Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher has no power
Dishwasher was working one day then when i came home from work that evening the unit would not come and had no power. I checked the the breakers in the fuse box and even swapped out breakers and still no power. is there a reset or fuse on the dishwasher somewhere?
    Scholar:
  • 165 Answers
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
Posted on Feb 19, 2009
The lights of my Viking dishwasher VDB200SS are flashing and do not stop even if I reset the unit by pressing start for more than 4 sec. The pump is running when I connect the unit to electric power for a...
Hello Jo, welcome to FixYa.
Based on your post, I suspect you mean the drain pump is running as is common for Asko built machines such as your Viking with this scenario/error. I have good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What this usually means is the control has indicated a overfill. All the indicators flashing is the error code for overfill/drain error.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump or a inlet water valve, so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit activates the pump-out non-stop
letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary. Good luck.
Regards,
Macmarkus :)
Oct 17, 2011 | Viking VDB200 Dishwasher
All of lights on a panel are blinking when I turn on my dishwasher.
Hello, welcome to FixYa.
Based on your post, "Asko 1996FI Dishwasher. ..All lights on panel blinking", the good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
-What this means is the control has indicated a overfill-
(it could mean a faulty drain pump so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit and the illuminated LED's are
Regards,
Macmarkus :)
Aug 18, 2011 | Asko 1996FI Dishwasher
Dishwasher cycle stops and readout says F2
Based on your post, "Asko 1485 Dishwasher. It is showing a F2 code", the good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What the F2 means is the control has indicated a overfill.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump... (it could mean a faulty drain pump so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit and the illuminated F2 letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary. Good luck. Please take a moment to rate my solution and your experience here at FixYa today.
Regards,
Macmarkus :)
Jul 16, 2011 | Asko D1776 Built-in Dishwasher
I have an Asko 1485 Dishwasher. It is showing a F2 code.
Regards,
Macmarkus :)
Jun 02, 2011 | Asko D5152XXLS Dishwasher
Stuck in drain cycle
Welcome to FixYa.
Based on your post, the good news...I can fairly confidently tell you It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What the pump running continuous means is the timer has indicated a overfill.
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit and the continuous pumping is
Good luck.
Regards,
Macmarkus :)
Apr 26, 2011 | Viking DFUD042 Built-in Dishwasher
I opened the door and the machine started running; the display panel flashes F2 and cannot be turned off or reset.
Welcome to FixYa.
Based on your post, the good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
Good luck.
Regards,
Macmarkus :)
Apr 15, 2011 | Asko D1976 Built-in Dishwasher
My dishwasher keeps displaying "F2"
Welcome to FixYa.
Good luck.
Regards,
Macmarkus :)
Mar 21, 2011 | Asko 24 in. D3350 Dishwasher
New Control Unit not working
i think this machine need a test run on it,i suspect a problem in the circuit and it might have blown the board again.adrian,,
Jul 13, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwasher showing wrench symbol after using dishwashing liquid
I am assuming this F1 error is coming in only one drawer and that you are able to run the second drawer as normal.
In the case of your dishwasher the F1 error occured because the foam would have overflowed over the drawer top into the base of the unit. This would have triggered a flood switch which is there to protect water damage to the dishwasher. You can either wait a few more days until the base of the dishwasher drawer unit dries up or you can dry it yourself.
To dry the base, extend the drawer as far out as possible (turn mains power off first). The use a few towels and push them on to the base. Pull the towels out and dry the base especially the centre of it with a hair dryer.
The F1 should disappear once you put power back on .
Hope this helps. You have a very helful child who sets the dishwasher up. I have to keep pushing my children to even empty it.
Jun 04, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My frigidaire washer has no power.I check the circuit breaker and everything is fine. The unit was working 2 days ago, it just stopped working.
have you checked the main wiring under the dishwasher.if the is good and you have power to that point then you need to change the main control board.i hope this helps your problem.get luck
Jan 23, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Whirlpool GU2400XTP Built-in Dishwasher Logo
576 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
