Question about Pioneer XV-HTD520 Multi-disc DVD Player
AMP FAN ERR on Pioneer XV-HTD520
Have always had unit plugged into surge suppressor. Power went out and when it was restored, unit displayed AMP FAN ERR and shut itself off. According to manual this is a problem with the cooling fan. Took it to dealer and had them send off for repair estimate. They told me it needed new fan, pickup and PC board and repair was more than unit was worth. I find it very hard to believe that "it just wore out" as the repair center told me. This is only 5 years old and has barely been used.
  • 67 Answers
SOURCE: dvd playback freezes or is choppy
Get a cleaning disk and run it through the machine. Could be a dirty lens on the laser.
Posted on Jan 22, 2008
tech48
  • 624 Answers
SOURCE: pioneer xv htd520 won't play dvds
This is a common problem for this model. It has a memory IC that must be replaced. This is a surface mounted IC that requires exceptional soldering skills to replace. I work at an authorized Pioneer service center and have repaired a good number of these for this exact problem. Unless you have great soldering skills it is not something that should be attempted to do yourself, it can cause permanent damage to the board if not done perfectly.
If you have the proper skills and soldering equipment I will be happy to give you the Pioneer part number so you can replace it yourself. If not, then you really should just take it to a service center and have a professional do this.
Let me know if you would like that part number.
Dave
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: PT FAN ERR
There is a fan located inside the unit used to cool the output chip. I iwould take a look to see if it is full of dirt, or is not turning.
Posted on Mar 12, 2009
Nic61
  • 1073 Answers
SOURCE: Need service manual for Pioneer XV HTD5
http://www.service.pioneer-eur.com/peeservice/InstrManuals.nsf/0/817C627E26301ED841256BE300511FA3/$File/XRB3016_XV-HTD50.pdf
The manaula as asked
Good luck
Nic
RATE me pls:)
Posted on Mar 17, 2009
SOURCE: dsc-363 displays code " oc err 1 "
It's output power amplifier ic problem. change ur output ic
Posted on Jan 27, 2010
Recently we had a electrical storm in which the power went out and came back on several times. This DVD player is plugged into a surge protector. Now when I try to turn the player on, it gets stuck in...
hi,
sounds cooked, open it up and look at the board with a magnifying glass and a strong light to see if its cooked anywhere. that was a nice dvd player too. google the name brand of that surge strip and see if theres other complaints. get rid of that surge suppressor and get an apc which completely isolates all your living room electronics..
jm
Jul 02, 2017 | JVC XV-FA900BK DVD Player
I have a pioneer dvd/cd receiver player,,, xv-htd540 and the timer light is on,, and the unit wont turn on..
i don't have a solution , sorry . but i am looking for a user manual for the xv-htd540 . do you have one ?? dennis
Jun 01, 2010 | Pioneer XV-HTD520 Multi-disc DVD Player
Help getting sound from New Sony LCD Television Model XV HTD520 DVD Player with Surround Sound S HTD520
While I could not find it in the manual, I found that you must
go to the menu, open Sound Options and set Speakers to "Fixed".
Note: If you turn off the Surround Sound or DVD player combination you must then go back to the menu and turn the speakers back to Televsion.
Jul 21, 2008 | Audio Players & Recorders
Dvd playback freezes or is choppy
Jan 22, 2008 | Pioneer XV-HTD520 Multi-disc DVD Player
Compaq intel pentium 42.8ghz512mb
How old is your computer? Did you recently have a power outage or anything? Most the time if a computer won't turn on, something in it went bad OR an outlet is bad. Try this:
1. Make sure that the power switch is on, the switch in the back (on the power supply itself) is turned on, and everything along those lines is functioning.
2. If that doesn't work, and it will not power on AT ALL, make sure the cords are plugged firmly in place, including the surge protector and/or the power cord itself.
3. Try resetting the surge suppressor and/or plug the computer into a different outlet in the surge suppressor. Try other items in that surge suppressor (or even in the wall outlet, if that's what you're plugged into) to make sure that the outlet itself is working.
4. If your computer is plugged directly into a working wall or surge suppressor outlet, try a different power cord.
5. If your surge suppressor works, your wall outlet has power to it, and you are using a known-good power cord in the computer, you will have to go into more in-depth investigation as something inside the computer likely went bad. It could be the video card, motherboard, CPU fan, power button, or the power supply itself. Start by testing the video card and the power supply by (one at a time) swapping out a known-good component for the one you suspect may be bad. If it won't turn on after that, try swapping out the next and try it again. If it still will not work, it could be something more serious such as the motherboard or power button.
it could be a bad power supply or a bad motherboard. Other problems might cause issues, such as a bad video card.
Jan 16, 2008 | Computers & Internet
PT FAN ERR
Oct 03, 2007 | Pioneer HTD-510 System
Pioneer XV-HTD520 Multi-disc DVD Player Logo
119 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
