Question about Lexmark T630 Laser Printer
My printer is a Lexmark T 630's on your display an error message "202 paper plunged back tray open" and that has no role and no arrest or plunged ajunde please me..
Could you list all of the values you see in the secondary error code? You can see the values by doing the following:
1. Press and hold Return and press Select to enter for sub error codes.
The first screen of information displays. Write down the information.
2. Continue pressing Return and Select until each screen of information is obtained.
3. When the last screen displays, the original message displays.
Posted on Mar 10, 2009
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
34 short paper error
This error message means that the printer has determined that the length of the paper in the source specified on the second line of the display is too short to print the formatted data. For auto-size sensing trays, this error occurs if the guides are not in the correct position.
Please try to do the following
• Press Go to clear the message and continue printing. The printer does not automatically reprint the page that prompted the message.
• Make sure the Paper Size setting in the Paper Menu is correct for the size paper you are using. If MP Feeder Size is set to Universal, make sure your paper is large enough for the formatted data.
• Press Menu to open the Job Menu and cancel the current job. Please see also the media guidelines on the user manual p.29
For further assistance, please contact Lexmark Technical Support.
Apr 21, 2011 | Lexmark C543DN Laser Printer
Error message says "Paper tray
If printer is connectedto a network, type the printer IP address into the address field of your Webbrowser. Click on Configuration and select on paper menu and make you have thecorrect settings. Make sure you selected the correct paper source and papertype. Make sure on yourapplication, the print settings matches with the printer. Check the printsettings of the application that you are using. For example if you are usingMicrosoft Word, you need to click on print and click the properties button andgo to the paper tab. From the Paper Tab windowyou can modify the Input options like paper and the source (paper tray).You may click on the drop down and select "Automatically select" for paper trayand select "Use printer settings on paper type and then click OK. For further assistance,please contact Lexmark Technical Support.
Apr 08, 2011 | Lexmark X500n Color Laser All-in-One...
Printer Error message : Printer Error has occurred. 6000
Error 6000 gets displayed when there is a paper jam or other general malfunction. When the message "6000 Printer error has occurred. Turn off the printer then back on again. If the problem persists, see the manual." Is displayed, something may block the paper feed tray from opening.
If the printer is surrounded with documents or when you copy large documents such as books, make sure that you secure the clear space in front of the tray before printing / copying. When the error message above is displayed and if you find something is in front of the tray, remove it. Then, turn OFF the printer and back ON again and the printer will be ready for printing.
If you still have the trouble, contact the repair service.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
Dec 21, 2010 | Canon Office Equipment & Supplies
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jul 22, 2010 | Lexmark X646e All-In-One Laser Printer
202 printer jammed error message appears, but could not locate
Here's an article in the Lexmark website on Error: "201 Paper Jam" or "202 Paper Jam". This will guide you on where to locate the cause of the problem. Follow the instructions. But if you're having a really hard time locating it or you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jun 28, 2010 | Lexmark C762dn Laser Printer
Get the error message change tray to plain letter
Most probably the paper tray guide is not set properly. Here's a link to the Lexmark website to guide you on what to do when having an error like this. Just click on this link: . You can move the paper tray guide back and forth and setting it to the correct size.
Apr 08, 2010 | Lexmark Optra T610 Laser Printer
I have an lexmark 630 and keep getting the error "load MP feeder plain paper" thanks for the help chip loye
Please follow my tips ,When you print your computer before you go to print properties.Setting paper layout choice paper source and enable MP tray then print ok.
keep your mind before print you must be insert paper in MP tray.
Sep 28, 2009 | Lexmark T630 Laser Printer
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Lexmark T630 Laser Printer Logo
590 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
