Question about Amana RanARG7302 Gas Kitchen Range
How to replace a baking igniter in an Amana ARG7300W oven.  Need a diagram of the connnections and process to replace the igniter.
  • maryr566 Feb 26, 2009
    I have the same problem... please help!
  • 999 Answers
The ignitor has 2 wires on it and they are interchangeable. Eric
Posted on Jun 20, 2009
How to test amana bake igniter
bad control board if ignitor works on broiler
Jan 24, 2013 | Amana AOGD2750 Gas Double Oven
The to oven bake doesn't work but the top Broil works. What ever brings on the igniter for the bake isn't working because I get ne power to the egniter. I don't have a wiring diagram to check any futher.
I replaced my Amana Gas wall oven Model AOGD2750E Lower Oven bake Igniter and temp sensor but still not working. I'm Thinking maybe the relay module is at fauly, Any suggestions, I need help!. Thanks
Jan 27, 2011 | Amana AOGD2750 Gas Double Oven
My husbad had sent out an email of our problem that we are having with our range. I am not seeing that there was a response. Is it possible for someone to assist us? I turn on my oven but it does not heat...
Hello Kim....Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. Other reasons that your oven may not bake are: The clock settings are incorrect (if you have timed baking or a self-cleaning oven). The thermostat is defective. The safety valve that prevents accidental gas flow is defective. The selector switch is defective. That said, if you want to see excellent diagrams of all of the parts of your stove, go to searspartsdirect.com Enter the model number and these diagrams will appear for your use. You can also order parts from that site, although your local appliance parts store may be less expensive. Joe Thanks for choosing Fixya!
Jan 13, 2011 | Amana AGDS902 Gas Kitchen Range
Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Feb 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
Broiler works Bake Oven doesn
The first thing to check is the oven igniter, check for spilled foods on igniter and clean if necessary
Dec 12, 2009 | Televison & Video
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana agr5735qds oven will not light.  broiler works as do all the burners.
There are two igniters in your oven one for bake and one for broil. The bake igniter very likely needs to be replaced. Igniter part number is 70080764.
Dec 13, 2008 | Amana AGR5735QDS Gas Kitchen Range
Amana Range ARG7300W -- igniter problem back??
I am sure you noticed where it is located. A gas oven cycles the same as an electric. depending on the number of times the door is opened and the length of time you operator the oven. Our furnace was acting up one night last winter and I turned the oven on warm with the door cracked open until I could get the part for the furnace in the morning and our igniter went out on the oven. Also try not to touch the element on the igniter when you install the new one.
Dec 02, 2008 | Amana RanARG7302 Gas Kitchen Range
Amana RanARG7302 Gas Kitchen Range Logo
520 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
