Question about HP Pavilion dv6000z Notebook
My compaq 6325 will not go beyond the power up
  • MICK FIXIT May 11, 2010
    TRY A REINSTALL ,MAY BE A VIRUS ,TRY F8 SAFE MODE
  • ltoso May 11, 2010
    what do you mean by that, did you mean that you just see the compaq logo and it stays there.or you see any error after the compaq logo appears or you see the windows log after compaq logo and the system freezes.
    if there is an error please mention the error
    i am standing by for your answer
My HP Compaq nx 6110 freezes afta the HP invent screen and doesnt go beyond that, and if i plug the adapter the system boots automatically but not beyond the HP invent screen. Please help.
Hello
Press and hold "CTRL," "ALT" and "Delete" at the same time. Wait and see if a prompt window loads. If one does you can select the program causing the crash and close it. This allows you to return to using the laptop.
Push and hold the power button until the system turns off. Typically, you need to hold the power button down for a few moments before the laptop shuts down.
Remove the power cord from the laptop if the power button does not turn the computer off. Occasionally this can occur, in which case you need to find an alternative way of cutting the power.
Flip the laptop over if the power button is not turning the computer off. Find the battery compartment on the bottom of the laptop and remove it from the computer. Momentarily the computer shuts down. Leave the battery out for a few moments.
Insert the battery back into the computer and press the power button. Shortly, the computer restarts and begins to load the operating system.
press F1 at start up to check the bios for power management settings as perhaps there is a conflict to the settings in Windows. Also I would check what is running in startup (msconfig) and leave nothing but essential antivirus and antispyware. I have seen Norton or MacAfee come up and cause this on several HP Laptops until I uninstalled every last bit of it
also ensure the laptop is in a roomy place a overheating could also be the cause
Dec 15, 2010 | HP Compaq nx6110 Notebook
I need the pc suite to install on my hp nx6325 laptop powered by windows7
Please find the link below to be helpful
Choose the appropriate link to get to your driver.
hp nx-6325
Dec 11, 2010 | Computers & Internet
Power on password is unknown
If you can get the cover off your notebook safetly,take out the cmos battery and put it back in,then power up your notebook...that may work:)
Apr 12, 2010 | Compaq Armada 1571DM Notebook
I need to know how to hook the power cables up from the hard drive floppy and all that other stuff to the power
The power supply should have several power connections coming out of it. Make sure yours provides the correct connection for your hard drive type (SATA or IDE). Beyond that, you should see where they connect.
Mar 11, 2010 | Compaq Computers & Internet
Compaq 21'' monitor power supply led is not working
I didnt know they still made cathode ray tubes. Id suggest you junk that thing and get a decent LCD screen.
It is beyond the scope of this website, and possibly your skills as an electronic technician to go through complete troubleshooting scenario.
Mar 09, 2010 | Compaq Refurbished PE1140 21 SVGA COLOR...
Not reading sd memory card
install all original drivers.
Jun 03, 2009 | Computers & Internet
I have a compaq laptop that the screen is dark but beyond the darkness you can see the stuff on the screen, i took it to a repair shop and its not the backlight or the inverter.what else could be causing...
the number of these i have fixed..... i'm 95% sure its the backlight, though it could have some underlying issues with the connectors on the motherboard, and a slight possibility of it being the graphics chipset, check if its under warranty with compaq, if it is have them walk you through thier troubleshooting, and have it sent off to them, they will get ya fixed and on your way, try a power cycle though. pop out the battery and pull out the cord,then hold the power button down for a minute and put the battery and ac adapter back in, if it dont work call compaq. :D cheers
Jan 24, 2009 | HP Compaq Presario V2000 Notebook
Using my iPAQ 6325 as a modem
only by bluetooth !!! Try to determine services on IPAQ by your-PC bluetooth device... You must to see the "dial-up modem service" --- select it and do a settings by provider...... that`s all !!
Sep 11, 2005 | HP iPAQ h6325 Pocket PC
HP Pavilion dv6000z Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
