Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL won't spin or drain
The repair man just left w/out wanting to fix it. I advised him of the warranty and even had to copy it for him. He told me probably clutch replacement and that includes outer basket/ Is this 1 piece? I am waiting for a call back about what is covered, he made sure to advise me that parts would take a rreeeeeeeeeeally long time. I want to be well informed when they call bame back. Of course he pointed out the rust on the clutch I was wondering if should try to wd-40 it first? There is a non visible leak that "caused " the rust.
  • 335 Answers
If you are handy you can drop the clutch out and inspect, if the spring is not broken and the bearings clean up like mine did you may get back in service with little cost just some cost saving DIY time. A couple other Forum members were luck like me and a clean and re-lube with WD-40 did the trick, no hard failure of the clutch. As I mentioned back in mid Dec 08 I may need to re-lube down the road with some bearing grease. I’m over 40 loads since my fix in Dec. Grab the manual if you haven’t all ready form this site “Tips and Tricks” and see if you feel OK to dive in. Can save yourself some $ for labor. See this link for couple other forum members that had success. Worse case you order the clutch and replace.
Read through this post of inf. At the end I placed a couple of links of other forum members who save big $.
http://www.fixya.com/support/t1612027-maytag_neptune_fav6800aww_wont_spin
Posted on Feb 19, 2009
  • 360 Answers
Go to this site (click -->here<--), type in your model #, here you will find the exploded view of your unit and pricing for parts and be able to determine shipping costs and delivery times as well as other useful information..
No, the clutch is not part of the outer basket
Hope this helps.
please take the time to give this solution a fix ya rating.
clarkco
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Machine does not drain and spin at 33 minutes left in cycle. Seems to spin, then stops, spin then stops
It is a computer problem. My daughters machine did the same thing and the company came out and replaced the computer board and it fixed the problem.
Jul 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune TL ( Model # FAV6800AWW) washing machine does spend but clothes still soak after it done. when you spend it by hand, it only spend in counterclockwise.
Any error codes. What happens if you start a Spin Only Cycle witht the same load? Does the times stay stuck at xx minutes in the LED display and the machine constantely starts and stops?
The more info on your problem the better.
Do you want to DIY the fix? Google this; Neptune TL Washer FAV6800AWW see the 5th post down here for general info and the Service Manual. If you want to try to DIY the repair I will help.
Apr 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Continue to receive a "DC" code on the Maytap
I no longer post on this site no way to post a Sticky.
If you want to DIY the repair Google this phrase ""Sticky: Neptune TL Washer FAV6800AWW""" Read the post Part 1; DC or UC unbalance error codes in Spin Cycle what is causing this issue? Part 2 for the fix action.
Post your issue in the repair forum not in the Sticky. Please include your Model Number i.e. FAV6800A or FAV9800A and I will help you.
Jan 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune tl fav6800aw top loader sounds bad and wont spin or drain half the time any ideas were to start. It is about 4 years old
Sorry I missed your post I feel I can help you if you want DIY the fix. From your description it sounds like you have a Clutch malfunction see this post Clutch Fix for support.
Let me know if I can help you thru the issue………Rich
Jun 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Have a maytag neptune TL water will not drain and on the panel it shows dc
I feel you are experiencing a clutch malfunction if your machine is a FAV6800A or FAV9800A. Can you confirm the machine model number and let me know if you want to try a DIY repair.
You only need basic hand tools and skill sets to repair and I will help you with the fix. See this post for what is involved and this a most recent post of a forum members repair for a dC error code condition in Spin Cycle. I’m an owner with solid repair skill sets of the machine standing by if you want to repair and save your machine and $$$…….Rich
Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Not draining completely
Clutch Fix
Hello surfsmitty68 ,
A couple of questions;
Is the machine failing to spin with error codes such as dc or UC? If not are there any error codes to the LED console display on spin cycle failure? If there is a blockage in the drain pump/drain line you would fail with a ND error code.
Do you want to DIY the repair once we get going or do you want to call in a repair service? See this post Clutch Fix to see what is involved to re-lube/replace the clutch in the FAV6800AW or FAV9800AW TL. If you or someone has basic mech. skill sets you can do this it’s just a tight work area. But let’s get some feedback from you before we commit to a clutch issue.
Here are some handy links; The Service Manual for reference. Sears Parts Direct for reference.
Post back if you have questions or concerns I’m a owner like you. Let me know what I can do to help…. Rich… aka dh1200s.
Nov 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
449 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
