Question about Ricoh Aficio 1027 All-In-One Laser Printer
I have a ricoh 1027 but it does work codes sc 548
You have a problem with your fuser - either an overheat, or lack of heat. Can only be reset by technician in a service mode, once it is fixed
Posted on Feb 20, 2009
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Im got problem with my copier machine model ricoh 1027,sc code 542..i no problem with fuser temp..after i clear code sc, same problem happen..so am don't no how to solve this problem .please help me to...
If you can tell that the fuser is trying to heat up then you are going to have to replace the thermistors. The thermistors or thermisters are 2 parts in the fuser that "read" the fuser temperature. When 1 or both go bad then the machine can not "see" the heat and thus throws the code. Ricoh's in particular have more issues with the thermisters than other brands. Here is a link to a site that has the thermistors and a picture of what they look like.
Good Luck and Thank You for using Fixya.
WheatlandServices
http://www.precisionroller.com/search.php?q=ricoh+1027+thermistor
Dec 21, 2010 | Ricoh Office Equipment & Supplies
Ricoh 1045 only one copy printed then error code sc 342 will seen
Hi, there's no sc342 listed in the service manual, and I've never seen that code in years working on these machines. Are you sure it's not a different code, like sc542?
Sep 14, 2010 | Ricoh Aficio 1027 All-In-One Laser Printer
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
SC543 ricoh Aficio 1027
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermostat open
• Poor connection of the fusing unit
Inspect all the elements before mentioned, soon presses total clear (Yellow Key) 1 0 7 and Maintain pressed clear stop key (orange key) more tan 3 sec. Enter SP 5-810 (SC code reset),
select execute, select close. Exit SP mode, turn the main power
switch off then on.
If the problem continuous the problem can be in the Power supply board, can be defective.
Aug 10, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Code shows SC 548 how do I clear this
SC548: Fusing unit installation error - Definition - [A]
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -· Fusing unit is not installed
· Poor fusing unit connection
check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion,
this sc 548 usually happens when paper jam occurs and user does not properly fit the fuser... also not fiitted properly due to some foreign object in between fusing belt and the sensor...
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps. if this doesnt solve ur problem then try contacting ur ricoh service tech
good luck
Aug 09, 2009 | Ricoh Aficio CL3500N Laser Printer
Service Code SC 542
That is fuser code and needs to be reset in the service mode, it will not go away by turning the off and back on.
May 29, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh MP 2510
Fuser installation error. Fusing unit set error. Remove the fusing unit out of the machine and reinsert it. It isn't seated in there properly. Once you do that the error code will go away.
Sep 15, 2008 | Ricoh FT5832 Copier
Ricoh Aficio 1027 All-In-One Laser Printer Logo
172 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
