Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
Turn off tv will turn on but only on for five minutes then turns self off. power button flaes in sets of three times continuouslly
  • Justin Thomas Apr 26, 2009
    My Sony TV will work fine for about 15 minutes and then will power off and the standby light will flash in sets of 3. I have not had any issues with my picture going dark or having issues. I did not get a message saying that my bulb was reaching its life end. I know the light code flashing in sets of 3 usually means the LCD door is not installed correctly, but I have not had the door off. Today I took the bulb out and tried to reseat the door, and to me the bulb looks fine and does not look burned out. The door goes back in place and locks down but it still will not come on. It has a flashing green light for a few seconds and then the flashing red code. I don't want to replace a bulb if that is not the issue, but not sure if there is anything else I can check.
    Thanks for any help you can provide!
  • 10,594 Answers
I think you recently replaced lamp or opened lamp cover which is not installed properly.
Please check Lamp Cover because 3 times error shows that lamp cover is not fixed.
Posted on Feb 19, 2009
MY REMOTE TURN THE TV ON, BUT IT TURN OF MY IT SELF. I CAN TURN THE TV ON BY POWER, BUT IT ALSO TURN IT SELF BACK OFF.
do the self check this set has, when power light goes off, ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT (DEVICE) BUTTONS FOR AT LEAST FIVE SECONDS AND RELEASE BOTH.
Watch the power light, it will blink a two digit error code=====most common is two blinks, two blinks a pause and it will repeat the code several times.
This is to narrow down where the problem is.
Let me know what error code you find and I will tell you what it means.
SD TECH
Nov 10, 2010 | Mitsubishi WS-48313 48" Rear Projection...
Turns on stays on five minutes works great then goes on standby
These tv is famous for high voltage it dead or cold solders to it FBT.The flyback transformer,a big black block of plastic with a red wire with a cap hook to the CRT(tv tube).U know how to solders? Take the tv aparts resolders the FBT.Or tries press the power button on/off couples times,if u get a picture.Don't touch it let it on,for three or four hours.Let the heat from the electricity to Amp up the heat,might solved this problems,without resoldering.
Apr 21, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Lost blue; otherwise normal; blinks 5x
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Left tv unplugged for a few months no tv won't turn on
The first thing to do is try to turn on the set with the remote and then when it doesn't respond go to the set and hold down the MENU and INPUT buttons at the same time until the power LED starts blinking a two sequence code. Like 2 - 4 or 1 - 2. The code will keep blinking for five or six times and stop. The blinking is the microprocessor telling you why the set is not working. We techs call that a self diagnostic function. Which this set has. Just repost your findings.
May 27, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Trinitron kv-32FS100 Black screen periodically, with sound, light blinks 5 times
5 blinks means there is a short in hor.section or the power supply
about 200.00 --- 250.00
Jul 12, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
145 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
