Question about GE Spacemaker JVM1640SJ Microwave Oven
Safety hazard if microwaves dont vent straight up?
Does it matter if the over the range microwave does not vent straight up? The outside vent (they used a straightened elbow joint) pipe was installed at a lower level than the microwave and off to the side due to a wall stud being directly in the middle where the top vent of the microwave is. So to connect the microwave top vent (cant use the back vent option) to the 3.5" x 10" house-vent, I have to use an elbow joint (airflow goes sideways and up) angled up to the drywall, which then due to the way the vent pipe is installed to the exterior, the airflow goes down, and off to the side a bit.. Is this an safety hazard fire issue or is this ok? Does grease buildup an issue if there is not a straight air flow or how does this work?? Will someone in the know help me with this, single woman who needs to be able to sleep at night!! Thks!!
  • GE Master
  • 9,098 Answers
As long as the air flow is good, gravity shouldn't make any real difference.
For more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Posted on Mar 16, 2017
  • 9098 Answers
SOURCE: cold air from outside coming in house through vent
Sounds like your damper (flap) outside is working, and that's probably the first thing to check. Wind may be also pulling the damper open from time to time. Hopefully the pipe fitting is sealed, and the pipe is insulated anywhere it runs through any unheated portion of the house. Some amount of cold air getting in will be unavoidable. The best bet next might be to look over the two pages in the installation instructions that deal with outside venting. If you don't have the installation instructions, you can get a copy here: Then if you don't notice any obvious problems with the installation, it may be time to contact the installer for their two cents.
Posted on Feb 05, 2007
SOURCE: GE JVM2070 issue
The same thing just happened to us..... there is no fuse on the microwave but we check our fuse box and tried another plug and it still did not work. GE sent us a new smartboard and now I trying to figure out how to get the thing apart.
Posted on Apr 05, 2008
SOURCE: Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Posted on Oct 07, 2008
  • 9098 Answers
SOURCE: Glass in microwave door shattered in middle of the night
There was a suit in Texas about this, but i don;t know if it led to a recall.
Did you contact GE customer service?
If not, GE Customer Service is here.
Please let us know what you find out so we can help others!
Posted on Nov 27, 2008
  • 9098 Answers
SOURCE: need minimum height of venting before going exterior when install
You can download the installation instructions here.
They will tell you all the requirements.
You can also download your owner's manual here.
Posted on Jan 13, 2009
Do i need a special vent kit to vent microwave to outside
Yes, an adapter/kit should have come with the unit and then you would have to buy the piping etc.If you do not have the adapter/kit get it from the manufacturer or unit seller.
Sep 12, 2014 | Samsung 2.0 cu ft Over-the-Range Microwave...
Trying to find out if I need to have the microwave vented to the outside
It doesn't matter some are some are not vented to the outside, if you have a vent already set up then use it....
Apr 14, 2014 | Kenmore 30" Microwave Combination...
GE Spacemaker arcing?
It is possible, but you heard a similar bang earlier, from the description the magnetron is arcing on a occassion because it is failing, or there is bare metal exposed on the interior. I would recommend getting it checked out to make sure there is no safety hazard and have it resolved.
May 02, 2012 | GE SpaceMaker Microwave Ovens
Is there a piece I can install on the bottom of my over-the-range microwave that will help keep the front of the microwave from being covered in steam when cooking on my stovetop?
Every over the range microwave has a vent on it that should be venting that steam. I don't know of anything you could put under there that would solve your problem as that is where then vents are and they would be blocked. It sounds to me as though your steam is not being vented properly, and this could also happen if the steam is being vented back into the room instead of outside as many OTR microwaves allow you to do. Its a little bit of work to vent it outside but I myself did that with my microwave and have never had a steam accumulation problem.
May 03, 2010 | Maytag Appliances Over-the-Range Microwave...
Why double filter on Maytag Microwave
If your range hood or microwave recirculates back in to the room.
Both filters are required. The mesh filter catches the grease & air particulate. The carbon filter should be changed regularly ( avoid range fires that spread quickly) & clears the recirculated air from smoke,odors, & airborne particulate.
With yours venting to the outside, you ONLY need the mesh filter. These filters should be cleaned regularly ( Avoid mentioned hazard) & should be replaced when you can no longer clean them enough to see through them when holding up to the light.
Good Luck
Apr 30, 2010 | Maytag MMV4205 Microwave Oven
Samsung Microwave for over the range vent issue
Most over the range models can be vented to the outside, or they can be set up (sometimes requiring a special adapter) to recirculate with a charcoal filter.
It depends on the model, and you would of course have to consult the installation instructions to be sure.
You can download many Samsung over the range microwave installation instructions here.
You may need the free DJVU viewer to view or print your manual.
You can order Samsung parts here.
Dec 05, 2009 | Samsung Microwave Ovens
I dont have a vent for above range microwave oven
It doesn't have to vent outside. These are designed to recirculate the filtered air back into the room. If you cook without a range hood now it will work fine for you.
Oct 29, 2009 | Whirlpool MH7140XF Microwave Oven
Replace vent over stove with microwave & the
So are you saying that the vent hole doesn't line up with the microwave vent hole? I had a similar problem, it didn't matter since most of the new over the stove microwaves can vent back into the house as an option.
Sep 14, 2009 | Microwave Ovens
How to vent outside
are you referring to an over the range microwave with an exhaust fan? It should have come with a damper kit and adapter to go a standard duct size and run it either trough the back wall or straight up
Jun 17, 2009 | Microwave Ovens
Kenmore microhood
"Microhood" seems to be a slang term for the "microwave hood" (hood fan or exhaust fan) which is normally part of an over-the-range microwave oven or range. But these should be available separately, as I seem to recall. I would contact home centers such as Lowe's, Home Depot (if they still exist), etc., or a local appliance store.
Dec 06, 2006 | Kenmore 62622 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
75 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
