or some lights are staying on, this will b a fault code, repost the lights or pattern and i will try to find the result for you.
Apr 07, 2010 | Hotpoint BWM12 Front Load Washer
Hotpoint bwm129 wont finish a cycle. super wash and rinse hold lights are flashing.have checked pump for obstructions and waste pipe. any suggestions?
Have you checked the filter? even if the pump is o/k, if the filter is blocked, it will not empty..
If filter clear, then you have a more serious problem.
Hope this helps.
Dec 02, 2009 | Hotpoint BWM12 Front Load Washer
I have a hotpoint bwm 129. clothes arnt coming out clean.
is it rinsing okay is it pumping ok if not clean filter located at sump hose
Sep 30, 2009 | Hotpoint BWM12 Front Load Washer
MY HOTPOINT BWM12 1200 SPIN WON'T DRAIN,
You need to check and clean filter first.
You will find the filter is normally located behind a removable plastic cover at the front right side of the m/c.
Make sure the drain hose is not kinked or restricted..
Make sure you have not selected rinse hold..
Obviosly make sure pump is actually working.
Plz rate this solution .Thanks.
Dec 24, 2008 | Hotpoint BWM12 Front Load Washer
My washing machine..hotpoint bwm12
If you need a manual type HOTPOINT USER MANUAL in your browser bar.
Click on hotpoint web site and then user manual and download your model.
Dec 14, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint BWM 129 washer
ARE THE PADDELS BREAKING OR MELTING.
Jul 16, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint BWM - very noisy but not walking accross the floor!
Remove the back of the machine to expose the inner drum pulley. Need to know if this pulley is rotating and if there is any side to side play.
The noise you are discribing does sound like a rear bearing that is mounted in the external tub housing. Depending on the age of the machine, this bearing is NOT replacable. The outer tub must be replaced because the bearing is molded into the drum.
Jan 02, 2008 | Hotpoint BWM12 Front Load Washer
Washing Machines Logo
742 people viewed this question
Top Washing Machines Experts
