Question about HP OfficeJet D135 All-In-One InkJet Printer
Reload/restart error fax worked yesterday but not today. nothing has changed and nothing is broken. fax document goes through ADF without jamming or anything else, but i get this error after it goes all the way through. just tried sending through the glass without a problem. do you know how to help? thanks.
    Problem Solver:
  • 3 Answers
Simply turned off and on several times.
wonders never cease, nor do errors (scan failure) with this MFC.
Posted on Feb 20, 2009
The fax is received by the other party but we receive an error code J72. There is no jam
Dear
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Thanks.
Mar 05, 2015 | Panasonic PanaFax UF-8000 Laser Fax
PIXMA MX330 Error message "Document in
The sensor may be dirty even if it looks like there is no paper jam. Take a bottle of compressed air and give it a once over. Make sure you don't shake or tip the compressed air as you don't want to fast freeze anything.
If this does nothing, you probably have a failed sensor which will need replacing.
Chris
Aug 18, 2011 | Canon Office Equipment & Supplies
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Cannot clear paper jam
Paper Jams in the Automatic Document Feeder
If you're loading legal-size paper, insert only 10 sheets at a time to prevent paper feeding problems.
If paper jams inside the ADF, clear the jam and reload the paper as follows:
1.
Open the ADF cover and remove any jammed paper.
Caution:
Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism.
2.
Press OK, then select Yes and press OK to clear any messages on the display screen.
3.
Reload the paper. Make sure the corners of the paper are not bent, folded, or curled up.
Jan 11, 2011 | Epson WorkForce 600 All-In-One InkJet...
Document in ADF error, however there are no
I'm having the very same problem. No paper was ever stuck and the first time I tried to scan a document by laying it on the glass, not even through the feeder and it did this, and just like with you now it won't even print. Apparently this happens a Lot. I sure wish I would have seen these issues before I bought it! I wish I could help you out, but at least you know you're not alone.
May 02, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My Canon MP530 indicates that I have a paper jam. There is no paper jam - I have checked and re-checked and turned it off and on several times and it is still reading that there is a paper jam. How do I...
Hello there You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 25, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
J 72
I don't have my manuals today, but I think there's a jam in the ADF (just pull it straight up to open)
Sep 05, 2008 | Panasonic PanaFax UF-8000 Laser Fax
No copy and send fax from adf unit
First try reseting the unit by holding the * key and the enter button and the same time turn it on until it starts beeping. This will rest the machine. If this does not work. you need ADF rollers the can be purchased for 20 to 25 bucks
May 08, 2008 | HP LaserJet 3380 All-In-One Printer
HP OfficeJet D135 All-In-One InkJet Printer Logo
67 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
